Question about Craftsman Garden
WITCH SCREW IS THE FAST SPPED SCREW ON 358.794773 BLOWER
TWO SCREWS ON CARB WHICH IS HIGH SPPED
4 Suggested Answers
  • 149 Answers
SOURCE: poulan pro bvm200 leaf blower/vac won't run on high
Is the exhaust spark arresor screen clean? a blocked exhaust will do this.
Posted on Jan 08, 2009
  • 124 Answers
SOURCE: How to adjust the carb on a McCulloch super
There is no set adjustment on any blower or chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the
adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Posted on Sep 20, 2009
rycgl
  • 1545 Answers
SOURCE: need "L" and "H" setting on carb mixture screws
Lightly seat the screws all the way in....then back them out about 1 and 1/2 turns. From there here is how to do the final Zama diaghragm carburetor adjustments.
http://www.zamacarb.com/tipspage.html
Posted on Oct 30, 2010
Testimonial: "thanks"
RYOBi 790r EZ Carb has 2 adjustment screws. Which is high speed and low? Approx no of turns out
You should see an H an L around those screws. Usually the High Speed is right an Low left. It's easy to figure out when engine starts adjusting high speed will cause engine to change revs. A good rule of thumb is between 1 1/4 to 1 1/2 turns. Look for the letters on the carb around the screws.
Jul 18, 2017 | Ryobi Garden
ADJUSTING HIGH AND LOW ON A CARB FOR A STIHL FS 45 WEED EATER
Hi..in general i always set the high and low screws at 2 turns out from a complete stop..and please dont tighten the screws too tight..it will bend the needles...I think it will..or should run at them settings...as far as the gas out of the engine..it is or has a problem with the carb...did you remove the carb...? Also try starting it with only starting fluid for a very short time..this is how I check to see if all else is ok..spray it in the carb in take...
May 05, 2016 | Stihl Garden
How to adjust zama carb
start with your screws turned in. adjust the high screw to 1 turn and the low to 1/2 turn. this should get unit running. once running then you can fine tune the carb
Oct 09, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I have a Stihl 009 chain saw that I just rebuit the carb on and when it runs at high speed it does so only for a few seconds then dies. It will idle all day long. What could the problem be?
Have you replaced the fuel filter in the tank? it will idle as the engine is not calling for much fuel, however at full revs it calls for a greater amount of fuel, if that fuel is not available the saw dies.
Dec 29, 2012 | Garden
2wire wireless usb
You just go to network connection and select your network connection. Just right click to it and go to properties. Configure it which suits you best (Do it if you know about dialling rules and near by dialing environment ie if this support the high speed prefer high speed and it support low spped then do low spped as it optimized the network utilizations.) You can also use network utilization tools available in tune up utility, etc whichever availabel in market.
May 31, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
My kids mongoose mayhem bike has a 6 spped gear
Being highly mechanical, this is a job for a trained Bike Mechanic. Get him to show you how to do it and you will be self-sufficient in the future.
It sounds like the gear cable is rusty or bent (requiring replacement) or needs lube. The upshifts occur solely from spring tension in the rear derailleur. Too much resistance in the cable housing and it won't happen reliably. A little maintenance will go a long way.
The 2 small screws are for the high and low limit of the derailleur to keep the mechanism out of the spokes or the chain from being positioned outside the smallest gear. They have nothing to do with individual gear selections.
Look at this for detailed info...
http://www.parktool.com/repair/readhowto.asp?id=64
Mar 12, 2010 | Cycling
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
My troy built lawn mower dies after it starts runs for a few seconds dies if i put my thumb in the carb it will stay running.
Your high speed needle jet is most likely the cause. Remove the jet and clean it out. Keep in mind that there may be least one or two very small holes drilled in to the sides of the high spped jet, if so, be sure they are cleaned and not clooged.
Jan 17, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How to set carborator adjustment on Poulan Wild Thing 2375?
hello,the starting point for adjustment screws is 2 turns out.turn in til lightly seated so as not to damage them. there are 2 or more style carbs used on saw,some have plastic caps that need to be removed(a small metal screw used as a corkscrew or pry off) or you need a special tool -splined.set high spped til runs good and back off an 1/8-1/4 turn so you dont burn it up. fine tune low spped so it accelerates when trigger squeezed and re check high speed adjustment.single screw is for idle spped-raises or lowers-if chain turns while at idle back off screw.
mowerman33@verizon.net
Oct 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2002 dodge grand caravan heater blower only works on high spped
If you are looking for the fan blower resistor, it is located behind the glove box. No tools need to get to it and a nut driver to remove the 2 screws to replace it. A 20$ part.
Jan 06, 2009 | 2002 Dodge Grand Caravan
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
