Question about RCA HD52W59 HDTV Projection Television
Rca projection television has a slight caving
Television has a slight caving on the middle and colors are distorted on both ends. I have checked the three convergence fuses that are located next to the power transformer all checked out fine, and also resolder the points on the power transformer. I do not know where else to check for the problem if someone could give me some feedback I will really appreciate it.
Revove torx screws
Posted on Feb 15, 2012
  • 1 more comment
  • M Wiskin Feb 15, 2012
    Just watched a vid on Youtube with this exact fix, mine had same issue and i got a repair guy to fix it years back. Today i just saw flux on the bottom of board under the flyback connectors and on one fuse. I found its best to kind of slide the whole plastic piece that holds the boards and then lift it up at the back so u can see under it and test the fuses and inspect the joints. Mine are fine this time, but the flyback smokes :( http://www.youtube.com/watch?v=S6Wa8FvSz...
    i did notice that there was flux on another way smaller point or tow near the tranformer, see if that looks cracked, maybe there is a crack somewhere else too.
    point or two, not tow.
Slinteriors
  • 8617 Answers
SOURCE: RCA P52937 52 in. Rear Projection Television
remove the speaker grille. then there should be a few screws running along the bottom of the screen frame. after removing those screws slide the entire fram up to release the hooks that hold the screen frame to the cabinet. Be careful and unhook the wire clip from the front control panel once the screen frame is loose before you stretch the wires.
Posted on Apr 13, 2008
  • 2920 Answers
SOURCE: 52" projection television
indicates a weak power supply
Posted on Aug 25, 2008
  • 2920 Answers
SOURCE: rca projection television
indicates bad power supply
  • 1030 Answers
SOURCE: 52 in RCA rear projection television
Not haveing the convergence option on this set is a clear indication you have the fl231 fuse problem. this is a simple repair and i see it all the time at the shop. I would suggest you read the "fl231 fuse problem in the tips and tricks section of this website. others have repaired this for less than 10 dollars and about an hour. if you have any trouble be sure to let me know
Posted on Jun 04, 2009
ladywinn
  • 5138 Answers
SOURCE: rca television model #D52w27d does not show
You have a Blowed fuse on deflection board It will be bottom left hand side board it has FBT flyback Transfomer on it and Right hand side of the FBT is 3 Fuses in a Roll they are small brown looking caps But they are fuses .06amp fuse it will be the one in the Middle FL231.
Posted on Jan 10, 2010
My Tv's picture looks like its caving in. whats needs fixed or replaced?? and whats the cost??
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 23, 2011 | RCA P52926 52" Rear Projection Television
I have a RCA Hd52w59 television that has a blurry red green blue colors on screen and the pics looked like they are caved in .any help ?
RED BLUE and Green are the component colors. If you are using component cables, which most likely you are, check to see if the Green has come unplugged. Try switching the cabls to a different input. Actually, if you get the same problem on another input that say....your DVD player is hooked to, you have a bad tv. If not, try to isolate it to the simplest thing first e.g. cables, input source, etc. Please don't forget to rate this solution for me.
Jan 21, 2011 | RCA HD52W59 HDTV Projection Television
Picture/color distorted
If the picture appears as 3D thats a simple and inexspensive repair. You can get the repair kit for your RCA Called "The ITC222 and ITC222A convergence option missing repair Kit" from www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions.
Dec 25, 2009 | RCA D52W19 52" Rear Projection Television
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
50 in rca tv
Either color wheel or ballast is faulty.
Oct 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Distorted picture
i was just working on a set with the same problem .. i found a east west correction curicit with a falty transistor. something in that cuircit has failed.
Jan 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted picture
The RCA P52960 uses the PTK195 series chassis. There are 2 main boards at the bottom of the set and above the board on the right (when viewed from behind) is the convergence power supply board. This board usually has a big black IC on it, labeled STK730-010 and bolted to a metal heat sink. Chances are, that IC has burned out and stopped working. Replacing that IC should restore your convergence. If you do not have experience replacing IC's in projection sets, allow a qualified tech to handle it for you.
Aug 29, 2007 | RCA P52960 52" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
