Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Trouble shooting for Brivis L20 - Mastercool 67471 Evaporative Cooler Air Conditioner
When shooting thru glass (like at a zoo or museum) using the Coolpix L20, will the autofocus detect the glass and focus there instead of on the subject? If so, is there a way to avoid or counteract that?
It depends how clean the glass is, whether the display/animal space is brighter than where you are shooting from, and whether there is any light hitting the glass itself and causing glare. Usually you just have to keep attempting to focus until you hit the focus spot you want. Also, some models do have a manual focus setting - see if your camera does and just set the focus to a particular distance when shooting. Hope this helps!
Hiram
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 06, 2011 | Nikon COOLPIX L20 Digital Camera
How do you turn off video and go back to picture mode?
Press the shooting mode button on the top of the camera to display the shooting-mode selection menu. Choose the option to enter easy auto mode and hit the OK button. That should do it.
Apr 19, 2011 | Nikon COOLPIX L20 Digital Camera
How do you change the asa on coolpix camera
As with many point&shoot cameras, the L20 doesn't give you any control over the sensitivity (whether you call it the ASA or the ISO). The camera expects you to point and shoot, while it takes care of the details.
One advantage of more complex (and expensive) cameras is that they allow you to take more control over your photos.
Nov 10, 2010 | Nikon COOLPIX L20 Digital Camera
Hello, I can't turn off the flash on my nikon coolpix L20. Can anyone help me out?
In the shooting mode, press up-arrow on the multiselector (marked with a lightning bolt). Select the no-flash icon (lightning bolt in a circle with a slash through it), then press OK.
Oct 31, 2010 | Nikon COOLPIX L20 Digital Camera
Sir, how to pause nikon coolpix l20 camera during video shooting
You can't. You can stop the current shoot, and then start another one. You'll end up with two video clips, which can then be joined together using video editing software on a computer. Remember that the L20 isn't really a video camera, but a still camera with video features grafted on.
Aug 09, 2010 | Nikon Cameras
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Hi any idea what causes this Brivis error. err
go to the brivis web page and type in serial number and error code theywill give you a code and repair instructions.adrian,,,,
Jun 29, 2010 | Heating & Cooling
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
67 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
