Question about DeLonghi ESAM Coffee Makers & Espresso Machines
General alarm delonghi perfecta
Can not clear general alarm. Brand new machine not a single cup of coffee made -bought a floor model EASM 5500 Perfecta and the store clerk packaged it up and put water spout in infuser so it got caught when the machine cycled. I have removed the back of the machine - with it UNPLUGGED-I moved the motor so as to cycle infuser to allow the stuck water spout to be removed; however, as far as I can determine the system seems no to cycle to allow a resetting of the gears to a known position. A schematic would help - I did jumper the one micro switch that is on the worm gear thinking at least I could get the motor to turn - but no luck - the General Alarm comes on before any motion, etc. Can anyone tell me how to reset the mechanical 'home' or a link to a schematic with function block diagram ?
SOURCE: Magnifica gives Generic Alarm Message - Infuser stuck
My infuser was stuck in the down position, When I called customer support the told me some easy steps to fix this problem..try calling them
Posted on Mar 12, 2009
EwingElect
  • 276 Answers
SOURCE: I desperately require an User Manual for a
try http://www.delonghi.com.au/support/instruction_manuals.asp?group=&mst=contain&ms=esam5500&dst=&ds=
Posted on May 26, 2010
SOURCE: insert infuser assembly alarm on De longhi coffeemachine
Did you try tightening the 2 hex screws behind the infuser?
Be gentle though. Mine felt tightend but thenIput just a bit more pessue on them and got an eigth to a quarter more turn out of them. Found this solution on this site
Posted on Sep 07, 2010
  • 4 Answers
SOURCE: DeLonghi Perfecta ESAM5500 when trying to make a
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Posted on Feb 08, 2011
  • 102366 Answers
SOURCE: How do I descale my Delonghi Perfecta? Can't
You can download the manual from the manufacturer's web site at
http://www.delonghiusa.com/downloadpdf.php?nid=69
Descaling instructions are on page 12.
Posted on Jun 13, 2011
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi Perfecta milk frother not heating.
My friend your problem is that the frother heat is foulty
Mar 18, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
General warning coming up in heating cycle.Not working at all.
For DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Team De-Brewerz.com says:
1. General Alarms should be taken care by authorised delonghi technician only. Please do not try to fix yourself as it is related to safety.
2. This error occures due to loose wirings, opened water circuit, failure of heating elements and last failure of PC board repalcement.
3. Please contact your nearest Delonghi authorised dealer for technical support.
4. You can claim the warranty if recently purchased through De-Brewerz.com . If you are in India then contact us at de.brewerz@gmail.com
Nov 03, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
The door to my DeLonghi espresso maker (Perfecta) keeps opening
I hope you have solved this problem by now... The door not closing properly happens when coffee grounds build up in the middle of the machine. It tends not to get everything into the waist box. You need a chopstick to fish out the grounds from behind/under the central column of the machine. You'll find a lot of coffee packed in! Then the door will close.
Sep 16, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Locating manual as coffee machine is unable to select appropriate grounding for coffee
There seem to be a number of different sub-models of the ESAM5500 line of superautomatic coffee makers.
You can see a list of all of the user manuals for these sub-models here:
http://web1.dlservice.org/dlservice/ext/delonghi/cercalibretti.php?cerca=ESAM5500&submit=Search
Good Luck!
Dec 28, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Coffee Makers & Espresso Machines Logo
1,775 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
