Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer alignment I have a hp officejet 6110 all in one printer. We had a power failure and the printer would not come back on. I unplugged it from the wall and left it for 20 minutes or so, plugged it back in and...yes...power. It is prompting me to press enter to align cartridges. I have done so over & over yet the prompt remains...Help!
  • 3 more comments
  • Anquita Nov 16, 2007
    Had a smiliar problem-replaced the black ink cartridge and it keeps telling me that it is aligning the cartridge but is just pushing paper through the printer, then telling me it's out of paper when paper is there, and it's still not aligned!!
  • Anonymous Dec 30, 2007
    yes I had same problem...this seem to fix it...but still need to print to verify it worked...at least it got it out of the "loop" of tryiong to aklighn carterages... Thanks.
  • Anonymous Jan 01, 2008
    Same problem - working one day, then for no apparent reason (thinking I may have replaced one of the cardtridges) stops working. Get the align cardtridge thing over and over, then busy - tried the partial reset (plug in while holding down 3 and the # keys). Then full reset (plug in while holding the Enter and Cancel keys. Still broken at this point.
  • Anonymous Jan 03, 2008
    Same issue as above. Switched to a different black cartridge, but still get the press enter to align message. If I press Enter again, it says busy. ???
  • ejdejdejd Mar 31, 2008
    repeated prompt to press enter to align print cartridge
Hold down the enter button for 5 sec. then simultaneously press the menu button
Posted on May 08, 2007
My hp officejet 6110 all-in-one carriase are stuck completely and cannot remove cartridges either my hp officejet 6110 all-in-one carriase is stuck as for left and want move at all
Try to power off and unplug the printer, then force the carriage to move with your hand
When the carriage moves, place it in the extreme right position, then plug in and power on :D
Aug 17, 2014 | HP OfficeJet 6110 All-In-One InkJet...
Hp office jet 6100.
is ther firmware update to it go to www.hp.com suport area download latest drivers ok save to hardrive then remove old ones then install new ones from add remove in control panel ok after new driver hold power in unplug it then plug back in hold that power for 10 sec manaual reset also in the settings
Jan 31, 2008 | HP OfficeJet 6110 All-In-One InkJet...
I haveHP 6110 all-in-one printer that I can make copies from my lab top computer by...clicking on print...connects to printer.....says paper jam...I then press "enter" on the printer....a sheet of pap
You may try to reset the printer per HP instructions.
1. Turn on printer with power button
2. With printer on, disconnect power cord from rear off printer.
3. Unplug power cord from outlet
4. Wait at least 15 seconds
5. Plug the power back into the outlet
6. Reconnect power cord to the rear of the printer
7. If printer does not come on, press the Power button.
Dec 30, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 all-in-one printer -- Getting error message "Press Enter to align cartridge." We've had this error before and did as instructed and it's corrected itself. However,...
turn off the printer
remove the cartidges.
Take a damp paper towel and clean the contacts of the cartridges and also the contact inside the holder of the cartridges.
put back the cartridges.
Print a self test
Also clear the the printer memory
Jul 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
When I turn the officejet 6110 on after afew seconds i see the message of "scanner failure turn power off then on asign"
Before turning the power off, please press and hold the power button for 30 seconds to try and do a reset. Then, power off, unplug the printer from both the printer and the power supply. Turn off the computer. The wait about 10 minutes, plug the printer back in to the power, then into the computer. Then start up the computer and see if the reset helped solve the problem.
You may have a hardware problem however. We will see what happens after the reset.
Brian
Feb 11, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Changed cartridges, printer doesn't align or function
Something seems to be physically wrong in the mechanism.
Try the rolling wheels and the belt on which the cartridges run.
Jul 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Alignment test keeps failing How di I override?
press the cancel button after you on the printer and wait a movement till the cartridges adjust and settle inside.
Aug 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Every power up requires set up
theres usually a small battery on these mfp machines which is soldered onto the formatter board, this would need replacing. Bes is don't turn the machine off.
May 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
411 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
