Installing 3Com wireless lanpc card
I have a 3Com 3crshpw 96 Wireless LANPC Card model No SL-1110 that will not work on my laptop now as all files related to its function were deleted after a hardrive reload. Where and how can I download free installation software for this please?
  • 82 Answers
The connection is limited
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Jun 29, 2012 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Can connect to router via LAN but not wireless.
Try updating wireless driver software. OR wireless driver for ur router might not installed while on LAN conn install them with UBUNTU SOFTWARE CENTER. Still nt works? check ur hardware for problems by experts.> ??? Try updating OS. OR installing another great open source OS with great hardware support.Follow the following link...
www.opensuse.org/
Dec 09, 2011 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Unable to make router wireless
To use a wireless network/connection you need to do.
1. Configure the router's wireless with SSID, WPA encryption etc.
2. Next configure the wireless card in the computer/laptop with the router's wireless settings so it can connect to the wireless router.
Please click on this link for my instructions on how to secure your wireless network, configure the wireless router and configure the wireless card in the computer/laptop :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 10, 2010 | 3Com Computers & Internet
3COM PC Card model 3CRWE154G72 Error code 10: device cannot start
a windows file or files is definitely corrupt,either repair windows xp with service pack3 if possible or do a complete format and re-installation.,and the card should work fine
Nov 24, 2009 | 3Com OfficeConnect Wireless 11g 802.11g/b...
We can't get our IBM T30 to connect with our Linksys router . The computer has a 3com wireless card
Has the Wireless card ever worked attached to another wireless router?
Is the card an internal miniPCI card, and is it an official IBM card for your region? Thinkpads check whether the card is for the correct region before configuring them in the Windows drivers.
Are you using the Thinkpad Assistant Wireless tool. I have found that it appears to be impossible to configure this software for 64 bit WEP or WPA PSK authentication.
Sep 11, 2009 | IBM ThinkPad T30 2366 Notebook
Wireless button
The T30 laptops do not have a on/off button that turns the wireless card on.
Once the wireless card driver is installed the wireless card will detect any wireless router and access point within its range. You need to configure the wireless card to connect into the wireless router or access point eg. the encryption, SSID etc.
The Thinkpad laptops have different wireless LAN cards installed, when you install a wireless card driver and it doesn't work, then install a different model wireless card driver. Also make sure the XP or Vista version of the wireless driver matches the Windows version that is installed on the laptop.
Jul 12, 2009 | IBM ThinkPad T30 2366 Notebook
XP compatable
then you have to used the wireless g router for wireless
Dec 30, 2008 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Computers & Internet Logo
563 people viewed this question
David Payne
David Payne
