Question about Sony DVP-FX820 DVD Player
How do i unlock this region specific player
I'm unable to play DVD's froma different region. How can I get it to read ll DVD's?
  • amitwadhwa64 Oct 28, 2008
    I tried the solution above and it di not work for me. I have SOny DVP FX 820 portable DVD player that I got in the US and I have lots of region 2 DVDs as I live in Ireland :(
  • byronjunior Nov 25, 2008
    I have the same problem. I would like to know how can I unlock my Sony DVP-FX-820.
    It's not possible with the comments that are in this site. Can you help me???
    Tks, Karina.
Here are the steps in unlocking the regions for your DVD :
1. Switch on the player
2; Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
7. Pop in a DVD and enjoy!
Best Regards,
Dongkitz
Posted on Oct 24, 2008
What is the multi region unlock code
SEE THIS .GOD BLESS YOU
Manufacturers of DVDs and DVD players install codes that only allow us to play DVDs that are manufactured for our region. (For example, the U.S. and Canada are region 1, while China is region 6.) To make your DVD player region-free, you'll need to find the unlock codes that will allow it to play DVDs from all over the world. Below are some steps to help make your DVD player region-free.
Read more: How to Make Your DVD Player Region Free ' eHow.com http://www.ehow.com/how_2036609_dvd-player-region.html#ixzz285JT4y65
Oct 01, 2012 | Teac DV-H500 DVD Player
I need the region code for tedelex ted7s dvd/vhs combo
see this and proceed . God bless you
Oct 01, 2012 | Televison & Video
Cant play a region 1 dvd
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Jul 12, 2011 | Audio Players & Recorders
The DVD player will not play anything. It says invalid region.
Then you have a DVD player that is either not designed to be sold in your region or DVD's that are for a specific region and not for the country you reside in. If you want to be able to play any video buy a multi region DVD player, not a locked to a region one! You may be able to find an unlock code, but oif its an unknown brand you're stuck!
Thanks for using FIXYA
Oct 10, 2009 | TruTech PLV16320 Television
I bought a movie diff region and i have a dvp1013 canregionchange
DVD's are made in different region codes as they are intended to be played on specific types of DVD players. As far as I am aware there is no way to change the region code of a DVD.
However, your DVD player maybe able to bypass the region code through a type of "hack"; you might search online for your specific DVD player.
A DVD drive on your computer may also be able to play the DVD although you may need to further research specific software players. You should be able to find some freeware that would enable you to play your DVD on your computer assuming your drive can read DVD's.
Another option is to buy a region-free (also known as an all-region) DVD player. Although they are a bit more expensive than a regular DVD player, region-free means you never have to worry about software fixes or trying to reconfigure your current DVD player. Online sellers abound the most well known probably including Amazon and YesAsia (a site that specializes to selling Asian merchandise overseas).
Hope this helps, I was a little vague in places.
Basically you can't change the DVD so much as the DVD player.
Jun 26, 2009 | Philips Televison & Video
I have brought some DVDs and my TV DVD player will not play them
You won't be able to do this unless your DVD player specifically says it is a multi-region player. DvVD movies that are encoded in a different region use different encoding methods like PAL instead of NTSC.
Jun 20, 2009 | Panasonic Proline AG-DV2500
Unable to play a DVD movie
Most probably the TV system is not compatible.
This VCR/DVD uses NTSC formate. Is the DVD in PAL formate. Also the Region code can be different. This DVD palys DVD-Disks with regional code 1 or All.
Dec 09, 2008 | GoVideo DVR4300 DVD Player/VCR
Unable to play some DVD's ,screen message says wrong region.Have entered different regions code to no avail.
Hello,i have been reading about your problem....
If the dvd you are trying to play is a fake copy,it will not always play.... , Plus.... when you buy in a different country it also may not work.... this is due to the dvds reagons....
Sep 14, 2008 | Philips Televison & Video
Region Codes
There has to be a DVD CODE HACK for the MAGNAVOX BDP170MW8. Please post the directions. thx.
Oct 25, 2007 | Toshiba DRW2 DVD Recorder
Sony DVP-FX820 DVD Player Logo
1,343 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
