Question about Actron CP7672 Digital Multitester
Physical size of the Actron CP7672 Digital Multitester,
I want to know the actual physical size of this meter, and exactly the kind of 9V battery that fits inside. Is it the large rectangular one with the 2 snap-on terminals?
The meter measures in size aproximatelly 2 1/2" X 5" X 3/4" deep, and takes a standard 9 Volt battury, unscrew the two phillip screws on the back, and gently pull off the back cover, and you will see the battury at the bottom of the meter, unclip it from the battury clip, and replace with a similar type of 9 Volt battury, and reassemble.
Posted on Dec 07, 2013
I'm looking for replacement leads for my Actron CP7672 Multi-meter
You can get them on ebay for about $3 shipped. Just search meter leads.
Dec 07, 2013 | Actron CP7672 Digital Multitester
I need to know what kind of battery is best for my yamaha dt 200 ypvs bike is it 9v battery with 3amp or 5amp
It will probably be 12volt 5Ah. Check with your local dealer for confirmation and exact size.
Feb 25, 2011 | 2006 Yamaha DT 125 X
How to check voltage on an alternator
try connecting to battery terminals to check if it's charging
Jan 18, 2011 | Actron CP7672 Digital Multitester
Lost my manual and need to know how to test a car fuse
With a car fuse, you are only looking for continuity.
Remove the fuse from the car.
Set the tester to "continuity", if you have it.
Touch the leads to the ends of the fuse, if it buzzes, the fuse is good.
If you don't have "continuity", set the tester to ohms, the lowest setting, possibly 200.
Touch the leads to each end of the fuse and you should get close to zero, probably 0.1 to 0.5 ohms.
Gary
Dec 15, 2010 | Actron CP7672 Digital Multitester
Checking 220 voltage in an oven outlet. Where do the red prode and black prode go in plug and what setting do I use?
Set the meter to AC, in a range that exceeds 220 V. Plug either electrode into any of the three holes, plug the other electrode into any other hole. If you get a reading of approx 110V, then one of the holes you picked is the ground. There are only two other combinations to try (realizing that the red and black electrodes are interchangeable when checking AC.) Only one combination should read 220, the other two should read 110.
Nov 19, 2010 | Actron CP7672 Digital Multitester
Hou can i chek 220 volt
make sure your probes are connected properly ( Black to common and Red to V ) Turn the Knob , Set the Range to AC ( ~ ) 500 V or 1000 V ( What ever is more than 230 V ) . Use the Prob tips for testing ...
As you are a beginner , it is a good idea to use a Electrical Rubber Gloves while Playing with Live Voltage....
Take Care yourself .
deeric27@aol.com
Nov 18, 2010 | Actron CP7672 Digital Multitester
Need battery for Onan 6500 Generator
I have searched but cannot actually find what type male of battery it uses, other than it is a Lead Acid Battery. Now with lead Acid batteries, it is the actual Capacity, in Both Amperage output, and Physical capacity. So based upon that ANY 12 V DC Wet Cell battery of the SAME Physical size, and CURRENT capacity will work. Look on the actual battery itself, it WILL/Should have identifying marks written on it. Get one the same, it is NOT all that critical.
May 23, 2010 | Watts Onan Portable Generator - 5000 ,...
How to connect to test amperage on a digital multimeter
go to www.actron.com click on digital multitester cp7677, scroll to bottom of page and download the user manual pdf file for detail amperage tests. The manual is free.
Jan 05, 2010 | Actron Digital Multimeter Tester
Only has a -1 on the display
Christoph, Likely you have the meter set to resistance (ohms) and thus, are getting the displayed reading you've described. Also, with the polarity reversed ( positive and negative + / - ) you'll get the negative number displayed in voltage settings.
First off, check to make sure that the battery inside the back of the test meter is new. If your meter has been around for some time, it is likely that the battery should be replaced. Typically it is either a AA or 9 volt battery in most testers.
Once you've replaced the battery, try testing the old battery with the meter set to DC-V and the probes (red & black) in the DC-V connections. Set the measurement scale to the lowest on the DC range and then with the red test lead on the battery's positive end and the black test lead on the battery's negative end, you should be able to get a voltage reading of the old battery.
Now you can check the resistance function (ohms) by setting the meter to the Ohms function at the lowest scale/setting and touch the two leads together. You should get a reading of 0.00 ohms resistance. You might have to zero the setting manually with either a small adjustment wheel on the face of the meter, or with a small set screw on the backside of the meter. (some models have this installed inside the battery compartment also)
Hopefully that's all the issue you've experienced and your meter is now working properly. I hope you find this Very Helpful and best regards!
Nov 02, 2009 | Actron CP7672 Digital Multitester
Actron CP7672 Digital Multitester Logo
Top Actron Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Bill Boyd
Are you an Actron Measuring Tool and Sensor Expert? Answer questions, earn points and help others
