Question about LG Computers & Internet
How to get off power save mode - LG Computers & Internet
    Genius:
  • 1,212 Answers
If monitor is not coming out of standby, replace the electrolytic capacitors on the power supply board. If that does not remedy it, test and replace the transistors as needed in the inverter section the CCFL back panel illumination plugs into. You may need to remmove them from the circuit to accurately test them.
Posted on Feb 12, 2012
How do I disable power save mode
Press the Power key > Activate power saving. To deactivate power saving mode, press the Power key > Deactivate power saving.
When activated, the power saving mode turns off some functions automatically. Radio configuration in power saving mode include the cellular radio (it is set to 2G/GSM only mode), the Bluetooth radio (it is turned off) and the Wi-Fi/WLAN radio (scanning for new networks in turned off but existing networks keep functioning). The power saving mode also reduces display power consumption by minimizingscreen brightness and by turning off touch screen feedback and theme effects. In addition the vibra alerts are turned off in a power saving mode. Hope that helps Anomy.
Mar 16, 2015 | Nokia N8
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Squelch won't turn off, won't go into power save mode
Power-save mode means the radio is being turned on and off repeatedly, to save power. The radio turns on, & if it hears any signals (i.e., if squelch circuit determines a station is being received), it turns on the speaker; else it turns off again to save power. So, squelch and power-save modes work hand-in-hand, and your problem is squelch circuit is either set too low, or a station is being received by the receiver. Download/look at the owner's manual and adjust the squelch circuit for a higher setting, and it should go into power-save mode again.
Good luck.
Nov 10, 2013 | Cobra LI 7020 WX-EVP Two Way Radio
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
Oct 12, 2012 | Computers & Internet
LAMP KEEP BLOWING OUT. TOSHIBA 65 HM167
I had this same problem with my Mitsubishi it is when you have fast on mode set it pre warms the bulb to much. I turneed it off and now the bulb has lasted much longer Setting the Power-On Mode feature You can select either Power-Saving or Fast mode. If you select Power-Saving mode and you turn off the TV, it can take several seconds for the picture to appear when you turn on the TV again. Power-Saving mode saves more power than Fast mode. See "Specifications" on page 66 for details. If you select Fast mode and the TV is turned off, the TV will stay in Standby mode for several minutes (see Note below). If the TV is turned on from Standby mode, the full picture appears immediately. To set the Power-On Mode feature: 1 Press Y and open the Setup menu. 2 Highlight Power-On Mode and press c. 3 Press b or B to select either Fast or Power-Saving and press T. Note: If Power-On Mode is set to Fast and you turn off the TV, the following will occur for a few minutes: • The screen (lamp) lights dimly; and • The fans continue to run. This is a function of the Power-On Fast Shutdown mode and is not a TV malfunction. If you do not prefer this, set the PowerOn Mode feature to Power-Saving. When the Power-On Mode feature is set to Power-Saving, if you repeatedly turn the TV on and off in a short period of time, the useful service life of the lamp may be shorter than the average useful service life (- page 63).
this is from your manual not my Mitsubishi please rate this answer if you felt it was useful.
Feb 03, 2011 | Toshiba Televison & Video
Analog power saving mode?...
I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
May 13, 2009 | LG 22" FLATRON LCD Monitor
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Power saving mode
go to comtrol panel and change the settings in the power saving control options... everything wi be fixed without any big problem
Feb 20, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Computers & Internet Logo
55 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
