Question about Bissell Vacuums
Bisell proheat steam cleaner Metal sprocket feel off pump and will not go back on. Do I have to buy a new pump system?
reddevil6
  • 1673 Answers
SOURCE: Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Posted on Jan 22, 2008
SOURCE: Bissell Proheat water pump
absolutly
Posted on Jun 22, 2008
  • 3 Answers
SOURCE: Where can I get a hard copy of manual for Bisell 7920 ProHeatr
Hi Kim 9682!
Your model is included in the PDF you can get at the following link. Hope it helps! The 1st page looks empty, but just scroll down a tad. Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on Dec 01, 2008
SOURCE: schematic parts diagram for bissell proheat 9200 carpet cleaner
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
hopes this helps, they also have parts, but shop around.
Posted on Jan 08, 2009
  • 29 Answers
SOURCE: I used my new proheat 2x steam cleaner the first
You may have mislaid a piece when you took your Bissell apart to clean it after using it the first time.
I experimented with mine to try and reproduce your issue. On the bottom of the water tank, there are two pieces that can be removed from it. One of them looks like a black plug at one end, with a red rubber flange piece on the other end. If you push your finger inside the red rubber piece, you can feel a spring move up and down. This is the first piece you place on the bottom of the water tank. I suspect you have this piece, because if you didn't, water would gush out of the water tank as soon as you turned it over after filling it.
The other piece, which is the one I think you may have have mislaid, is a larger black, plastic ring with screw threads. This piece goes over the top of the first plug piece, screws onto the water tank, and holds the plug in place. The words "RECLOSE TIGHTLY" appear on mine. If this piece is missing, the water tank does not sit flat on the base of the Bissell, but kind of flops around, out-of-place, and the unit will not dispense water properly, though it may leak it.
If ithat piece is gone, it should be possible to reorder it. Start here:
http://www.bissell.com/Customer_Service.aspx
If that's not the problem, if you have all the water tank pieces, I wonder if perhaps you unscrewed one black screw to remove the clear front plastic piece from the base of the unit-- the piece through which water is drawn up off the carpet-- to clean it, and didn't get it back into place properly. Make sure the two hooks at the bottom of this piece are inserted, one per side, into the clear plastic side pieces at the bottom. If the hooks are not secured properly, before trying to reinsert them, unscrew the black plastic screw so you don't break the tab. It's easy to miss getting these one of those hooks back in right, but it's important to do that before trying to screw the clear front plastic piece into place.
Posted on Jun 12, 2009
Bisell carpet cleaner lost pump prime
Hi Jay! Sorry to hear your machine has lost prime.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
Feb 19, 2013 | Bissell 1699 ProHeat Clear View Upright...
Installation of pump for bissell steam cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101 //,.
May 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I bought a Bisell Pro-heat carpet shampooer and had the belt break after one use. Tried to buy replacement belts only to discover that store out of stock. Question: Is there such a thing as a "generic" or...
No unfortunately not. Some brands of vacuums and steam cleaners have similar belts that can be used on several different models, however this Bissell carpet cleaner has a very unique belt, that is really unlike any other belt on the market today.
I'm sorry to hear that your local store was out of stock on these. We do however have these belts in stock ready to ship today if you haven't already found them. We do offer free shipping & no tax (except VA). Here's a link to the brush belt for your Bissell:
http://www.govacuum.com/bissell-proheat-steam-cleaner-replacement-belt-part-0150621.html
Please feel free to add a comment if you'd like help installing the belt, I'd be more then happy to walk you through this.
If you found this helpful, it would be greatly appreciated if you rated the repair helpful, or left feedback.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Bisell Proheat will not dispense water to the floor but it will dispense through the hand held tool.
check the little nozzle that the water sprays from and see if they are plugged if not your element chamber may need to be cleaned
Mar 02, 2010 | Bissell 1699 ProHeat Clear View Upright...
I need new adapters to hook bissell steam cleaner 1631 to the faucet...where can I find them?
bissell steam cleaner 1655. I need the faucet adapters to this steam cleaner. Where can I buy them?
Oct 24, 2009 | Bissell 1631 PowerSteamer ProHeat Canister...
Soap will not dispense from Bisell Pro Heat carpet cleaners
This is a design flaw. The pump design has a problem with staying primed. Only going to another brand will you solve this problem. I recommend the Royal 7900 series extractor.
Oct 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat Clearview - Belt and pump keep melting
Is the brush roll turning freely? Is there something binding the pump pulley or belt casuing it to not turn? Was the replacement pump a new one? If you replace these parts again, after doing so, try turning the pump pulley by hand to see if it will turn the brush roll easlly, if it doesn't then there is a problem.
Apr 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
Model Bissell Carpet Cleaner
I just needed the same info and found the model number - you have to turn the whole unit over. It's underneath the the vacuum unit, near the brush. Hope this helps.
Dec 22, 2007 | Bissell 8910 ProHeat Clear View Upright...
Vacuums Logo
24 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
