Question about Maytag Kitchen Ranges
Range stopped working, Maytag model MER5765RCW
Model MER5765RCW stopped working while I was cooking. Is there a fuse that needs to be replace? House breakers are not tripped.
3 Suggested Answers
the dr
  • 447 Answers
SOURCE: Range element does not work
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
SOURCE: oven controls all work but off buton not working.
This is the Membrane switch which is faulty. I had mine replaced once already. These units cannot be repaired, they need to be replaced. Apprently it is very common and you should report this to your local ESA (Electrical saftey authority) this is a very dangerous problem. The ESA can have this item recalled if enough people lodge a complaint. The round Stove top knobs on these Ranges also have a tendency to switch on when bumped, very dangerous too.
Posted on Oct 19, 2009
The burners on my Maytag electric stove work intermittently. Advanced cooking system Super capacity model.
If intermittenly you mean they quit glowing at times is how mine work also and wife does not say they don't cook alright but they do turn off and on as heat requirement changes
Jan 11, 2015 | Maytag Gemini 30" Self-Cleaning...
Maytag oven blowing hot air from bottom vent heating house
Wanted to know if you found the answer. I have the same problem.
Aug 31, 2012 | Maytag Ovens
Had a storm the range works but the oven went out model number 8114P732-60 Maytag advance cooking system super cap. is there a reset button
There isn't a reset per say but you can turn the unit off at the breaker box for the home for 1 to three minutes. If this does not work...either the heating elements were blown during the power outage or the control board is now fried from the surge and needs replaced.
Sep 01, 2011 | Maytag MER5775Q Electric Kitchen Range
Nothing heats up on my maytag glasstop but the digital display
an electric range needs 220 volts for top burners and oven to work,if getting only 110 volt the display or clock will work.the most common problem i've found with your curcumstances is a burn't wire where the cord attaches to the range or if hard wired still the same place.pull out your range and inspect all wiring where range connects to house and where house connects to range.if ok take a volt meter and meaurse voltage there at cord area .if not 220 volt reading problem will be with the house.if yes 220 volts will need to trace out the range .then the problem at a place the cook top burners and the oven have in common,wire path wise.
Jan 22, 2009 | Maytag MER5775Q Electric Kitchen Range
Instruction Manual
I NEED A MANUAL FOR MAYTAG SERIAL NUMBER MER5752BAB
Jan 03, 2009 | Maytag MER5775Q Electric Kitchen Range
I have a Maytag Model MMV5207BAB over the range microwave oven that crapped out after 11 mos use. No warning, just no power. The outlet is fine I have no power surge problems in my house. This is the...
There is an internal fuse which is located underneath the side\top shell. If you have no lights or control panel, this is the most likely cause. This is not difficult to replace.
Nov 08, 2008 | Maytag Microwave Ovens
EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Kitchen Ranges
Kitchen Ranges Logo
89 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
