Question about Dell OptiPlex Computers & Internet
DELL XPS400 BLINKING YELLOW POWER LIGHT - OptiPlex Dell Computers & Internet
SOURCE: Yellow blinking power button
A customer of mine has several of these that have the same problem. I found a comment on a Dell forum indicating that one of the capacitors on the mainboard will be either swollen or leaking. Replace the capacitor and it should be OK. I do not have the proper equipment for soldering on a mainboard so I have not done this. However, I did a google search on "Dell SX280 mainboard purchase" and I found a guy on ebay selling the repaired boards for $100.
Posted on Sep 18, 2008
  • 508 Answers
SOURCE: I have Dell GX280,I got the Solid Yellow light on
check connection on computer!!!
Posted on Jun 25, 2009
xtreamtech
  • 40 Answers
SOURCE: Dell Insp 4600C blinking yellow power light
the issue could be woth the power supply unit or internal wirings ..
Posted on Jul 19, 2009
  • 3 Answers
SOURCE: won't turn on only blinking yellow light
Another problem with the Dimension 4700's are some of the capacitors. There are a few that cause problems and prevent the machine from powering on. Check the single large brown capacitor next to the black heatsink. If you see the top bulged or stuff leaking out, there's your problem. The other two that tend to blow are in the bank of capacitors right next to the CPU. Look for the two tallest ones and check for bulged caps or leakage. Replacing them is really not a difficult fix as the Caps are readily available and it isn't hard to solder them in. Alternatively, you can hit an electronics shop and see if there's someone who can charge a nominal fee to replace them.
I've repaired two 4700's with similar problems this way.
Best of luck!
Posted on Aug 29, 2009
ashokpandey
  • 121 Answers
SOURCE: I have a dell dimension desktop. It won't turn
open the tower//
check for any loose connection of the cord of Hard drive and power unit//
better option is take out the wires one-by-one and refix it//
if this does not work then probably the SMPS has gone bad and needs to be replaced..SMPS is the power unit which supplies power to all the component.
during all this process please alwaws make sure that when you put ur hand in the tower then the power cord should be out , otherwise you can get power shock.
Posted on May 15, 2010
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
Yellow light blinking on my Dell Inspiron one 19 and won't start up
if you have replaced the MB and power supply, then the from IO panel could be the failed component
Nov 16, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
When i turn power on my dell gx520 just blinks yellow and nothing else, nothing else at all
If the power button light is blinking yellow . Generally it means the problem is with the power supply and needs to be replaced . If after replacing the power supply the problem is not solved it would be the motherboard failure.
If the power light is blinking amber -
The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
To know more on how to troubleshoot the system visit the following link
Dell support site link
Thank you for using Fixya
Proton
Oct 08, 2010 | Dell OptiPlex GX520 PC Desktop
When I power up my dell optiplex 360 the power light should be green but is staying yellow help
if you light is blinking yellow then you might have two problems
or one , your power supply is defective even though its powering on. that is a dell defect, or *********** board is bad..
my best guess is your power-supply..
Aug 16, 2010 | Dell OptiPlex 360 Desktop Computer
Dell? OptiPlex? SX280 blinking yellow what is that
blinking yellow light on the power button of a Dell system is a possible power supply issue. press the eject button on the dvd drive while the power button flashes yellow light. if the disc trays wont come out, you need to replace the power supply. hope it helps. good day.
Jan 07, 2010 | Dell OptiPlex SX280 PC Desktop
Dell dimension e310 desk top will not power on
If the POWER Button on the TOWER is blinking AMBER (Yellow) then the most likely failure point is the POWER SUPPLY in the Tower.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226001
Dec 21, 2009 | Dell Dimension E310 PC Desktop
Jul 19, 2009 | Dell Dimension 4600C PC Desktop
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Have a yellow amber light blinking
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 25, 2008 | Dell Dimension 8400 power supply ** FREE...
Computers & Internet Logo
37 people viewed this question
Alun Cox
