Question about Kenwood KAC-8101D Car Audio Amplifier
Won't come on
I noticed a couple days before it stopped my subs were making like a humming noise. That noise would not stop so i just shut my stereo off because i didn't want it to ruin anything. Now when I Start my car my amp just comes on and goes right back off. Also when it comes on it makes my subs make a thump. Then it just goes off. I've heard of something like a safe mode but i don't know what that is all about.
    Scholar:
  • 148 Answers
Check this out: http://www.techlore.com/article/14696/
Posted on Aug 17, 2006
How do I stop my Paradigm sub from humming and "burping?"
The amplifier that powers the sub is the source of your problems. Sounds like some power supply filter capacitors are failing.
Dec 31, 2014 | Paradigm Audio Players & Recorders
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
My Logitech Z523 Speakers make a loud humming noise when plugged into my PC. When i plug it into my phone or laptop there is no humming noise. Sometimes there is a fuzzy crackling sound when it is not...
Mine did the same thing then I found the solution by accident. After reading a post about moving the sub to different positions and making sure connections were tight to the sub , I loosened the right speaker connection screws to the sub and noticed the humming stopped completely . I know it sounds crazy but it worked for me.
Nov 30, 2010 | Logitech Z523 2 Speakers
2003 Dodge Durango makes a funny noise when the ignition is turned both off and on. Sounds kind of like an annoying hum. Stops after a couple of seconds.
Usually the humming or buzzing noise you hear at start and turning off is the fuel pump being activated or shut down.
May 02, 2009 | 2003 Dodge Durango
1997 Nissan Sentra, weird humming/buzzing sounds
can you hear this through the stereo?  If so you may have a problem created somewhere in your ignition , where the stereo is picking up a fluctuating signal.
Mar 19, 2009 | 1997 Nissan Sentra
Sunfire Subwoofer 110 Noise on input plugin
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Sep 25, 2008 | Sunfire True Sub MK II Subwoofer
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
MHC-GS100 Shelf system
to restart, press stop, clear and display at the same time.
Nov 21, 2007 | Sony MHC-GS100 CD Shelf System
Sub-woofer does not turn itself on in 'Auto' mode (signal driven)
For the "auto on" problem.
These will sound very basic, please go with it.
On your signal source, make sure you have the sub set to on.
If you can adjust the output setting on your source, turn this up.
Adjust the volume setting on the sub lower to mach the volume of the main speakers.
You may need to make these adjustments a few times to get them working.
On the hum and noise problem
Check your power outlet for the sub, make sure the polarity is correct. I have found this to not always be right. Also what is on that same circuit. Things like the fridge can cause a lot of noise on the power line. Next check your connecting cables, are they of good quality? Are they running next to anything that may cause interference? Also check you connections to the signal source. Cable and dishes are known for ground problems.
Sep 26, 2007 | Velodyne CHT-12 Subwoofer
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
May 29, 2007 | Frigidaire FAS155K1 Air Conditioner
Kenwood KAC-8101D Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
