Question about Digital Concepts 952AF for Pentax Flash
Diagnostic Mode for "Digital Concepts Flash 952AF"?
Actually my Flash works fine, I've a question though. There's a interesting thread on the web, how to get into the diagnostic mode of a Nikon Speedlight for increasing the output – to increase the sync speed!
link:
http://strobist.blogspot.com/2008/04/overclock-your-speedlight-for-more.html
Is it possible to do the same on the Digital Concept Flash? Is there a hidden button sequence?
thanks for the answer.
manuel
  • 411 Answers
SOURCE: I have the 952AF/CAN it worked twice, the flash
yes dscharging section failure,do replace,the concern parts
Posted on Mar 07, 2010
Why can't I download adobe flash player for my iPad?
Steven Jobs has a thing against Flash. As long as he's in control, there likely won't be a Flash player available for the iPad (or the iPhone, or the iPad touch).
May 01, 2011 | Digital Concepts Cameras
The wing of my hot foot has broken off due to a wayward volleyball at an intermural tournament I was photographing. Is there a way I can get a replacement foot or casing?
You are basically going to have to look for either junk camera or contact a Pentax desler or someone who can repair the camera. If you can find a parts camera then its is a simple matter of swapping parts. Getting a genuine replacement part may prove to be rather expensive if the part is in the system.
Jan 20, 2011 | Digital Concepts 952AF for Pentax Flash
I want to know how to use the 952AF/Nik with the nikon d200 using multi flash units with the commander mode set to channel 1
The vivtar 952AF flash is not compatible with the D200 in commander mode. Only the Nikon SB600, SB-800, SB-900 will work with that camera wirelessly.
Oct 11, 2009 | Cameras
Quantaray QDC-900WA
Quantaray appears to not be a company at all It is affiliated with Ritz Camera and neither Quantaray nor Ritz actually manufacture anything.
The Quantaray SLR lenses are made in the Sigma factory. But many feel that they are not equal to the Sigma branded lenses.
I haven't found the maker of the flash units, yet. I should learn more this evening. An interesting mystery.
In here, you can find the User Guide for Quantaray 900 for Nikon TTL Flash
Good luck.
Jun 16, 2009 | Quantaray QDC-900WA for Nikon TTL Flash
Camera won't turn on, I need the webaddress to this company!!
I have a little black Digital Concepts camera and after losing my manual and disk I was able to find information/driver/manual by going to:
http://www.sakar.com/p-218.aspx?categoryid=155
Through that link you will also be able to find tech. support's contact information in case you want to call/email for more help.
Jun 12, 2009 | Digital Concepts 952AF for Pentax Flash
952AF/CAN Flash
I guess you did the basic thing and see if the flash fires when pressing the shutter button.
I don't know the Rebel itself,but I can suggest a few general things. I will be speculating here for you.
Make sure that in the setup for the flash, that the curtain is in the correct mode. If I remember right there is something about when the flash will fire. Check this in the instruction manual.
Also check the flash sync speed range. If the sync speed is out of range for the flash, it will fire at the wrong time. If you want to experiment, try using 1/60 for a start just to see if it works.
If you call Canon tech support, they will help you.
Jerry G.
Apr 17, 2008 | Cameras
Digital concepts camera
you've got to change the view... it may be on the outdoors view. On the side of the camera opposite the batteries, there's a switch that has a flower, and two piramids. Change it to the piramids and turn on the flash
Dec 31, 2007 | Cameras
Cameras Logo
Top Digital Concepts Cameras Experts
Tony
Steven Wander
Steven Wander
Are you a Digital Concepts Camera Expert? Answer questions, earn points and help others
