Question about Casio Baby-G BG370S-4V Wrist Watch
Why does my watch beep everyday at 12 pm.
My watch use to never do this and now eveyday it beeps at exactly the same time how do i change that ?
4 Suggested Answers
  • 2501 Answers
SOURCE: the watch has an alarm that goes off at 10:17 pm,
Go to the casio web site "www.casio.com/support"
select "manuals"
Select "watches"
Select "watch manuals archives"
Enter details of you watch and download instructions.
Posted on Jan 06, 2010
  • 319 Answers
SOURCE: hourly alarm/beep
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Posted on Mar 11, 2008
freetek
  • 5568 Answers
SOURCE: hands won't sync up
It sounds like the time zone may be incorrect; check your manual to see if this can be the case. Also, these devices may wait until some time between midnight and 3 AM to synchronize with the 'atomic' standard. Make sure you have the watch near a window as this may aid reception depending on where you live.
Posted on Mar 14, 2010
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
Does the Timex Men's T77862 Expedition Digital Compass Watch allow for military time usage? ie-24 hours, instead of 12 hours
Here is a link to the Timex support page with the download links for all the different instruction manuals:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
And here is the direct link to the manual for the Expedition Digital Compass model:
http://assets.timex.com/user_guides/W215_M179/W215_M179_NA_EN.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 1 of the manual for instructions which basically read as follows:
1. In TIME mode, press and hold SET/RECALL. Time zone will flash.
2. To set, push + or - to select first or second time zone.
3. Press NEXT. Hour digits flash.
4. Press + or - to change hour including AM/PM. (Scroll through 12 hours to get to AM/PM).
5. Press NEXT. Minute digits flash.
6. Press + or - to change minutes.
7. Press NEXT. Second digits flash.
8. Press + or - to set seconds to zero.
9. Press NEXT. Day of week flashes.
10. Press + to - to change day.
11. Continue pattern to set month, day of month, 12-hour or 24-hour time display, MM.DD or
DD.MM date format, turn hourly CHIME on/off, turn BEEP on/off. If you select BEEP on, a
beep will sound every time you push a button (except INDIGLO).
12. Press DONE to confirm and exit or NEXT to continue and set second time zone, if desired.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 25, 2011 | Timex T77862 Watch
No problem I just forget how to change my ironman 30 lap timex watch time from 12hr to 24hr! Please help :-)
And here is the direct link to the manual for the Ironman 30 Lap model:
http://assets.timex.com/user_guides/W89_M877/W89_M877_NA_EN.pdf
Thank you very much and good luck.
Joe.
May 23, 2011 | Timex Watches
Showing 6ae on my Tissot T touch. Also cannot synch properly
Press the center button marked "T". The watch should beep once;- Touch the center of the touch-sensitive face until 24H Cm appears in the digital LCD display;
- Press and hold the center button marked "T" for approx. 5 seconds. The watch will beep once and then again a second time, after 5 seconds have passed. The digital LCD display should now read SYNCHRO;
- Press the upper button marked "+" to move the minute hand until it is positioned exactly at 12:00;
- Press the lower button marked "-" to move the hour hand until it is also positioned exactly at 12:00;
- When both hands are aligned together and pointing directly at 12:00, press the center button marked "T" to save your settings.
- Your watch is now synchronized, so no expensive repair work is required!
Jan 24, 2011 | Tissot T-Touch T33759851
Need to sync digital and analog screens?
There are instructions on here and in the tissot website. However in basic layman terms here goes...
Press central button and hold for 5 seconds til 2nd beep heard. press centre of glass to show 24hr CM display. Sync will appear in LCD window.Then press top button (mins hand) until hand at 12 exactly. Then press bottom button( hrs) and again hold til at 12 exactly then press centre button. This hould fix sync.
My problem is that I changed my 4 year old battery today and at first heard a beep, removed battery as fiddley closure of base and redid battery. Now I have nothing at all. Could i have possibly shorted out the watch and what do I do now?
StevieG
Dec 27, 2010 | Tissot T-Touch T33759851
I have casio Edifice E-546. The date changes at 12pm instead of 12am everyday. Can someone help/
mcdevito75 here, Many Casio Watch Models out there, I'll bet however your Casio is displaying say 1 AM rather than 1 PM as it should if the time is indeed PM after 12 noon, if so, this is why the date is changeing at 12 PM rather than, 12 AM simply re-set your casio and make sure the time of day is set at PM for time after 12 noon and AM for time anywhere before 12 NOON. Also, as you set your Casio, look for anything that may give the hint of Military time, this may be revilled as 12 hours or 24 hours, if you have anything like this, make sure it's set for 24 hours. If you have additional problems, visit a small watch repair shop in your area. Again there are many, many Casio models out there and without your watch with me it's difficult to be more accurate.
Jul 25, 2010 | Casio Edifice EFA110D-1AV Wrist Watch
Hands won't sync up
Mar 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Tissot t-touch analog time is out of sync with digital time. How do I res-sync them?
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
Jun 04, 2009 | Tissot T-Touch T33759851
Watch is Beeping loudly on every hour!
While pushing and holding the RESET button in, press the START button to toggle between CHIME ON/OFF.
Mar 13, 2009 | Bulova Men's Watch
Date changes wrong time
thats because analog watches don't know the difference between AM/PM. First reset the time, moving the hour and minute hands another 12 hours will let you know exactly what mode its in (am/pm) first allowing you to set the date correctly.
Nov 12, 2007 | Watches
Casio Baby-G BG370S-4V Wrist Watch Logo
48 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
