Question about Xerox Office Equipment & Supplies
Have a Fuji Xerox Docucentre 11 C2200 Printer and have a printer error 004-333
  • 3 more comments
  • rodneystone Oct 24, 2008
    I have unplugged machine from power and removed from network for at least 10 minutes. I have also tried powering up and holding down similtaneously the power save, 6 & stop keys. These solutions dont clear the error message.
    I have spoken to Fuji Xerox support, however they have suggested they send a technician out on Monday. I need the machine over the weekend.
    Yes I have checked all wiring, the equipment was working earlier in the day.
    Fuji Xerox could not find the error code either, I have also checkjed in my manual and it is not shown. I did try to put a document with approx 30 pages through however it was only text no graphics. I regularly print files up to 60meg. Xerox thought the document file may be jambed before it has hit the print que however the document did show up as qued under printers & faxes but not on the internet screen.
    The electrical including fan seems ok. My IT consultant had a quick look at thew unit remotely, he advised that it is showing as offline. Test pages seem to hang for a minute or so then disappear.
  • 905 Answers
You will need to keep the unit unplugged longer than ten min. , at least an hour or so , there are capacitors that hold a charge for a long time and will keep components in a state for a long time.
if after that it still doesn't work correctly then there is a internal problem that will have to be tested to determine where the fault is
that is an internal error code that can be caused by a component not letting an IC work correctly or a chip itself is at fault
electech
Posted on Oct 24, 2008
    Master:
  • 538 Answers
I suppose a test page has been attempted?
    Sergeant:
  • 306 Answers
  Turn your printer on, remove the power cable at the back of your printer while the printer is ON. PRESS AND HOLD the # key and 3 key on the keypad, plug back the power cable WITHOUT releasing those buttons, DO NOT RELEASE THE BUTTONS until you can see the WELCOME SCREEN or INPROPER SHUT DOWN PRESS OK TO CONTINUE. .. else i recommend you to uninstall ur printer ,restart ur system, install the printer ,restart ur system ,n ur problem is solved !!i think it may help else chek ou tis>> http://download.fujixerox.co.jp/apeosport/download/c4300series/doc/nt4e/README.TXT..
    Master:
  • 505 Answers
Since you require the printer on urgent please contact bestbuy or Geeksquad. They will send a technician at your place with 24 hours.Please dont the printer or else you may damage some internal parts.
Thanks
    Brigadier General:
  • 3,614 Answers
first try to reset all the setting has been made...
and also it seems that the error codes was on the power supply area, check the fan blower on that are if still functioning,,,
    President:
  • 1,952 Answers
Have u checked all ur wiring and componenets are connected properly?
  • 507 Answers
What country?
here's a list of country support desk
http://www.fujixerox.com/eng/support/index.html
  • Xerox Master
  • 19,396 Answers
Try first unplugging power cord for ten minutes, see if this clear the error message.
  • 2 more comments
  • Ginko
    Ginko Oct 24, 2008
    Hi there, try power cycling the printer, unplugging from power, removing toner and putting it back.
    I cannot find error 004-333 in the error code list for Xerox Docucentre, can you double check the error code?
    Thanks.
  • Ginko
    Ginko Oct 24, 2008
    Did they address the meaning of code error 004-333 , I cannot find it in the error code list for this printer?
  • Ginko
    Ginko Oct 24, 2008
    When you get a code that is not in the list that means that is a bad main board, as the error codes are managed directly by cpu on main pcb.
    That is the reason why the helpdest told you that they need to send you a repairman.
  • Ginko
    Ginko Oct 24, 2008
    Hi there , test pages print blank, and unit stays offline because the main control board is defective. When you have an error code that makes no sense, that is usually the reason, either CPU, som onboard component, or firmware stored on printer EEprom have had a problem.
    You need to check connectors, and probably to replace the board.
How to fix xerox docucentre 2056 error 010-327
That error signifies a defective fuser, not coming to temperature. Replace fuser, part number 126K24980. See link below:
http://www.iteminconline.com/126k24980_126k24980-126k24981-126k24982-126k24983-126k24984-xerox-workcentre-5225-5230-fuser-110v-new.htm
Jun 10, 2014 | Xerox WorkCentre 52255230 Copier
How to set up Iphone app to print using FX DocuCentre-II C3000 PCL 6
You must have a wireless PC with iTunes + Airprint loaded - to provide a "shared printer" for IPhone.
Nov 19, 2013 | Xerox FX DocuCentre-II C3000 PCL 6
Do you have a link to download the drivers for a printer xerox docuprint p8ex for windows 7? thanks raul delgado
Hi-
You can try to download the driver here:
http://rapidshare.com/files/353421558/P8exWin7drv.ZIP.html
or
http://www.megaupload.com/?d=B2YJXH31
If this will not work: Try these steps: Steps to install: From Device Manager -> Other devices -> Right click on DocuPrint P8ex -> Update Driver Software Browse my computer for driver software -> Let me pick from a list of device drivers on my computer Double click Printers -> Fuji Xerox from Manufacturer -> FX AP-II C2200 PCL -> Next That should install it, Hope this helps! Good Luck!
Mar 16, 2011 | Compaq Xerox DocuPrint P8ex Laser Printer
Can you tell me what error code 124-315 means on Xerox Docucentre-II 2055 ? and what the recommended fix is. (Multifuncton printer). Thanks, Gajj
hi
regarding your error go to following link
http://www.copytechnet.com/forums/xerox/36062-xerox-docucentre-ii-2055-error-016-315-a.html
Jul 24, 2010 | Office Equipment & Supplies
Any Windows 7 64bit driver for Xerox Docuprint P8ex? The one posted by Droidd is probably 32 bit and does not work in Windows 7 x64. Thanks.
Hi, The Xerox DocuPrint P8ex understands PrinterControlLanguage of version 5e or 6 (PCL 5e or PCL 6). So actually you can use driver from every printer supports PCL 6. Driver for "Fuji Xerox AP-II C2200 PCL 6" working very well for me on Windows 7 64bit. Steps to install: From Device Manager -> Other devices ->Right click on DocuPrint P8ex -> Update Driver Software -> Browse my computer for driver software -> Let me pick from a list of device drivers on my computer -> Double click Printers -> Fuji Xerox from Manufacturer -> FX AP-II C2200 PCL -> Next
May 12, 2010 | Compaq Xerox DocuPrint P8ex Laser Printer
Windows 7 does not have drivers for Xerox Docuprint P8ex
Hi all, The Xerox DocuPrint P8ex understands PrinterControlLanguage of version 5e or 6 (PCL 5e or PCL 6). So actually you can use driver from every printer supports PCL 6. Driver for "Fuji Xerox AP-II C2200 PCL 6" working very well for me on Windows 7 64bit. Steps to install: From Device Manager -> Other devices ->Right click on DocuPrint P8ex -> Update Driver Software -> Browse my computer for driver software -> Let me pick from a list of device drivers on my computer -> Double click Printers -> Fuji Xerox from Manufacturer -> FX AP-II C2200 PCL -> Next
Feb 12, 2010 | Compaq Xerox DocuPrint P8ex Laser Printer
FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
Jan 05, 2010 | Fuji DocuPrint C1110B Laser Printer
I require a service manual for a xerox 3030 wide format photocopier so I can learn to install a new toner
Fuji-Xerox XP-11 (Xerox 3030) Toner / OPC
6R281/13R32, 20k Under switched off printer press and keep the button of the unset, residing near by cord of the feeding; include the printer.
Procedure alike for both cartridges
Sep 02, 2009 | Xerox Office Equipment & Supplies
How can I reset the pasword for a docucentre 24,
Use this link it may be helpful:::
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/
Mar 15, 2008 | Xerox DocuColor 12 Printer
379 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
