Question about Sansui HDLCDVD260 26 in. LCD Television
How do i get my sansui tv to work as a computer monitor
Im trying to use my television as a monitor, and when i start up the pc, it will show the "windows is starting up" screen, and then after it goes black and flashes no signal across the screen. I have the refresh rate set to 60hz because i saw some other people saying thats what they needed to do, but its still not working. can anyone give me some in depth help?
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 37 Answers
Dose your tv have capability for use as a moniter, if so all you need is a cable from your computor to the back of your tv, you will need to make simple ajustmenys to your tv.
Posted on Feb 12, 2012
    New Friend:
I cant get sound ?
Posted on Jun 25, 2013
  • Eric Sebasta
    Eric Sebasta Jan 23, 2015
    If you are running VGA you have to go into audio settings and change it from HDMI.
3 Suggested Answers
SOURCE: Sansui HDLCD3200b Drivers for PC
The TV has a resolution of 1366 x 768 for mine, I set the display properties to1280x768 the closest you can get to the actual 720p resolution.
Posted on Jan 23, 2009
SOURCE: I have a Sansui HDLCDVD260,
I have a same Sansui HDLCD 2600 which did not have anything happen when try to switch on. no lights even on the power led. where can I get the replacement parts?
Posted on Jun 28, 2009
Computer vga cable/ sansui tv problem
Hello
Nvedia signals cannot be porcessed by Sansui Tv. You have tow options before you to connect your self assembled computer to this tV. The first one is try by reducing the resolution f VGA output. for that, go to Nvidea control [normally will be displayed at the right end of the taskbar] and chage relolution there. By default, the resolution will be 1024/768. Select it to the lowest; 800/600. If the TV display it, just advance it to the next highest; 960/600.
If this does not help you, there is no other way than change the computer's video card to any other, which works on Windows Video Drive. Can be bought from local computer component market, insert it to one amoung the free PCI socket of the computer and do the next proceedings to change over video output from on board video out, and feed this video signal to yur TV. OK.
Nov 01, 2011 | Sansui HDLCD1908 19 in. LCD TV
I have a Sansui HDLCD 19WB. Can I add speakers? Where do they plug in?
Yes, you can either plug speakers into the back of the monitor in the orange colored slot. But in order for this to work, you must also plug the computer tower audio output into the Sansui's audio input port, which is located directly underneath the monitor's video input (where it is already connected to the computer). If that sounds like too much work, you could always just plug your computer speakers directly into the audio out of your computer tower.
Feb 28, 2011 | Sansui HDLCD1908 19 in. LCD TV
I have hmdi cords and I am trying to get the tv to turn to 1080I how do I do that
This Sansui HDLCD-1900 can only do 720p MAX. The source will determine the display resolution, you do not set it at the TV, just like you do not set the PC monitor resolution at the monitor, it is done at the PC. http://reviews.cnet.com/flat-panel-tvs/sansui-hdlcd-1900/4505-6482_7-33089579.html
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 21, 2010 | Sansui HDLCD-1900 19 in. LCD Television
I want the Windows 7 Driver for Sansui SFL22MH TV/Monitor. Pl. tell me the location to download or send me the file.
ignorant untrue answer. Many monitors and especially older TV/Monitors of odd makers (Sansui for a FACT) are NOT plug and play and windows has no idea what resolutions it supports. Really, all you can do is go under advanced in your adapter settings and try different resolutions and refresh rates. If you can't see - quickly hit escape. Find the best one that works for your monitor.
Aug 07, 2010 | Sansui HDLCD3200 TV
When conecting a pc up no display
Sansui tv's with a PC input are usually 60hz tv's. Try changing the refresh rate on your PC to 60hz. You will need regular computer monitor to make the change on your PC.
May 19, 2010 | Sansui HDLCD-1900 19 in. LCD Television
I bought an HP-desktop from a friend of mine, i plugged it in and it would not load onto Windows screen. I thought the reson may be lack of a Driver for the HDLCD1955. The computer works on a regular...
On current Sansui lcd and led tv's you must change your PC's refresh rate to 60hz to match the tv's refresh rate. How you do this will depend on what PC you have as well as what operating system. I hope this helps you.
Bobya.
Apr 04, 2010 | Sansui HDLCD-1900 19 in. LCD Television
CONNECTING TO PC
On a Sansui tv, select the PC input on the tv. Change the refresh rate on your computer to 60hz to match the tv's refresh rate. You will need a regular computer monitor to do this.
Aug 15, 2009 | Sansui HDLCD-1900 19 in. LCD Television
Driver for monitor
if u r using xp sp2 ,sp3 or vista no drivers r required for any monitors as such drivers r installed by windows automatically.ok next is go to divice manager and search for monitors if ur monitor has any issues it is displayed yellow.ok even if the device manager doesnt show up any issues with monitor,u can always upgrade the drivers to the drivers that came with the monitors installaion disk that may be supplied with ur system.
Jan 17, 2009 | Sansui 19 in. LCD TV
I have a Sansui HDLCDVD260, 26in Television that I can't get the monitor to work on. TV works fine, DVD player works fine but when I hook up the SVGA cable to use as a computer monitor it just shows a...
After you have set the refresh rate to 60hz and the display mode to the recomended setting, shut down the computer. Turn on the tv and select the pc input on the tv. Connect the computer to the tv and then power up the computer.
Dec 25, 2008 | Sansui HDLCDVD260 26 in. LCD Television
Mar 26, 2008 | Sansui HDLCD3200 TV
Sansui HDLCDVD260 26 in. LCD Television Logo
528 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
