Question about Indesit Dishwashers
Hi experts, My Indesit IDL530 dishwasher never seems to run on any of the 5 programmes. On pressing the power button, the red light comes on and on pressing the start/reset button, the light signalling washing comes on and not the one showing water intake. But even then nothing progresses and just a buzz with that wasing indicator on shows for a second and goe off. But today only the buzzer sounds when pressing down the start/reset button and no indicator comes on atll. Will be great if you could suggest something. Thanks
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Posted on Aug 19, 2008
SOURCE: indesit idl530 error code
go to indesitservice.co.uk and look at he online manual for the machine. it tels you what it ean in there
Posted on Oct 09, 2008
SOURCE: Indesit idl530 2nd and 4th
rang indesit enginners there is a fault with the heating element needs to be replaced thankfully under guarantee only had it 8 weeks 13.08.09
Posted on Aug 13, 2009
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
Wont let me set program just beeps when pressing program so wont run ( indesit dishwasher
Hi. Are you still having this problem? I just experienced exactly the same thing with my D61 for the second time and eventually I just got cross and held down the P button for a couple of seconds and the machine beeped 3 times and the green light went out. I was then able to select the program as normal. Then, it froze on me again so I held down the button again, it reset again and I tried it on a different cycle. Now it's actually going through the cycle. It's so random (the first time I didn't hold down anything and just shuffled stuff around inside for a bit and then it worked ) it seems to be a actual fault with the programmer, so I can\t say for sure that this will work on yours or even on mine again but it's worth a try!
Mar 04, 2010 | Indesit 24 in. D61 Free-standing...
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit idl530 2nd and 4th lights flashing
Sep 23, 2008 | Indesit Dishwashers
Indesit IDL530
it will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
Sep 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
The second two lights on my dishwasher are flashing and not working any help would be great IDL530
On my IDL40S the second two lights showed that the water was not getting through. Have you checked the supply?
Jul 20, 2008 | Indesit Dishwashers
Indesit idl530 2 flashing lights
no, turn the on / off button off, then turn off the power for about 5 minutes and then it should work again. and at some point do contact someone to look at it.
Jun 13, 2008 | Indesit 24 in. D63 Free-standing...
INDESIT DW S 60
check and make sure the door switch is activating
Jan 03, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwashers Logo
64 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
