Canon ir 2018. What do system errors E000 and E003 indicate?
5 Suggested Answers
SOURCE: How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Posted on Jul 12, 2008
SOURCE: System Error E000 and E003
E002 Error code details Heater temperature error (fails to reachspecific level; inadequate increase)
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Action
 See the description for E003. E003 Error code details Heater temperature error (abnormal drop; low-temperature detection)
0000 The main thermistor reading is lower than 140°C when paper is moved.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Action
1. State
 Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate?
 NO: See "The fixing heater fails to operate."
2. Wiring
 Is the wiring from the DC controller PCB to the fixing film unit normal?
 NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
 Try replacing the fixing film unit. Is the problem corrected?
 YES: End.
 NO: Replace the DC controller PCB.
Posted on Sep 06, 2009
  • 23 Answers
SOURCE: my canon IR 2018 copier is giving me system error
This is a problem with the fuser unit, this is the section that heats up. Once the code comes up you will need a service tech to come out to check your copier. The code can only be reset by entering the service mode. If your lucky and all looks well in there it may just need to be reset with no parts to be replaced.
Posted on May 17, 2010
  • 6 Answers
SOURCE: canon IR 2018 system error E007
E007 means that the fuser film inside the Fuser unit is damaged which needs to be replaced, or the white patch on the fuser film is dirty and it just needs to be cleaned. I recommend getting a canon technician to fix it,
Posted on Jun 01, 2010
I REALLY NEED SOMEBODY TO TELL ME WHATS AN E000 IS
You need to formulate your post into a sentence that makes some sort of sense instead of a cryptic error code. You know something like
"I have a Canon MG7120 al in one printer. I was printing, it stopped printing and the display shows E000. Can you tell me what the error is and how to fix it please"?
WHAT DOES SYSTEM ERROR E000 MEAN? - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting
  1. Cached
The error is a system fault error that can sometimes be reset: Follow these steps to reset the error: Press Additional Functions key. Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it. Ask Your Own Printers Question ...
I have an MF4350d. It is showing SYSTEM ERROR E000. What does ...
  1. Cached
I have an MF4350d. It is showing SYSTEM ERROR E000. What does that mean and what do I need to do? Thanks! - Answered by a verified Technician.
Technology Time: Canon Error E000, E001,E002, E003, E007
www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
  1. Cached
  2. Similar
I described in a previous post that E000, E001, E002, E003 and E007 are fixing unit temperature error codes. Lets go into more detail now. .... I have A problem canon 2002 when i power on the machine then show error E002-0000 pls advice me what i do ? ReplyDelete ยท Lizpeth G. ... What's prize of cannon copier E354?
Mar 08, 2018 | Office Equipment & Supplies
What does error Code e00030000 from Canon ir 5075 Mean?
I have come across :
E000 - The heater fails to heat
E003 - There is an error in the rise in temperature
Can you recheck the error message?
Aug 07, 2014 | Canon Office Equipment & Supplies
Canon iR 2022 gives a system error E000 and error E003, what could be a problem?
how to clear error code e000 please help me copier ir 2022 show me how to clear
May 19, 2011 | Office Equipment & Supplies
System error E000
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Mar 24, 2010 | Canon imageRUNNER 2010F Copier
System error e000
E000
The error history indicates any of the following error codes 4 times: E001, E002, E003.
Which relates to the fuser temp. you need to change the fuser unit.
Sep 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
2,450 people viewed this question
k24674
jasbo
jasbo
