Question about Cambridge Sound Work Radio 705 Shelf System
Sound Work Radio 705, automatic shut off
Hi,  I know the unit will shut off itself after 30 minutes is desired. But my radio also shut off the speaker after it does not see anybody in front of the unit.  There should not be any sensor to detect the presence of listener or wall near by, but it anyway will shut off.  This happens now every time I get more than 2 meters away from front of the unit. This problem is very strange.  Can you help?
Radio and CD-6 player
The humming sound prior to cutting out could indicate a short in the unit itself.....remove unit and have it tested!
Aug 21, 2015 | 2003 Ford F-150
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
No sound radio honda accord 2004
Either radio is bad, or you have a loose connection to speakers, or poor ground connection at the radio. If a poor ground connection, the radio will intermittently not work also. Since radio continues to work, but sound does not, it is probably a bad audio circuit in the radio itself.
Apr 29, 2012 | 2004 Honda Accord
My 2002 chevy malibu's radio seems to be shorting out, the radio will work fine but randomly the sound shuts off the radio still shows the radio station and even says which artist is playing but there...
I'd suggest using the balance and fade controls to cut out each speaker one by one. to possibly determine if you have shorted speaker or speaker wiring. As far as the turn signal clicking noise, the hazard switch is the actual flasher unit for the turn signals, and could be the culprit, but the most likely cause is the turn signal switch itself. It is usually caused by corrosion across the contacts, which can be cleaned out fairly easily, but more typically, the switch is just replaced
Jun 16, 2011 | 2002 Chevrolet Malibu
Radio working just fine But no sound coming from speakers
if the radio still has power the audio amplifier ic in your radio has failed.
take your radio to an electronics repair shop or, replace the radio; this not something you can fix unless you know how to use an oscilloscope.
Aug 01, 2010 | Harley Davidson 426290 AM/FM Radio
Makes a wining sound but plays no music on any
Hi, check to see if you have any surpressor fitted to the alternator?
Jul 14, 2009 | 1991 Chevrolet Corvette
06 ultra radio no sound from speakers only headset.
Switch is fine. You have a damaged audio circuit caused by vibration. Check the bikes mounting brackets. probably broken. The radio will need to be repaired. www.ironcrossaudio.com
Apr 21, 2009 | Harley Davidson 426290 AM/FM Radio
03 chev silverado radio on but no sound
studying the radio schematics , i'm seeing a radio amp fuse under the hood ,in the main fuse box under hood , 30 amp , check that for starters , if the amp was out you would only lose sound , would like to get a fix ya vote , comment back because i have other thoughts on your schematics , and do you know if its the base model or premium sound , with or without cd ? , thanks .
Jan 11, 2009 | Car Audio & Video
Sound problem
You have a shorted speaker or a speaker with a bad voice coil. This has been confirmed by the fact that the audio amplifier is shutting down (protection) but the unit stays powered on. The speakers will play for a few seconds or maybe even longer at lower volume, but any length or time or an increase in volume will immediateley shut off sound. This is due to the fact that a shorted speaker wire/connection will ground out or short to one another. If you have checked all connections behind the radio AND at the speakers and found no problems, then it is a voice coil on the speaker. A shorted voice coil will work until the speaker cone moves causing the short or until enough power passes through the voice coil's short to turn off the radio.
Solution:
1. You can use a voltmeter set to check continuity to test for a speaker short. Disconnect all speakers from the radio and connect one side of your meter to ground and the other to the speaker lead. An audible "beep" will confirm a short.
2. The other method would be to disconnect all speakers and re-connect them one by one until the radio's sound output shuts off again. This will be your shorted speaker.
I hope this information was helpful.
Apr 07, 2008 | Pioneer DEH-1800 CD Player
Cambridge Sound Work Radio 705 Shelf System Logo
Top Cambridge Audio Players & Recorders Experts
Don Hart
Tom Chichester
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Cambridge Audio Player and Recorder Expert? Answer questions, earn points and help others
