Advent ht2751a do you have a schematic or discription on the bent in sides problem on this tv? could you help?
  • 1 more comment
  • jason Oct 24, 2008
    without adjustment
    with adjustment
    board
    thank for anything you can help with on this diode issue
    found the equivalent here http://www.nteinc.com/specs/500to599/pdf...
    thanks for your help!
  • dofii May 16, 2009
    will replacing both these diodes solve the problem or are other parts also damaged
  • 10,594 Answers
I don't have schematics of this particular tv but I would try to help you to diagnose and rectify this problem.
I think that your tv has problem of pin cushion, incorrect picture size at sides, this is cause of few defective parts in Pin Amp area.
I need few clear and focused pictures of both sides of TV main board to see what part is damaged.
Thank you.
Posted on Oct 24, 2008
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Oct 24, 2008
    You can use Diode "PG156R" OR "EGP20G" as replacement part for D155.
    Both diodes are high frequency and used in Pin Amp stages in most TVs.
    Part number for above diodes are as follows...
    8-719-979-85 EGP20G available at Parts Store price is $5.57
    6-501-302-01 PG156R available at Parts Store price is $2
    Thats great you found required part.
Advent tv displays green
If you are saying no red: The model indicated here Recoton Advent Advent Q1435A TV is a 14 inch set.
first it may be cheaper to replace than repair--That said if no red look to the small circuit board at end of picture tube (it plugs onto the tube).
It will have either individual output transistors or a single IC.
What (if only one color missing) I would look at is the bottom side which faces to the rear---a circle of solder connections--possible one is broken--there will be one for each red, green, and blue--not always easy to see but if any of the solder connections look cracked or even broken loose-----
Mar 28, 2012 | Recoton Advent Advent Q1435A TV
Advent Tv on direct tv with snow showing on screen
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Jul 22, 2009 | Recoton Advent Advent HT3251A TV
Curves on TV
You have a bad capacitor off the vertical output I.C..Find the pin off the I.C. that represents the out of the I.C. If you have a capacitor checker, you can check the ESR(equivalant series resistance) to see if it reads high.Look on the internet for a schematic,this will show which pin of the vertical I.C. is output,and the cap. that leads off it..
Jul 07, 2009 | Recoton Advent Advent HT3251A TV
Model ht2751a no power,clicks and power light cuts on and off
I replaced caps in power supply.set work fine now.when off light stay blue,when on light is anber.
Jun 18, 2009 | Recoton Advent Advent HT3251A TV
The picture on my Advent TV HT2751A is curving inwards.
Hi, although I have all sony tvs in my house, every room brand new, when there broke there like a opened bottle of wine ,FLAT, no good!! A 27 is so cheap its worth buying a new one. UNLESS you live where you have friends that fix them on the side. I do and if you ever get to seethe inside of the tv you will wonder what your paying for there is only a few parts in them now and my friend chks them with a machine in 10 minutes if it is worth fixing he has the parts on the shelf and it must be under 100 or its going in the barrel. I have had 1 fixed 10 minutes still good other 1 he threw it out. That's all I can do for you from here, sorry, good luck, Frankie
May 07, 2017 | Televison & Video
Looking for schematics for a Advent TV HT2751A HDTV?
try this
http://www.servicemanuals.net/
Jan 04, 2008 | Televison & Video
Advent HT2751A display no good until after 1-2 hour warmup - maybe
After 3 years, I finally decided to open up the TV and do some troubleshooting. Found out the problem, It was a blown capacitor Location C554 Capacitor value is 2200uF 16V - costs about a dollar to replace yourself and the TV works brand new.
Aug 16, 2007 | Recoton Advent Advent HT3251A TV
Televison & Video Logo
809 people viewed this question
Top Televison & Video Experts
