Question about NetGear DG834G Router
Vista and remote printing
My printer is attached directly to my Netgear DRG843 router using the network interface and works fine. The router is attached to my Desktop Dell computer running XP. I have recently bought a laptop using Vista which will not print to the 3210.
I have installed the printer vista drivers, I can look at the printer details via its IPaddress. I have tried changing/ adding a port and making its address the IP address of the printer. All to no good. I thought Vista was supposed to be an improvement. Any thoughts or help gratefully receieved - or I am going to just throw the Vista off and go back to XP
    Master:
  • 409 Answers
Have you applied SP1 to Vista? It is supposed to fix a plethora of issues.
Posted on Oct 24, 2008
Netgear fs516 default ip address
switches do not normally have ip addresses as they are layer 2 network devices. They work on the MAC address of each network card attached to it to direct the network packets of data to the correct Network card.
Cisco Switches have an IP address but it is a virtual ip address used to remotely log into a Cisco Switch via IP but has nothing to do with the switching function however this is not a cisco switch.
Routers have IP addresses and use them to switch IP addressed packets to other Networks that have Routers connected to Switches.
Jun 30, 2014 | NetGear FS516 Networking Switch
Can I connect non-wireless printer directly to netgear rangemax wpn824?
No you cannot.
To make your printer a network printer you need to connect your printer to a network print server and the connect the print server to the Netgear using a LAN cable.
Feb 14, 2013 | NetGear RangeMax WPN824 Router
How can I turn a CLX-3185FN into a CLX-3185FW?
Buy a Netgear WNCE 2100 which has one wired ethernet port connected internally to a wifi radio which is a 2.4GHz transceiver with WPA security. Fully compatible with most routers from D-Link, Netgear, Buffalo, etc. The samsung printer has a USB port to which you can connect and power the WNCE2100. This product is called by two different names. Sometimes it is called a Universal Ethernet Adaptor and others it is called a Network Bridge--which is more accurate. The Netgear product is b/g/n compatible. Try to place it not more than one room away from the router because the signal strength drops very fast if it is more than one wall and or 40feet from the wireless router.
Jan 03, 2011 | Samsung CLX-3175FW Multifunction Laser...
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Jan 01, 2010 | NetGear WGR614 Wireless Router
How do I know what my SSID is for my NetGear router Can I hard wire a printer and also send jobs by wireless to same printer? Do I have to download the software in order to print wireless from a different...
Go into the router configure to view the wireless settings, it contains the SSID and encryption etc.
Open IE browser and enter the Netgear URL configuration IP address (http://192.168.0.1)
A network printer must have a built-in print server or be attached to a print server device on the network then all the computers on the network can access this printer.
For a run of the mill printer to work as a network printer it needs to be attached to a computer which is on your network and the printer needs to be setup as a shared printer. This printer and computer must always be switched on for the other computers on the network to access and print to this printer. This method does not require any additional software.
Nov 18, 2009 | NetGear WGR614 Wireless Router
Can't seem to print thru wireless network anymore.
Follow the instructions in this document for setting up your printer in a wireless environment.
Aug 31, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Netgear wpn824v3 slow connection, etc
MTU Adjustment
1. Access the web-based utility of the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
2. Adjust the MTU setting.
a. Click on the WAN Setup under Advanced tab.
b. Lower down the MTU size to 1492, 1400, 1358 or 1300.
c. Click on the Apply button.
Note: You may verify from your ISP the recommended MTU size you can use.
May 02, 2009 | NetGear RangeMax WPN824 Router
Macintoshes and Print Servers, the PS110 in Particular
Topic 1. What do I need to connect a Macintosh to the PS110 Print Server? A PostScript printer with a parallel interface, a Mac running MacOS 8.6, 9.x, or 10.x. (NETGEAR products are not supported for earlier versions.), and Ethernet cables to connect the Print Server to the printer, and the Print Server to your Macs, and to a router. NETGEAR's RP614 router is known to work connecting the PS110 to the Internet with Macs. Topic 2. How do I avoid losing my network configuration when restarting my Mac? When changing theMacOS configuration it is best to use Configurations (MacOS 8.x or 9.x) or Network Location (MacOS 10.x) settings instead of changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). That way you can be sure the changes will not be lost after rebooting. To Create a Configuration in MacOS 8.x or 9.x 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. Select File > Configurations > New Configuration. 3 . Type a meaningful name for your new configuration (e.g., NETGEAR Wireless Router). 4 . Make your changes to the AppleTalk or TCP/IP settings. 5 . When closing AppleTalk or TCP/IP choose Save Changes. Whenever making Configuration changes for settings in MacOS 8.x or 9.x, open File > Configurations or press Command-K. Changes in Configurations are saved after rebooting. To Create a Network Location in MacOS 10.x 1. Open the Apple Menu by clicking the Apple icon in the upper left of the screen. 2. Select System Preferences. The System Preferences window displays. 3. Click Internet & Network > Network. The Network Settings window displays. 4. If the window is locked, click the Lock icon in the lower left to unlock the Network window. (You may be asked for a username and password.) 5. Click the pull down menu next to Location at the top of the Network window. 6. Select New Location. 7. Type a name for your new location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left to prevent further changes. The Apply configuration changes window displays. 10. Click Apply to keep the configuration changes for the newly-created location. 11. Close the Network window. Topic 3. How do I connect a Mac to the PS110 Print Server? For MacOS 8.6 and 9.x 1. Follow the instructions in the NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-PostScript printers with Macs on the PS110 Print Server.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer to be used with the PS110 Print Server on your Mac. 5. Open Chooser from Apple Menu. 6. Select LaserWriter 8. 7. Select the PostScript Printer to use. (This is probably the description for the PS110 Print Server and may have a name like ?PSD90335?. This name may be different on your computer.) 8. Click Setup. 9. Click Select PPD. 10. Select your printer from the Printer Descriptions list. 11. Close the Chooser. 12. Click OK. A message displays: ?You have changed your Desktop Printer.? You can now connect to the RP614 Router Gateway, and to the Internet. For MacOS 10.x 1. Follow the instructions in the printed NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-Post Script printers with the Mac and the PS110.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer you will be using with the PS110 Print Server on your Mac. 5. Open Utilities > Print Center in the MacOS 10.2 Applications folder. The Printer List appears. 6. Click Add. The Printer Selection window appears. 7. From the top of the Printer Selection window, select AppleTalk from the first pull down menu. 8. Select Local AppleTalk Zone from the second pull down menu below. 9. Click the Print Server from the list in the window. PSD90335 ? PostScript Printer in the case of this test. 10. Click the pull down Printer Model, and select the model of printer connected to your Print Server. A list of printers displays. 11. From the scrolling list select the Model Name of the printer connected to your Print Server. 12. Click Add. 13. Printer List displays with the list of printers and print servers connected to your Mac. Select the name of the Print Server from the Printer List. 14. Click Make Default. 15. Close the Printer List. 16. Open a file and try printing it. You can now connect to the RP614 Router Gateway, and to the Internet.
Feb 19, 2006 | NetGear RP614 Router
NetGear DG834G Router Logo
71 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
