Question about Encore ENLTV-FM-HA (CTETVC)
Initialize hardware default
I am using zebronics usb tv box but now a day whenever i start the program the error message -initialize hardware default.. appears pls help me ..my system is windows xp essential-service pack 3...my email id is ...suku1957@gmail.com.thank u in advance..Dr,C.Sukumar.
  • mazid Nov 16, 2008
    i am using zebronics usb tv box but now a day whenever i start the program the error message -initialize hardware default.. appears pls help me ..my system is windows xp essential-service pack 2
    please mail me.
  • prabakaranme May 03, 2009
    I am having the same problem. i searched all over the internet, no solutions. I don't know whom to blame? The Buyer("US") or the Manufaturer ("Zebronics").
5 Suggested Answers
SOURCE: FAILED TO INITIALIZE HARDWARE ????
I tried the Solution #3 and it works fine for me !!!
Its complicated but fixed the problem
Thanks
Posted on Mar 05, 2008
SOURCE: Failure To Initialize Hardware
OK I think your problem may be that you need to install/reinstall the drivers.
Does it show up in Device Manager? If so, Uninstall it, reboot and then reinstall the drivers when, if? XP detects it and asks for drivers.
Hopefully this will sort it. If not, then maybe ya card is faulty.
Posted on Jan 19, 2010
SOURCE: ''failed to initialized hardware!''
I had the same problem.... (the "failed to initialize hardware!") I found a solution posted somewhere... it's not my discovery, but I've checked it and it works. First of all, you need to uninstall the drivers for the Enutv. You can do that from Control Panel> System> Hardware> Administrator of Devices (I'm not sure about this last label, as my XP is in Spanish, but it's the first button in the folder). The hardware should be listed under the label sound, video and games devices. Once you uninstall the driver, you unplug the hardware and reset the computer if necessary. Now turn over to the installation cd. Inside the drivers folder, there is an XP folder and a Vista folder (choose the one you need), copy the 32bit folder to your computer, and plug in the device. When the Asistant runs, instead of looking for the drivers automatically, make the search yourself. And when it asks you for the file, select it yourself (it is the one in the folder you copied from the cd - note: if you don't have the cd you can download it from the Encore website). Once you finish with that, you can install the enutv software and enjoy it. I've read somewhere that you should re install the OS, but that is not necessary...
Hope it help!
N86
  • 36 Answers
SOURCE: I've ZEB-i2010 internal tv tuner
Try installing this software and see what you get. It comes from the manufacturer of your card.
Posted on Jan 10, 2011
SOURCE: When I want to start
I am Using The XPOD, XDC-700 TV CARD.It is given me replay ErroorCode#E0601009.Please help me that what can i do for it.
Posted on Nov 15, 2011
Unable to format usb stick
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Aug 05, 2012 | Dane-Elec DaneElec 4GB USB Drive Copper...
Have the SimpleTech SimpleDrive External 400GB hard drive. When I click on StorageSync I get the message "Program is already running. Can't create process". Don't know what to do? Any help?
Go to task Manager > processes tab and find the StorageSync program and end process. Unplug the drive, shut down the PC, replug and start up the Pc and try again.
Oct 29, 2008 | Computers & Internet
Printer wont print
what ink has failed?
please tell the exact error message
Aug 17, 2008 | HP Photosmart C6180 All-In-One InkJet...
Everytime i log in, facebook acct doesnt appear, pls help
It seems that Face book have some internal error this days many people complaining like u.
dont bother hope it fixes in short term.
use proxy if its urgent.
please vote
Jul 25, 2009 | Computers & Internet
I'm trying to install drivers for USB2.0 TV Capture Box but it says initialize hardware default. Is it that I need to get the vista drivers. I can not identify the manufacturer of this TV box...Help!!!
GO INTO CONTROL PANEL LOOK FOR INSTALLATION OR NEW DEVICES OR DO YOU HAVE WIZZARD FOR INSTALLS
MAY HAVE A COM PORT ISSUE OR IRQ ISSUE
THAT STOPPING THE INSTALL PROCEDURE.
NEED MORE HELP
CANDYMANGANDY
Jan 28, 2009 | Sabrent TV Tuner / Video Capture Box USB...
Tech-Com failed to initialize the capture device on Vista
I don't know if you have already solved this problem. Here is a solution I came across in one of the sites.
I too had a similar kind of problem... Now, the problem initializing the capture device was solved but still I am unable to view the TV channels.
Nov 24, 2008 | Sabrent TV Tuner / Video Capture Box USB...
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
SAN DISK PEN DRIVE troubleshooting
When i connect the pendrive into the USB drive the indicator light doesnt glow on pendrive and no "new hardware found" message appears on the screen.
Mar 18, 2008 | SanDisk Open Box 1GB Cruzer Mini...
Computer does not read
Have you had any other devices that use the USB port have any problems. Sounds like you have an error with your USB drivers on your computer. I would suggest that if you are using a microsoft product such ash windows XP or Vista they have a program that will fix your USB drivers. Try running the program and then try your movie box again and see if that works. One other thing have you tried it in a different port could be a damaged port on your computer.
Thanks,
Mark
Dec 17, 2007 | Pinnacle Studio MovieBox USB Video Capture
Initial GM-501
its a software issue....it turnes out initial is out of bussiness...they sold their technical support to a third party company real *** holes...its a manufacrurer error....they told me is i wanted to fix it they will have to charge me $150.00 to reset the software....thats rediculous i shoped around and the initial units are runing around $120.00....well good lood and never buy an Initial product
Oct 01, 2007 | Fine Digital FineDrive 400 GPS Receiver
Televison & Video Logo
396 people viewed this question
Top Encore Televison & Video Experts
Electro Med Services...
Are you an Encore Televison and Video Expert? Answer questions, earn points and help others
