Question about M-Audio BX5a Speaker
M-audio bx5a blue light won't go on speaker is dead?
Could it be a fuse. there was newver a huming noise
5 Suggested Answers
SOURCE: M-Audio BX5a Speaker Problem
Not sure i can help with the led problem but i just fixed a hissing problem with one of my BX5a monitors. It developed a hiss when on (both tweeter and bass) and a very loud thump when switched off. I found a slightly swollen power filter capacitor on the internal board. They are the two biggest black capacitors, labelled as 25v 6800uf. Only one of these was bulging. The tops of these should be totally flat. The indented X on top of the caps make any bulge easy to spot. Worth opening it up and having a quick look. I could only find 35v 6800uf caps at my local electronics store but they did the job ($3 each). I swapped both out and it's now working great. An easy DIY fix, just be sure to always have the power cord unplugged before you put your hands anywhere near the guts of the thing. Hope it helps.
Posted on Dec 06, 2008
SOURCE: No sound from M-audio BX5a monitor
I have a pair of BX5a monitors hooked up to a video editing suite. One of the monitors is off. They are powered to a working electrical supply. They are driven off a Mackie DFX-6 with a 1/4" unbalanced connection. No blue light on the monitor, no sound or hissing on that...
Posted on Mar 08, 2009
SOURCE: bx5a monitor speakers
Check the capacitor, if its swollen or rusty it needs replacing, also check the fuse.
Posted on Jul 29, 2009
esound
  • 425 Answers
SOURCE: I'm a video editor (MAC
Hi, cases like that always comes u. Earlier you said just replaced it, that's not too good for anew monitor speaker.
You could test the fuse inside the speaker if it's still working, might be power fluctuation that might have caused it to blow.but you need to test it. If it is the fuse,fine! you can replace it, it does not cost much to replace.
Also if i can recall,most new stuffs always comes with guarantee with it,right?. I would suggest you could take it back and get a replacement, and i guess if they see it,since it is on guarantee,they can fix it for you without even charging you a penny.
Hope that helped.
Thanks and feel free to pass on your comment.
Thanks for using fixya..
Posted on Jan 12, 2011
Huming noise when I turn my steering wheel
sounds like you are low on power stearing fluid check level
May 07, 2015 | Ford E-Series Van Cars & Trucks
Rear noise
you may a rear end bearings causing the noise. have it checked out at a shop.
Sep 03, 2014 | 2008 Chevrolet Tahoe LTZ
How to replace capacitor on M Audio bx5a speaker
http://mr-ives.blogspot.nl/2011/09/mending-pair-of-m-audio-bx5a-monitors.html
Apr 20, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
My jvc does'nt have sound coming but it humes when turned up
test the power supply, filter, diode, fuse. c.breaker, audio i-f detector, output amp, see the block diagram attached.
God bless you
Oct 11, 2012 | JVC Televison & Video
Active Speaker won't power up
If the speaker is OK, check the audio output components like ICs and transistors.
Jun 05, 2012 | Mackie SRM-450 System
The led light went out not even a year old
it says the quality of your led light is too bad if it wooldn't been fixed well ..you never buy the that led . you should change another .
home light
May 10, 2012 | M-Audio BX5a Speaker
When speeeding up engine makes a huming noise
If it also happens when standing still then pop the hood, rev the engine and listen. Try to get an idea of where the noise is. I'd start my guesses at the exhaust system - depending on exactly what that humming noise sounds like.
Apr 11, 2012 | 2009 Saturn Aura
One of my two year-old BX5a pair started making cracking noise. I am wondering if it's something I can fix myself. I happen to be an amateur radio operator and used to build radios when I was a kid and...
This would be burnt out voice coils. This takes some special tools and material to rebuild them. etech.com or ebay or amazon may have the things you need to rebuild it. It would likely come with instructions as well but there are how stuff works videos and maybe youtube vids as well to watch to see how it's done.
Jan 28, 2011 | M-Audio BX5a Speaker
M-Audio BX5a Speaker Logo
173 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
