Question about AT&T EL51359 Phone
On screen it says connecting. Can not make or recieve any calls.
I have unplugged all the phones and removed batteries and connected back every thing, still same problem
  • Ramesh Feb 12, 2012
    AT & T Cordless Phone Dect 6.0 with three hand sets
My samsung mobile s3500 - the display has gone off suddenly, but the mobile is working. i am able to recieve calls. But how can i retrieve the contacts stored in PHONE memory without repairing the phone...
My dear friend, the problem with your phone is the flex is bad. The flex is the cable that connects the screen to the main board of the phone. First check if there is no damage on the screen, before replacing the flexi ribbon of the phone. Then you replace the flexi ribbon of the phone. If you want to replace it yourself, follow the steps below:
  1. Turn off your phone, Remove your back cover, battery, sim and memory card. Four screws need to be removed,
  2. Run something like a credit card around the join of the battery compartment to release it.
  3. A ribbon connector, needs to be disconnected. It attaches like a plug and socket so just lever this up to unplug.
  4. Now pull the circuit board to the side (a few clips around its edge hold the circuit board in place) and you'll see it's attached to the rest of the phone by another ribbon connector. Again, this attaches like a plug and socket and can be levered away from the circuit board.
  5. Remove the six screws you can see and you'll then be able to remove the slide part.
  6. The flexi ribbon that is behind the screen is what you need to replace, or you can replace the entire screen, but i will advice you replace the flexi ribbon only.
You can get a friend to do that for you once you find out you cannot do this on your own.
Take care and good luck
Jan 03, 2011 | Samsung S3500 Cell Phone
Ear piece is not working..only when speaker is on able to hear the callers voice. using moto rockr 6 model please assist
u need to change the ribbon, this is what connects the screen to the keypad an mainboard, sometimes f the phone falls or even when u are opening the phone the ribbon can be torn/cut.
Jun 23, 2010 | Motorola Mobility i776 Cell Phone
Phone Not Working
Remove the battery from the back, wait 1 minute, then replace the battery. DO NOT HIT ANY BUTTONS. place the phone back on the main base unit so it can reregister.
Apr 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
Cingular 8125 display problem
you have to open up the phone and try to remove and connect the screen flex cable back to it's original position
Jul 18, 2009 | Cingular Wireless 8125 Smartphone
GE 27956 only produces white screen in photo frame.
I followed these steps that were listed, but it didn't work. Then I increased the time in step to an hour, and it worked
I called GE support. I was told
1. unplug power from base
2. unplug phone connection from base
3. remove cover and battery from handset
4. wait 10 minutes
5. put battery back, reattach phone connection and power
It solved the problem.
Feb 20, 2009 | Lands Phones
Backlight not turning on when phone is turned on (Razr)
There is a small cable, inside the phone, near the hinge, that can come loose or unplugged. You should have this checked out by someone who can service it. For them it's a simple procedure of reinserting the cable fully.
Aug 03, 2008 | Motorola Mobility RAZR V3
Blank screen
Solution for Frizzyloo:
The most likely problem is that the connections between the phone and the screen have disconnected or are not connected properly. See if the screen will work if the phone is slid down or half way up etc. Try pushing down on the area around the screen and see if it works then.
Also get it to a repair person if this problem is continual. The problem will not be covered under warranty unless you get it in for under a year and it's worth replacing the connections.
Solution for Zeewon:
Try starting up the phone with out the sim and if it starts fine then your sim needs replacing. Try the same with the memory card. Also check your battery, there should be a sticker around where the contacts are and if it's red then your battery and the back of your phone have been wet. Wipe the back of the inside of the phone then replace the battery.
Good Luck to you both.
Nat
Dec 25, 2007 | Sony Ericsson W550i Cellular Phone
Phones won't pick up calls...say connecting
HOLD THE HANG UP BUTTON AND THE POUND BUTTON DOWN FOR 5 secons. select base unavailable....yes. then hang it up on the base and it will register to the base. if that doesn't work then unplug the base then plug it back in then put the reciever on the base.
Nov 20, 2007 | Uniden TRU9380-2 Twin Phone
AT&T EL51359 Phone Logo
41 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
