Question about Honeywell Programmable Thermostat Heater
How do I override the program on a honeywell T8011R1006 thermostat
I have it programed and I want to override it and reprogram it
  • 518 Answers
SOURCE: program manual for honeywell thermostat model T8700C1005(1)
Without a model number, it's hard to help Ya out, but most manuals are here: http://www.honeywell.com.au/business/acs/acp/ecc/ec/residential/identify.html
Geno
Posted on Jan 23, 2008
hotuna
  • 288 Answers
SOURCE: Honeywell 6300 programable thermostat instalation
The thermostat is a low voltage circuit (24 volts) most of the newer heating systems have a fuse for the low voltage controls. If you are having to re-set the high voltage circuit breaker, then you have something else wrong. When does the breaker trip? while its running or after it shuts off?
Posted on Jan 03, 2008
SOURCE: Honeywell thermostat RTH230B
After several months of calling Honeywell (actually someone in India), I found what seems to be the solution. I think I became such a pest (they had a lot of complains from me in their record) that they put me on hold and called someone at Honeywell Corp. The solution was to "reset the microchip". You do this by holding down the "Mode" button and while holding it down, take the batteries out for a couple of seconds (still holding down the Mode button) and then put the batteries back in and release the Mode button. 10 days have passed and it has been working perfectly. Hope this doesn'f jinx it! Good luck.
Posted on Feb 26, 2008
boanhtgclg
  • 34 Answers
try holding the up and down arrow, down, at the same time, see if the time or temperature starts flashing. also the cover should lift up so you can change from heat to cool, there should be a program button or a set button to hold down. all you should have to do is adjust the time and temperature for the 4 settings during the week and the two on the weekend. should be really easy, let me know if you need some more help
Posted on Nov 13, 2008
  • 252 Answers
SOURCE: how do I program my honeywell basic thermostat?
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Posted on Oct 10, 2009
Google com
'Override' condition is the condition where the thermostat is manually bypassing the scheduled event. It goes into 'override' when you push the 'override' button and goes out of 'override' when you either push 'override' again or the 'run program' button. If it is not a programmable time frame, the typical 'override' length is 2 hours.
Aug 19, 2014 | Honeywell CT87B ROUND HEATING&COOLING...
Can I reprogram my keyless remote from my 1995 eldorado to my 1996 cadillac eldorado
AS programs can be altered I would have it checked out at a dealer service centre as they will need the keys and the vehicle to see if it can be done
Jan 11, 2014 | 1996 Cadillac Eldorado
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
Reprogram harley key fob
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
How To Program New Key Fob For Harley
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Apr 06, 2013 | Harley Davidson Motorcycles
The furnace comes on @ 70* when programmed to be 60* at night
you have to switch it to settings and reprogram it. find your owners manual and it will tell you how to program your thermostat
Dec 01, 2012 | Honeywell Programmable Thermostat Heater
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
Nov 24, 2012 | Hardware & Accessories
Hi there just wondering do u know where i get the code to unlock immboliser
There is no "code" to the key (security) immobilizer system. If the key looses its programming, you need a dealer to re-program the key. Some mechanics have the software to do it also, but not many. Once the immobilizer locks out your key, there is no "do it yourself" fix. Dealer reprogram only.
Sep 28, 2012 | Bypass Essentials pkh34 Immobilizer...
How can i reprogram a remote on a viper 300 ??
There are two possible problems when attempt to program and you never hear the chirp. One is the siren doesn't work and two, the alarm is not detecting the door open. This is commen with some GM vehicles that have the dome light override and the alarm was installed to trigger with the dome lights. Open the door, press the dome light override until the dome lights come on. Proceed with programming.
Jul 28, 2012 | Viper Vehicle Parts & Accessories
What does temporarry and hold mean on thermostat
Sounds like you have a programable thermostat. the temporary setting is when you change the temp setting to a different temp and it will stay at that setting until the next programed change. The hold setting is to hold the temp setting you have chosen for an indefinate time. It overrides your programed settings.
Jul 06, 2012 | Honeywell Programmable Thermostat Heater
The on/off button quit working. I can't manually turn lights on/off. In wall timer ST01AC
Thank you for including timer model number.
You have almond-colored ST01AC timer that worked before and then stopped working.
The manual override no longer turns lights on-and-off.
Manual override works by pushing in timer door, and also by pushing on-off button on face of timer.
1) Try pushing on-off button directly instead of timer door, in case little plastic point on timer door has worn down. If timer door is worn down, maybe add a few layers of tape so door can push button again.
2) If timer on-off button is not working, then timer may be defective -or- timer CR2 battery needs to be replaced, and then timer reset and reprogrammed.
3) Defective timer: timer has 1 year limited warranty against workmanship defect
http://www.intermatic.com/customer%20service.aspx
4) Replace CR2 battery, reset timer, and reprogram timer and see if functionality is restored.
If timer is not restored, then timer is going bad.
Open following link for illustration of battery replacement, steps for resetting timer, and illustrated re-programming steps.
http://waterheatertimer.org/ST01C-program.html#battery
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Heating & Cooling Logo
668 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
