Question about Stanley Composite Hacksaw
Put together a hacksaw - Stanley Composite Hacksaw
Point gap wanted for honda 300u generator
General rule of thumb for point gaps.
25 thou.
Hacksaw thickness
Should work fine.... it's not a precision machine?
Mar 06, 2015 | Honda Electrical Supplies
Tip
Choosing the right hacksaw for your job
For every project that you want to work on, there will be a different set of tools that you will need to use. The hacksaw has different types of blades and frames that can be switched out for the different projects that you are working on.
There are three main kinds of blades that the hacksaw can use and each one has different benefits. The teeth on the hacksaw blade will range between 14 and 32 teeth per inch. The thicker the blade the fewer teeth there will be per inch on the blade. The types are regular, raker and wavy. Regular blades are good for soft metals that don't have a lot of metal and the teeth will be closed together touching and alternating left and right. The raker blade has teeth placed in sets of threes and are best used fro cutting through thick metals. The last kind of blade is called a wavy blade, on these ones the teeth are in a wave pattern that are great for making smooth cuts in hard thin metals.
When it comes to hacksaw frame types there are two types to look at the fixed frame and the adjustable frame. Fixed frames are only able to hold a blade of a single sized length of blade. The adjustable frame can hold different length blades typically between 10 and 12 inches. The blades that you will buy for a hacksaw will have holes on either end of the blade. These holes are used to attach and dettach the blades from the frame.
Whatever the blade that you are using make sure that when you are sawing through metal make sure that you go slow because rubbing metal on metal will generate a lot of heat and can spark. You can also ruin the blade on your if you are sawing too quickly.
on Feb 02, 2014 | Saws
Are there different types of hacksaws?
They aren't really different types of hacksaws, they're more like variations of the traditional hacksaw. There is the panel hacksaw, junior hacksaw and the power hacksaw.
Jan 02, 2014 | Saws
Am i better off using a hacksaw or a pipe cutter to cut the metal pipe that runs through my garden?
Although pipecutters are generally seen as giving a much cleaner and better cut than hacksaws, they are a bit limited in what they are able to cut through. Hacksaws however can cut through all sizes of plastic and metal.
Dec 26, 2013 | Cutter Tools
Whats the difference between a hacksaw and a panel hacksaw?
a panel hacksaw has no frame, so it is better for use in cutting sheet metal
Jan 28, 2013 | Saws
Remove broken key from egnition
Hi
Use needle-nose pliers to pull the broken key out, if there is enough of it sticking out of the ignition to grab. Put a little melted wax, Museum Putty or Super Glue on the pliers before you grab the key.
Make sure that the ignition is in the "neutral" position so that the tumblers are not gripping the key. If it is in the locked position, insert a thin hacksaw blade--with the teeth facing up--next to the broken key, and turn the ignition to the "neutral" position.
Pull gently up on the hacksaw blade. If you are lucky, the teeth will grab the key and slide it out. Try this with the hacksaw blade behind the key, and again on top of the key. Most keys have a groove on them that the hacksaw blade can grab, so wiggle and twist the hacksaw blade around and see if you can feel it catch the key.
Try using the hacksaw blade and the pliers together--pushing with the blade and pulling with the pliers.
Cut or break a six- to eight-inch piece off of a wire coat hanger and use your pliers to fashion a small hook at the end. Slide this into the ignition behind the key and try to grab it. If that doesn't work, insert the wire in front of the key and try again.
Spray a little cooking spray or WD-40 into the ignition and try again with the hacksaw blade. Remember to try both in front of and behind the key, and to wiggle the blade. Do not spray the lubricant before trying the pliers or wire, because now your key is not only stuck, it is slippery.
Call a locksmith if the above steps do not work. Do it before you get too frustrated, because it is much cheaper to replace a key than it is to replace a key and a shattered ignition.
Also check this useful link:-
http://www.diylife.com/2010/06/24/the-daily-fix-remove-a-broken-key-from-a-lock/
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 23, 2012 | 2002 Kia Spectra
Where do I find a screwdriver to open up the case? The scews that hold it together have a raised part in the middle of the screw head so a regular screw driver does not work.
Hi there
Most decent tool suppliers will sell you a kit of bits that are interchangeable with most battery drill/drivers.
Loads of manufacturers fit these raised center screws either hex or torx driver to reduce the number of people who can repair their equipment.
Regards
Gordon
Apr 17, 2011 | Soleus Air 25-pint Dehumidifier
SPARK GAP FOR 1990 TOYOTA COROLLA I bought NGK G-POWER PLATINUM SPARK PLUGS Looking everywhere - I checked all the panels under the hood and I don't have a car manual for my 1990 4 cyl 1.6 litre 4-door...
Do you happen to have a hacksaw blade? The thickness of the hacksaw blade is equal to the clearance of the
spark plug contacts. You can put the hacksaw blade flat
between the contacts, and make the necessary adjustment. Then, start your engine. Send in your e-mail
so we will know.
Oct 11, 2009 | Toyota Corolla Cars & Trucks
Mr.
I found a way to do a fix that should last for awhile. Put the large gear in a vise leaving room to partially knock the small broken gear through. I used a bolt the same size as the hole in the plastic, and tapped it in about 1/4 inch. This pushes some of the small gear through, exposing more of the usable part of it. I then cut (hacksawed) off about 3/8 inch of the broken part, put it back together and it works!..................Good luck, Sparky
Jan 07, 2008 | Office Equipment & Supplies
Stanley Composite Hacksaw Logo
484 people viewed this question
Top Stanley Saws Experts
Rob Bridges
Level 1 Expert
Jim
Level 1 Expert
Are you a Stanley Saw Expert? Answer questions, earn points and help others
