Question about Garden
Briggs and Stratton 28N700 series 15 hp mower motor
Engine will not start.Appears to be lack of fuel.Timing OK.Valve settings OK. Fuel solenoid working OK. Float and needle Ok.Where else can I check please
  • john326 Oct 25, 2008
    Thanks for trying.enginedoc.Problem was that the aluminium flywheel key had sheared and timing was out. Key replaced.Problem fixed. Thanks john326
  • 48 Answers
Do you have spark at the plug - remove it and ground it while you crank the engine . is this an overhead valve engine ? have you checked compression .
Posted on Oct 24, 2008
  • enginedoc Oct 25, 2008
    that wound have been the next place to go - if the spark plug had been wet and you still had spark advice would have been that - glad you found it
I have a 15 HP briggs ovc engine. It will not start. Have checked these items. Compression good, have a good spark when plug is out and grounded, Timeing is okay, valves working properly. Even using starting fluid I get no fireing at all. Is it possible that the plug could not be sparking in the engine eventhough it sparks when out and grounded? I am really confused! Can you help? Thanks David
Posted on Mar 18, 2010
Carb float bowl has an electric selanoid on it no wires going to it how does it work and where do wires hook up
Carb solenoid and a fix, dont forget the cut off valve ...
? 10:23
https://www.youtube.com/watch?v=gQw2pQ_oa6o
Jul 16, 2012 - Uploaded by Murray Mayhem
would you advise doing this on a 2004 Bolens with a 15.5 Briggs..... I have a 15 hp Craftsman-koher riding lawn mower that won't run. ... when I put power to it, and the there is gas in the bowlwhen I take it apart. ... Rename the video "How to Bypass Carb solenoid for Temp Fix on no start" Try to edit that ...
Small Engine Repair: How to Check a Solenoid Fuel Shut ...
? 4:40
https://www.youtube.com/watch?v=Kr6UayxyVwU
Jul 23, 2011 - Uploaded by smallengineshop
When the engine is stored with fuel in the carburetor for long periods, there is a .... There is gas in the carb in the lower portion where the float is. .... Engine hadn't been run for over a year and the solenoid would not operate. .... DIY - CarburetorReplacement On Lawn Tractor With Briggs & Stratton Engine ...
Dec 01, 2015 | Briggs & Stratton Garden
Surging problem on 10 HP Briggs & Stratton rear mounted engine on @86 Snapper mower
Dirty fuel in the tank, breather in the filler cap blocked, or partly blocked main jet in the carb, if there is a fuel solinoid on the base of the carb check its function by removing, when the ignition is turned on the plunger should retract into its housing,
May 28, 2012 | Briggs & Stratton Briggs Stratton...
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
May 15, 2012 | Briggs & Stratton Briggs Stratton...
15hp briggs
the only timing is the key on the flywheel to crankshaft i set the valves to .006 turn the engine till one of the rocker arms opens a valve then set the other one then do the same to the other valve those engines are known for valve seats falling out let me know if that's the case i can guide you to that repair
Apr 02, 2012 | Briggs & Stratton Garden
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
14 hp briggs runs fuel filter dry every 15 minutes. have to blow into fuel tank to fill filter up then it runs for a while again. whats up ?
Sounds like the tank is not venting. Try leaving the cap a little loose and see if it stays running. If it does, either the vent for the tank or a vented gas cap is plugged
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
1,325 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
