Question about Refrigerators
Westinghouse fridge freezer
Tophalf fridge not working only freezer works
  • Refrigerators Master
  • 4,654 Answers
First signs of a defrost problem, Sea Breeze
Posted on Feb 13, 2012
  • 105 Answers
SOURCE: my westinghouse fridge is not cooling but the freezer works fine
There isn't a fuse in the refrigerator. Check to see if the fan in the freezer is running, you should be able to hear it when you open the door unless it is a very old refrig. See if there is any frost or ice on the back wall inside the freezer. If so, you have a problem with the defrost system. If you do not hear the fan running it may have failed.
Posted on Apr 08, 2009
SOURCE: Freezer not working
my WSE6100Wa (westinghouse side by side) is not cooling on both sides
Posted on Jul 28, 2009
SOURCE: westinghouse silhouette frost free 522 fridge is
The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
Posted on Jan 01, 2010
SOURCE: Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Posted on Feb 20, 2010
heatman101
  • 43501 Answers
SOURCE: Westinghouse fridge/freezer (freezer on top) has
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 07, 2010
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
Westinghouse fridge freezer fridge not working
What is the model number?
Do you see any ice buildup on the back wall of the freezer or behind it?
Oct 20, 2012 | Westinghouse Refrigerators
I have got westinghouse fridge. The freezer is working but the fridge does not get cold at all
Is there any sign at all of snow/ice build-up in the freezer section ??
Is the fan in the freezer running ??
Need more info..
Dec 24, 2010 | Westinghouse Refrigerators
I have a Westinghouse frost free fridge with freezer on top.(RJ340M) Freezer part is working great but the fridge is not performing well at all. Thermostat was my first thought but wouldn't that be...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 23, 2010 | Westinghouse Refrigerators
Replacing thermostate in Westinhhouse WSE6100SA fridge freezer.
I would recommend an appliance service company for this type of work!
Feb 19, 2010 | Westinghouse Refrigerators
Westinghouse WSE6100SA fridge in side by side fridge freezer free
the thermostat has broken down and needs to be replaced,, normaly when they brake down they just stay in the closed poshion so the fridge freezes up get a new one fitted and all will be well
Feb 19, 2010 | Refrigerators
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Westinghouse Fridge problem
-Try defrosting the unit. (force defrost)
- Check air vent if air is present.
- Check if the unit is not overloaded with stocks or air vent block with stocks.
- If no air is present in vents then check your blower inside if operating.
Feb 29, 2008 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
