Question about Panasonic SC-PT960 Theater System with Wireless Speakers
Scpt960 wont power on
I have the unit plugged in but nothing lights up and the fan dosent come on. i dont know how to tell if the chord is bad or something inside the device is bad.
  • David Kirchens
    David Kirchens Feb 12, 2012
    i know i spelled a few things wrong sorry about that
2 Suggested Answers
  • 11 Answers
SOURCE: Panasonic LA95 Portable DVD
any flashing red powerlight ?? (assuming theres any charge left)
if the powerlight flashes quickly then the units kaput ( bin it)
slow flashing means the microswitch may be stuck (the one that turns off the screen when you close the lid.
you may have to be sneaky at a dealer and ask to plug in to a new mains unit ( most new panasonics still use the same power supply voltage and ampage. if it works then run away quickly and go buy a universal power supply, if it doesnt , well your in the right place tobuy a new one ??
Posted on Feb 07, 2010
Have a DISNEY CARS MODEL#c1310 atv 13" TV AND WONT
possibly bad tv chord (at plug) or fuse blown inside of set..somehow you are not getting power..
Sep 05, 2014 | Televison & Video
When I press the switch button the power led comes up but nothing shows on the screen, the cpu fan rolls for few few seconds and stops
try to do a power drain.... unplug the power chord... then remove the battery.... while the battery is out... press and hold the power button for 30 seconds.... then put the battery back in and then the power chord.... then try booting it up.... if it works well and good.... if it does not and u see all the lights but not anything on the screen, try with an external monitor just to check if its an issue with the lcd screen.... if its working on a different monitor, u know what to do... take it to a service center....
again if nothing works... dont wait.. take it to a service center
Mar 18, 2011 | HP Compaq nc6000 Notebook
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light...
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Oct 14, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
No power. T light does not illuminate.he monitor is plugged in 110 volt as usual. Now when I press the power button nothing happens. power on
1. Check whether power is there
2. Check the power sockets receives the power supply
3. Check the Female socket on power chord is fix with male socket on monitor
4. Check the power chord is leak free.
Nov 17, 2009 | LG L1932TQ LCD Monitor
No power light if bulb is bad? plug unit in the fans don't work and no power light.
Check the internal fuse since power is not flowing into the projector and the chord too, which could have been damaged ..........sodeep
Nov 10, 2009 | Sony VPL-CX75 Multimedia Projector
Won't power on
try these solns: (not a joke) it worked sometimes with me. 1. remove the power chord and count for 1 minute then put it back then put it on. 2. reseat your RAM 3. make sure your processor fan is really inplace. 4. reseat your video card 5. make sure your monitor has power, hehe.. if not, well tell me, i may have more suggestions. its hard to know how to fix your hardware with less information.
Jun 10, 2009 | Compaq Presario 5000 PC Desktop
Fan dosent work also the temperature gage
Sounds to me that the temp sending unit needs to be checked or replaced, bad sending unit can cause a multitude of problems.... ie Fan not running, Engine running rough, Try checking for voltage at the sending unit with the ignition on but not running. Possibly bad sending unit.. Unit is usually located near the radiator hose that goes into the engine. usually round nut with either 1 or up to as many as 3 or 4 wires coming out of it Check the voltages there.. If you dont have power going in and nothing going out when the engine is warmed its bad.,...
Apr 29, 2009 | 1995 Mercury Tracer
I plug my xbox 360 in everything is all plugged in... but i when i plug the power in a fan starts up no lights no green or red lights NOTHING. and it wont turn on wat can i do
Talk with microsoft and give him a description of your problem. It sounds like the main board is bad but dont quote me on that. You have a one year warrenty on damages like that to your xbox so give them a call and let then know of your situations.
Jan 16, 2009 | Microsoft Xbox 360 Console
Vicking VIDV500 Kitchen Hood
steve...first, is the light working? If not, you may not have power. If so, turn off all power to the unit at the breaker. Remove the filter and see if the blower turns easily by hand. Yes...switch could be bad...no...motor bad.
Open up unit and using test light from the hardware store and motor plug disconnected...turn on fan and probe the motor feed wire for power. It may be the switch that's bad. This should tell you.
Dec 01, 2007 | Viking VEDV900 Kitchen Hood
Samsung tv stoped working, it now wont power on, the red standby light dosent come on.
Yup I would tend to agree it's probably the PSU... It shouldn't be too expensive to fix, probably an hour or so labour and either parts OR a complete new PSU, in saying that ensure ya take it to a reputable service place.. and get a "quote" B4 allowing to continue.
Jul 30, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Panasonic SC-PT960 Theater System with Wireless Speakers Logo
102 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
