Question about Saeco Magic De Luxe Espresso Machine
Master reset for saeco magic deluxe
I ran out of beans mid grind cycle, and now i have a brew unit jammed fault. I have tried to restart the machine with the brew unit out, and the switcjed activated, to no avail. When i switch it on, it doesnt even go through normal check of the brew unit (no sound of motor whir)
mirran
  • 515 Answers
SOURCE: saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Posted on Aug 17, 2008
EsWorld
  • 1618 Answers
SOURCE: Saeco Magic de luxe not grinding beans
Try setting the grind to the coarsest setting, if you still have the same problem, check the wire connections to the board, it might have been reversed.
Posted on May 12, 2009
  • 1089 Answers
SOURCE: Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Posted on Jun 12, 2009
bozcro
  • 867 Answers
SOURCE: poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Posted on Jul 01, 2009
SOURCE: Saeco Royal=,beans do not appear to be grinding,
Coffee Beans were roasted by local business,believe they were either not roasted enough or over roasted causing the problem, I have since tried Supermarket(Vittoria Roasted Beans) and machine is working perfectly.
Thankyou
Keviroy
Posted on Oct 03, 2009
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
Sep 03, 2017 | Saeco Vienna Plus Black Super-Automatic
Beans grind and are wet but coffee doesn't come out... it goes through the cycle and spits out a little. When cycle is complete, the water light comes on, but after priming the same thing occurs.
This tells me that either the grind is too fine and or the brew unit screen, and discharge tube needs to be cleaned. Try this first press the button for making a espresso using the manual function, do not add coffee through the door then press the brew button. If water flows freely then the grind is too fine, if you get the water prime error then the screen under the red o-ring on the brew unit needs to be cleaned.
Oct 19, 2011 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
www.CeriniCoffee.com
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Fault F 17 appears when in use. Starts grinding the beans but no coffee in the cup yet. What does F17 mean?
f 17 is no water flow. It usually occurs when the brew unit has not been cleaned regularly, when the coffee grind size is set too fine, or when oily beans are used. You can try to soak the brew unit in hot water for a while, and run water through it in the sink. Unfortunately, most cases require brew unit replacement. A properly cleaned and maintained brew unit should last the life of the machine.
Jan 26, 2011 | Miele CVA4070 Coffee Maker
DGB-550BK Filter basket won't stay shut when either brewing ground coffee or grinding beans.. With the ground; the basket pops open mid brew and makes a mess everywhere. When grinding beans, I've noticed...
Not a solution but...
Many folks have reported this, the latching mechanism wears out eventually.
We had the problem but discovered that the door on the basket wasn't getting completely closed. Now I make sure it's closed and haven't had any problem since.
Hope this solves your issue - if not, keep an eye on yard sales, we picked up two at different times for $5 and now have parts to swap out - not much help for a failed latch though.
Glad I never paid full price for it, even though it's a fairly good grinder/brewer.
Jan 19, 2010 | Cuisinart DGB-550BK
I put beans in where the grinds should go. help!?
Hi
Open the door and remove the drip tray. Then remove the brew unit and empty the beans. Make sure that you get all the beans. Check the brew unit thoroughly. Then put everything back. Try the pre ground button but don't put anything in the brew unit then push the medium coffee button. That will run the machine through a brew cycle and if it works OK then you set to go.
Dec 30, 2009 | Saeco Incanto Classic Espresso Machine
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Coffee Beans do not grind
Try using the vacuum to clean out the grounds, then remove the brew unit and make sure the chamber from the grinder is clear.
Aug 11, 2009 | Saeco INCANTO DELUXE Espresso Machine
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
349 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
