Question about Eclipse CD5100 CD Player
Im installing cd5100 in my 02 avalanche....my eclipse stereo harness has a amp turn on and a power antenna wire...my harness that plugged into my stock harness only has a power antenna wire....if im installing an amp my amp turn runs to the amp...and antenna to the stock wire...if im not installing an amp, do i wire the blue/white and solid blue together to the solid blue wire on the stock harness???
2 Suggested Answers
SOURCE: ok, I bought a new
It is available from United Radio Service for $14 plus $8 shipping. Just do a Google search for United Radio Service to get their web address.
Posted on Jul 16, 2009
Need Car Stereo Wiring Diagram
Here you go. Be careful this can disable the truck in some models due to the radio system be tied into the factory anti theft system..
2009 Chevrolet Tahoe Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. The accessory turn-on is controlled by the lan serial network. Run a wire to the fuse box or ignition switch harness.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: The radio harness does not provide a dimmer wire. The dimmer wire is controlled by the lan serial network.
Car Stereo Antenna Trigger Wire: The radio harness does not provide a antenna trigger wire. The antenna trigger wire is controlled by the lan serial network.
Car Stereo Amp Trigger Wire: The radio harness does not provide a amp turn on wire. The amplifier turn on is controlled by the lan serial network.
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jul 27, 2012 | 2009 Chevrolet Tahoe
Im installing a new stereo for my 1995 chrysler lhs. the stereo works, but why cant i get any sound?
It sounds like you have the "Infinity System". The accessory/antenna wire has to be hooked up to the power wire for the factory installed amplifier (should be located under the passenger's seat). Locate the wire from the original harness and hook it to the amp wire. I hope that helps. Please rate my assistance and leave a testimonial.
Dec 31, 2010 | 1995 Chrysler LHS
I'm installing an after market radio on my 82 vette, but i don't know which is the power lead for the power antenna. anyone know?
Usually the blue wire from the stereo is for the remote amp and/or power antenna. If you haven't cut off the stock radio plug, I would check into getting a stereo harness adapter for the stereo. Most auto stereo shops can get them.
Apr 27, 2010 | 1981 Chevrolet Corvette
Im installing a radio in my 03 chevy avalanche and i cant figure out y it wont work
if you put it in with the wire harness that plugs into the trucks harness you have to make sure the amp turn on wire is connected from the radio to the harness if the amp isnt on you get no sound, if you didnt buy the harness and cut into the trucks wires you could have a problem, check all radio and amp fuses also
Feb 23, 2010 | 2003 Chevrolet Avalanche
The radio was pulled off the wiring 2005 Chevy avalanche. How do I match the after market plug to the wiring in the truck? I have the 71-2003-1 parts but the colors do not match.
2005 Chevrolet Avalanche Car Stereo Installation Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: N/A
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under the Center Console.
Hope this will help you, good luck
Jan 05, 2010 | 2005 Chevrolet Avalanche
Where does the rem wire plug into
It plugs into the power antenna cord on your radio if your radio does not have a dedicated remote cord. The remote switch is so that you amp can detect when your radio is on and turn on too, or is off when your radio is off so as not to drain the battery
Sep 23, 2009 | Eclipse (XA1000) Car Audio Amplifier
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
2002 CHEVY BLAZER
Can purchased an adapter kit at Best Buy or Circuit City that is color cordinated with the factory wires for about 12.00. This will go right into the factory plug.
Radio 12v orange + radio harness
Radio Ground black - radio harness
Radio Ignition dk. green + radio harness
Radio Illumination gray (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- tan - gray +,- radio harness
RF Speaker +/- lt. green - dk. green +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- dk. blue - lt. blue +,- radio harness
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 457G, 555L, or 555T
Notes: The Passlock 2 wire colors are yellow, orange/black, and red/white (not used).
Sep 21, 2008 | 2002 Chevrolet Blazer
I need to install a max385vd in a 2002 pord f-350, do i need an install kit?
Regardless of whether this is an amp or a head unit, an install kit is either very helpful or necessary. If it's an amp, you'll need it for sure - you can't power an amp with 18 gauge factory power wiring like a head unit can use. You need to get at least 10 gauge power and ground wire, 18 gauge remote turn-on wire, and RCA patch cables to conduct the sound. If you have a factory head unit, you'll also need a line-level adapter to give you a source for the RCA patch cables.
If this is a head unit, you'll need the adapter harness to plug your existing stereo harnesses into the new head unit. It makes it simple - the wires on the new head unit are color-coded for what they do, and the adapter harness is identically coded. Match the colors, then plug it in. You may also need an antenna wire adapter (some cars require this).
Aug 10, 2008 | Clarion Car Audio & Video
Eclipse CD5100 CD Player Logo
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
