Question about DreamCatcher Interactive Enigma: Rising Tide - You Are In Command for Windows
Enigma:Rising Tide Cd Key - DreamCatcher Interactive Enigma: Rising Tide - You Are In Command for Windows
My enigma autoclave isn't starting. There is no error message on the screen. It just beeps 3 times and does nothing?
I know nothing about Enigma but this is typical of PC problems with memory. If there is a Keyboard, try getting into Bios by restarting and pressing F2 and Del keys alternately on turn on. This gets you into most computer Bios. When there, look for Memory/RAM to see if it is seeing any. Try "Reset to defaults" as a last resort.
Try to get the manual and look for "Trouble Shooting" section. If it has info on memory installation (for example, adding or replacing, read carefully.
If you have a techie guy there, think about opening up the Enigma to get to the main board (mother board) and removing the RAM module(s). If you can have them tested, do so. If not, clean them with a dry clean toothbrush, blow out(or vac) the main board socket the RAM came out of (be sure Enigma is plugged in and off and not too much vacuuming as it builds up static). And if there are more than one RAM, plug in only 1 or reverse the slots or use other slots if there are any. Try all combinations. Power off between each removal/insertion. Be careful and gentile but firm. Be careful of static electricity. Any little "Snap" you hear from touching some thing is a hazard to electronics, so keep in touch with the machine to stay grounded. Hold the RAM, use that hand to touch the Enigma 1st without touching the RAM to the Enigma and then proceed. That grounds you and by default, the RAM safely. Peep the Enigma plugged in but turned off except when testing.
Nov 20, 2016 | Computers & Internet
My cd code will not work keep getting an error message,
The code is called an activation key, and it is good for one computer install only. In order to get a valid code for this new computer you must contact the software makers support by email and and explain that your old computer crashed and you need a new activation key code for the replacement, they may provide one free of charge, but not all do, it is a good will type of situation.
Dec 20, 2011 | DreamCatcher Interactive Enigma: Rising...
Need installation drivers for enigma 3.1, lost disk
Here's a link for a driver. Just need to put in a verification code and then click download. Might have to click on a thing with a blue arrow pointing down that pops up on the top of the screen that asks you to download the file. If that happens you might have to restart the download.
http://download.driverguide.com/driver/Enigma+1.3/Digital+Dream/d362827.html
Dec 20, 2010 | Digital Dream Company Enigma 1.3 Digital...
I want to play the steel tide without CD inseeted in the CDROM
Hello timpugrt
You can download the latest no-cd patch from here:
http://m0002.gamecopyworld.com/games/pc_operation_steel_tide.shtml
Make sure you back-up the original .exe file before replacing it.
Hope this helps. If you require further help, please donĀ“t hesitate to ask.
ajblaj
Sep 10, 2010 | Infogrames Steel Tide for Windows
DreamCatcher Interactive Enigma: Rising Tide - You Are In Command for Windows Logo
344 people viewed this question
Top DreamCatcher Interactive Video Game Consoles & Games Experts
Dominic
Dominic
ray gallant
Are you a DreamCatcher Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
