Question about HP Pavilion dv6000z Notebook
I can not turn on the web cam on my HP pavilion dv6000. there is no program it could make it work and i can not even find the cam device in device manager.
    Problem Solver:
  • 3 Answers
Hit the start button and go to all programs scroll down and check to see if its in the communicaation and chat folder. thats where my webcam is located on my Hp g7-1075dx notebook comp. called CyberLink YouCam on my HP
Posted on Feb 12, 2012
hotkanni
  • 13 Answers
SOURCE: HP Pavilion Web Cam Code 10
Code 10 error is nothing but issue with the Drivers.  To resolve this issue, download and install the webcam drivers from the below link.
Install the Webcam drivers from the link given below
ftp://ftp.hp.com/pub/softpaq/sp34501-35000/sp34746.exe
This will resolve the issue.
All the best
Posted on Sep 14, 2008
SOURCE: HP Pavilion dv6000 Webcam problem
Download Quick play if you can i havent tride this before so i dont know if it will work hope this helps. =]
Posted on Sep 17, 2008
ctf1800
  • 4402 Answers
SOURCE: Web cam(Yu cam) problem in HP Pavilion dv6000 notebook pc
go to web cam manufactures page and look for upgrade software and drivers.
Posted on Nov 17, 2008
SOURCE: driver ricoh webcam HP pavilion DV6000
I had the same problem of code 10. I am using an HP pavilion dv6000 with a ricoh webcam. I found that I download a microsoft updates on the 8th of febuary which included some sonix drivers which were optional and no good to me but stoped my webcam working.
By going into 'control panal' and selecting 'system' then 'devise manager' you get a list of your system. If you then select the 'universal serial bus controlers' at the bottom you will see the sonix driver. By rolling back this installed driver I found my webcam started working again.
This solved my problem and I cant believe there aren't a lot of people out there with the same problem. Good old microsoft!
Posted on Feb 22, 2009
joecoolvette
  • 5660 Answers
SOURCE: hp pavilion dv6000
The only internal power for a laptop is the battery. The external power is the AC adapter. (Charger)
If you're asking for the schematics, for the circuitry and component layout of the motherboard, to my knowledge only HP trained authorized technicians, have access to this. In truth, if they have a problem, they just replace the entire motherboard. It's more cost and time effective.
Which leads me to this. The main issue of power problems for a laptop, is the DC Power Jack, right after a failing battery. This is the round port on a laptop, where the AC adapter plugs in. Although replacement of this jack, is no 'Walk in the park', it isn't that tough. However, there aren't that many of we tech's around, who do this anymore. There are just a bunch of 'Parts Changers' out there. Still, from a laptop manufacturers point of view, it may be more time and cost effective, to just replace the motherboard. Less chance of that laptop coming back for the same issue.
I state, that the DC Power Jack is the main source for laptop power failure, right after a failing laptop battery because, the jack receives a lot of accidental abuse. When the AC adapter is plugged in, and the plug of the adapter receives a heavy 'bump', the DC Power Jack can break, or it's solder connections can break, very easily.
This is an enlarged photo of an average DC Power Jack, http://us.st12.yimg.com/us.st.yimg.com/I/yhst-42877593004970_2046_1476209 You can see the 'body' of the jack, is not much larger than the plug that goes into it. The body is also made of plastic.
The thick pin in the center is the Positive connection. The outer metal shell inside, is the Negative connection.
Sometimes the plastic body can break. Sometimes the connection at the end of the center pin, can break. Sometimes the cylindrical metal outer shell, inside the body of the jack, can break.
There is also another issue. In the photo the DC Power Jack is upside down, in relation to how it sits on the motherboard. The flat metal pins that are sticking up, go down through holes in the motherboard, and are soldered to the motherboard, on the backside.
(The flat metal pin in the middle sticking up, goes to the center pin in the jack. One of the flat metal pins on the sides, goes to the metal shell inside the jack. The third flat metal pin on the side, is just soldered to the motherboard, and helps to give strength to hold the jack in place)
Sometimes these solder joints for those pins can be broken. They develop a crack in the solder joint.
In a case like this, just re-soldering the solder joint/s, puts the laptop back in business.
I posted all of this, in case this is the issue you are having.
The following is a link to a Maintenance and Service Guide, for the HP Pavilion dv6000. Don't let the name 'Guide' fool you. This is really an extensive Service Manual.
It tells you, and shows you how to disassemble the entire laptop down to just the bare motherboard in your hand. Also tells you and shows you how to remove and replace all the hardware components inside. It also has all the part numbers. It also has exploded illustrations of the entire laptop.
This is HP.com/Support>Manuals, and the page to download the manual I stated above,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1842155&
Just go down to the blue ->
HP Pavilion dv6000 Notebook PC Maintenance and Service Guide <- , and click on it.
This is a PDF file you download. You have Adobe Reader on your computer. Adobe Reader uses PDF files.
After you copy and paste the link above into your address bar, press the Enter key.
For as much as 30 seconds, you may not see anything happening. The file is downloading, I assure you. The first page may pop-up after ten seconds. IF So, you should see a green Adobe download
bar below to the right. It will show the progress of the download. I suggest you let the file fully download, before you look through it. If you start looking through it before it is fully downloaded, you could break the download connection.
After it has fully downloaded, you can save it to your computer if you wish. This way you can have it to look at, anytime you want. You can also burn it to CD disk.
Just go up to the top headings, and click on the floppy disk icon. It is the second icon from the left.
Hovering your mouse cursor over it will briefly reveal, "Click to save this file to your computer or another location"
(IF you take the laptop apart, remove the battery and the AC adapter first. Also so I suggest using an ESD wrist strap. They are cheap, and help to insure that you relieve your body of Static electricity)
Posted on Apr 14, 2009
I have a HP Pavilion dv6000 and the webcam does not work , i also tried everything still i couldn't use my web cam
did you try update correct drivers and reboot system?drivers is here -
http://www.hp.com/united-states/products/dv6000.html
Nov 15, 2012 | HP Pavilion dv6000z Notebook
I could not find my web cam in the computer pavilion ho dv6000 with vista sp , In the ddevice manager, there is not a image device
I have a dv6000 labtop. You should have an icon in your desktop that says "HP Webcam". If not, search for the program (click on windows sign, then go to "Find").
Apr 29, 2010 | HP Pavilion dv6452se PC Notebook
Web cam short cut
double click on my computer - it will show the webcam - right click on the webcam icon and select send to desktop - create a short cut.
Jul 23, 2009 | HP Pavilion dv6000z Notebook
Y hp pavilion dv6000 webcam is not work mhay dont
ok ..I dont know exactly the problem that you have ...but I am link-ing you to the site where you will find all drivers for your model ...
so ..if you are running windows vista ....just go to control panel and uninstall the driver from remove programs ....
then you either install the new driver ...and after that run the wizard from add new hardware ...or it will prompt you for a driver after you uninstall the old one ...I dont know if its a build in or not web cam ...anyway the procedure is the same ...you will be also be prompt for restart
pav dv6000 drivers
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Web cam
Start, settings,control manager, see if you see a camera in your control manager or device manager under System, hardware
Dec 25, 2008 | HP Pavilion dv6000z Notebook
Cant turn my built in webcam on??
This is known Webcam issue in DV6000 notebooks. To resolve or narrow down the issue, we have to check few things.
First open Device Manager.
Please follow these steps to open Device Manager:
1. Right Click on 'My Computer' icon on Desktop and choose Properties.
2. The System properties Window opens.
3. Click Hardware tab and then click the Device Manager button.
Expand + Imagining Devices and check if the HP Webcam is listed under it.
If Webcam is not listed there, then you have to contact HP to get the BIOS update.
If it is listed there, right click on it and select Disable. Again right click on it and select Enable.
Now open any applications like Quickplay and check if Webcam is working or not.
Please reply me if that won't resolve the issue, I can provide more work arounds
Aug 09, 2008 | HP Pavilion dv6000z Notebook
Wecam 1.3mp builtin for hp pavillion dv6000 found not working the day i bought the machine
Hi I have Hp pavillion dv6000. When am using yahoo msnger or msn ..the web cam not working. There is one message coming Your web cam is not connected. Please give me a solution for this....
Thanks
Simon
Jul 15, 2008 | Computers & Internet
How to turn on webcam
There should be an icon on your desktop for the webcam, if not try checking in your device manager to see if it is enabled..go to control panel>system>hardware>device manager It should be under the imaging devices.
Apr 07, 2008 | HP Pavilion dv6000z Notebook
Feb 10, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
