Question about Olympus Stylus 410 / ? 410 Digital Camera
No flash camera works fine but flash won't work at all on any setting,the battery is fine,it's probably the lamp,how do you change it.thanks.
  • 4 more comments
  • ajhawkins Nov 25, 2007
    Flash doesn't work on my Stylus 410 either.... Is there any way to fix it, or get parts?
  • Anonymous Nov 29, 2007
    The camera has worked great for over a year but the flash no longer works so it stopped taking photos in the Auto mode and any flash mode. It still works fine in the No Flash mode. i imagine the labor cost to repair exceeds the cost to replace. If it's the bulb, I'd like to buy the bulb attempt to replace it mayself. If others have had the same problem and already found that it's not the bulb then I'll pass it to my kids and get something new. Has anyone identified the cause?
  • jan52 Aug 20, 2008
    My Olympus 410 will also take pictures but the flash has stopped working. Out of guarantee now and very irritating. Looks like a design fault.
    Janet Whaitfield
  • carlosallan Sep 20, 2008
    The flash on my camera has stopped working
  • Anonymous Oct 09, 2008
    FLASH DOES NOT WORK AND LIGHTS AND ARROW FLASH CONTENTLY
  • Anonymous Apr 28, 2009
    My Olympus 410 has the same problem. I'll buy Nikon in the future....
    Problem Solver:
  • 4 Answers
It is a problem that has happened to 2 out of 2 of my Stylus 410's. Olympus will not reapir them unless they are under warrenty (or for $175). I filed with the BBB...we'll see if that helps. They really need to recall them. Good luck. =)
Posted on Mar 21, 2007
SOURCE:
FZ-100 shows number +/- 1-1/3 next to the flash icon in circle, what does that mean, flash is working ok but seams not enough flash power
This probably means the flash power is set to 1/3 of the full flash power.
Go into the camera's Menu and change the flash setting.
OR
If you cannot find how to change this setting, then remove the battery for 15 mins, replace the battery then go to the camera's Menu to set the Date & Time. the camera will be restored to the default settings.
Feb 28, 2013 | Panasonic Lumix DMC-FZ100 Digital Camera
Camera still dead with a new charged battery. Is it possible to overcharge a battery so it won't work?
If you have another battery definitely give it a try, most likely it won't work either. The problem is probably the fuse located on the DC/DC board that has 'blown' causing there to be no power. Replace the board and the camera should work fine. Canon will probably charge $175 or so for the repair.
Hope this helps.
Thomas
Sep 07, 2011 | Canon Rebel XT / EOS 350D Digital Camera
While using it, suddenly the flash didn't work anymore in my S4,everithin else is working, may be there is a problem with flash lamp?
First try with new batteries as power received will be less as the batteries gets older and so flashes might not be working well.
If you still face the same problem even after changing the batteries, then there is a problem with flash lamp.
Hope this helps.
Jan 27, 2010 | Nikon Coolpix S4 Digital Camera
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Mar 08, 2017 | Canon EOS 450D Digital Camera
Flash setting doesn't work
Does your camera gave a small battery in place somewhere that is used to maintain the date and time settings? (it is generally a watch battery type small flat silver disk.) You should not have to reset time and date after each battery change.
Many digital cameras eat up batteries quickly, especially when using the flash alot., that is why it is important to use good quality rechargeables whenever possible.
Jun 19, 2009 | Fuji FinePix 3800 Digital Camera
Shutter button causes camera to turn off
It is usually a battery strength issue. Try this, set the flash to "no flash" mode and try to take a shot. If it works with the flash set to "off", the batteries are probably not strong enough to power up the flash and shoot. If that doesn't work, try really, really GOOD batteries. Most of my customers with this problem solve the issue with Energizer Lithium AA batteries. We sell lots of these batteries, and it usually solves the problem.
Mar 11, 2009 | Fuji FinePix E500 Digital Camera
Flash is acting weird...
The problem with troubleshooting is that you have to try different things to see what changes when you do something different. Try new batteries, then try another set, then connect the flash to another camera and see if you have the same results. In my opinion, I'd have to say that it's probably the flash but like anything else, you have to try different things. Try using a different flash unit to determine if it's a flash issue or a camera hot-shoe issue. Once you find the culprit, then either replace the flash (hopefully this is the issue because it's cheaper) or it may unfortunately be the body. Hope this helps... just try a few things and cancel out what's working vs. what's not working.
Feb 23, 2009 | Canon Speedlite 430EX TTL Flash
Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Oct 08, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
Canon Powershot SD550 flash not working
most likely it could be stuck
you can try prying up the flash a bit not to much.
otherwise its broken, the gears that runs it, could have a broken tooth.
so it wont pop up or go up.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 23, 2008 | Cameras
The flash won't work!
Hold it to your ear and listing for the singing noise the capacitor should make when charging up. If you cant hear this then it is dead Flash units are integral to the main board usually A new camera is the only cure. However try Nikon Technical support before giving up completely
Mar 28, 2007 | Nikon COOLPIX L4 Digital Camera
Olympus Stylus 410 / ? 410 Digital Camera Logo
215 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
