Question about Vacuums
Scunci wet/dry vac model 52171 - Vacuums
  • 143 Answers
SOURCE: scunci cordless wet dry vac wont hold charge
battery pack has developed memory and needs to be replaced
Posted on Sep 20, 2009
Testimonial: "thank you"
  • 447 Answers
SOURCE: Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
Posted on May 16, 2010
Asbestos 56
  • 191 Answers
SOURCE: We have a scunci recharge
if the charger is working, and the battery does not hold a charge for very long, you will need a replacement battery. this is the most likely problem. if the battery does not charge at all it may well be the charger and you will need to replace that. hope this helps
Posted on Jun 08, 2011
javeedcare
  • 316 Answers
SOURCE: I have an old shop
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Posted on Jul 04, 2011
hunter19_46m
  • 7482 Answers
SOURCE: need owner manual for Scunci
Hi citykitttyka...
I could not find a user manual, but I found a webpage explaining how to use your Scunci...
Please take time to rate me
http://www.ehow.com/how_5601648_use-scunci-steam-cleaner.html
Posted on Aug 17, 2011
Testimonial: "I appreciate the time an effort you took to assist in finding an answer for me. I was unable to find a user's manual or much of any useful info regarding the Scunci canister wet/dry vacuum cleaner model #52033. Thank you, I really appreciate it. The solution you found was for a steam cleaner. I actually own one, it will be valuable to me when I need it. Thank you."
I have a scunci rechargeable wet and dry vac. Model 52069. I plugged it in to charge green light turns on. Couple hours later I unplug it and push the button nothing. Need instructions or manual.
Most likely the rechargeable battery needs to be replaced.
Unfortunately, I haven't been able to find a battery pack listed anywhere. You'll probably have to have a company like Batteries + Bulbs (In the USA) take it apart and replace the battery pack.
Nov 11, 2016 | Scunci Vacuums
Need owner manual for Scunci 52033 canister wet/dry vac
Hi citykitttyka...
Aug 17, 2011 | Scunci 52033 Canister Wet/Dry Vacuum
We have a scunci recharge cordless wet-dry vac model # 52033. The battery does not charge. What can we do to fix this?
Jun 08, 2011 | Scunci 52033 Canister Wet/Dry Vacuum
Do I take off the dry bag and the fome cover when picking up moisture ???
dont know what model you have, but, as a rule, the dry bag is for dry vacuuming and the foam is for wet vacuuming.
Feb 12, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Nov 04, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
Scunci cordless wet dry vac wont hold charge
Sep 19, 2009 | Scunci 52033 Canister Wet/Dry Vacuum
Shopvac 2010
Just be sure to remove the paper filter bag that fits over the foam filter before vacuuming liquids. It's easy to get it wet and they don't work very well when that happens.
Dec 10, 2007 | Shop Vac 201-13 Wet/Dry Vacuum
Vacuums Logo
54 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
