Question about Incredible Technologies Peter Jacobsen's Golden Tee Golf demo
Downloading Golden Tee Golf in windows 7 does not install
Error loading golden tee golf displays #2154...suite 6.3 error displays 70080072..Need help
Tip
How fix cabinet hinges quick and easy.
If you've ever had a kitchen cabinet door hinge fall off or get loose due to a wood screw stripping out. This can be fixed very easily with a golf tee or toothpicks. Just remove stripped screw and expose screw hole. Put golf tee or toothpicks in hole and break off even with surface. Now just replace screw in the original location and the toothpicks or tee will tighten up screw like new.
on Oct 10, 2010 | Home Fencing
Tip
Clever use of a golf tee
in a pinch, .....a golfing tee can act as an excellent shim to stick into a loose spot, a shovel, a hand trowel, a rake, you will have a place for it...
on Apr 29, 2010 | Garden
I can't get the right tv to game connection for plug and play golden tee live
Hi, i dont have this game but I recommend searching up instructions on google. The company who make this game would probably have instructions on their websites. Hope this helps
Dec 24, 2012 | Radica Golden Tee Golf Plug And Play Home...
Picture on golden tee is dark red not normal green did revert to green but back to red
Sounds like a cold solder joint. Unless you have knowledge of electronics and high voltage, I wouldn't try to fix it myself. A honest TV repairman should be able to fix it. And when I mean high voltage, I mean 2000-3000 volts is average with a CRT TV tube.
Dec 17, 2012 | Arcade Golden Tee Unplugged Video Cabinet
I have a 2005 golden tee tournament edition, when i turn it on it powers up but the screen is blank, any suggestions???
First you will need to open your game arcade machine and check the Game Motherboard cables and connections, check all plugs, every connector, reconnect all of them..and try to turn it on again!
After doing this try to check your power supply and see if it is working well..
see if the board look´s like this:
Note that some versions has ide hdd interface.
to help you, i find the service manual with all the instructions in this link
There is a step by step guide to fix your Golden tee!
Good Luck!
Dec 07, 2010 | Arcade Golden Tee Unplugged Video Cabinet
Golden keeps rebooting
Vandre's suggestions are very good.
Some boards are fussy with voltage and need a small adjustment to find the setting they like best.
You can put the board into test mode/menu when you power it on, refer to the manual on how to do this, and see what the current voltage is being supplied to the board.
5.2 volts DC is a good setting for fussy boards. If it still reboots try 5.4volts, maybe 5.6 volts, but recommend going no higher than 5.6.
This will compensate for voltage drop across the board to getvit through the startup cycle.
Hope this helps.
Jan 24, 2010 | Arcade Golden Tee Unplugged Video Cabinet
Error F-05
pulled out filter- golf tee jamming it, now works fine. hotpoint were going to charge me £100 to fix it,as it was something you can't do yourself!!
Oct 24, 2009 | Hotpoint Ariston AW125 Front Load Washer
Video Game Consoles & Games Logo
200 people viewed this question
Top Incredible Technologies Video Game Consoles & Games Experts
James Wishart
Are you an Incredible Technologies Video Game Console and Game Expert? Answer questions, earn points and help others
