Question about Kenmore Dishwashers
665.1302 Hold 3 sec lights up and flashes 3 times
5 Suggested Answers
  • 326 Answers
SOURCE: Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Posted on Jan 31, 2009
SOURCE: clean light flashes 7 times then repeats
Bonjour,
ma machine à laver la vaisselle., Maytag, le modèle S-MDB9600AWS PLASTIQUE éclaté sur les deux roues tiroirs connectés navires. Où puis-je acheter ces roues et ce que nombre d'entre elles ont?
Merci,
Posted on Aug 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite dishwasher model 665 clean light
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@##%^
Posted on Sep 30, 2010
snakehead
  • 1074 Answers
SOURCE: When u turn the power
its a problem in the power supply circuit check T602 and R672 they can be faulty god luck.
Posted on Sep 25, 2011
Blue light flashing
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
Apr 16, 2014 | Belkin Computers & Internet
Red light flashes 3 times
hold in on the power button for 10 sec make sure you put the cover on it good first if that dont work unplug it for a few sec then try to hold the power button down for 5- 10 sec that should work
Jan 06, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
Mc70
hold down the 1 and 9 key down. hold the power button down for 3 sec and relelease all 3 at the same time. the light on top will flash and the scanner should boot up in about 5 sec.
if you need please give me a call or send me an e-mail
Kim Ganoe
kganoe@datexcorp.com
Feb 04, 2010 | Symbol MC70
How to program in the 3 pre sets for garage door openers We have a 2001 dodge grand caravan es
Hope this a Homelink. Put new batt in garage door remote. Park outside garage. #(1) Press & hold 2 outer buttons on Homelink. Release ONLY after light starts to flash. Don't hold for longer than 30 sec. Don't repeat to program the other 2. #(2) Hold the remote 3 inches from Homelink. #(3) Press & hold the Homelink buttom & the remote button at the same time. #(4)The Homelink will begin to flash slowly then rapidly. After the Homelink flashes rapidly release the buttoms. #(5) Press the just trained Homelink button if the light stays on constantly, programming is complete..... To program the other 2 links DO NOT REPEAT #1
Jan 10, 2010 | 2001 Dodge Grand Caravan
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
How do you shut the oil light off
check the fuse box on the driver's side of the dash, there should be a red button in there labeled reset. press & release the button, light flashes then press & hold for 5 secs. if no button turn key to on but do not start engine & press gas pedal to floor 3 times light should flash & go out
Jul 10, 2009 | 2002 Pontiac Grand Am
Reset power
To do partial Reset.
1.Unplug the power cable and turn off the the unit.
2. Press and hold # & 3 at the same time with out connecting the power cable.
3.While holding the button,connect the power cable and do not the release button for 5 sec.
4.Then turn ON the unit.
To do Semi full Reset.
2. Press and hold # & 6 at the same time with out connecting the power cable.
To do full Reset.
2. Press and hold # & 9 at the same time with out connecting the power cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 30, 2009 | HP Officejet 6310 All-In-One InkJet...
Trying to pair BT150 but it won't go into pairing mode
I had the same problem. The many instructions available don't have quite the right details. This worked for me:
1. Turn off the BT150 by holding down the answer button about 5 sec. until the blue light goes off and is not flashing.
2. Turn on the BT150 by holding down the answer button about 5 sec. until the blue light flashes.
3. Keep holding the answer button, and press and hold the volume + button for another 5 sec. until the blue light comes on solid.
Nov 12, 2008 | Jabra BT150 Wireless Headset
Dishwashers Logo
61 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
