Question about Frigidaire ATF6000ES Front Load Washer
Gasket mold getting bad?
Mold
We have mold along the inner rim of the rubber gasket between the opening and the door. How can we get rid of/prevent?
Robert, You can buy or make up your own mold Rid/ cleaner, which you will spray on bad areas and wipe off. Tip if possible leave washer door open so trapped moisture can air dry.
Check the attached links, for mold Rid/cleaners.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Concrobium Mold Control 946 mL The Home Depot Canada
http://blackmold.awardspace.com/kill-remove-mold.html
Amazon com CLR PB CMM 6 Mold and Mildew Stain Remover 32 oz Spray Bottle...
Mar 10, 2016 | Bosch Vision 500 Series Front-Load Washing...
How to clean the mold of the rubber
If you have mold on the rubber gasket of your Duet front loader, I can almost assure you that you have lots of mold in other places in the machine. Front loading washing machine are almost hermetically sealed and if the door is left closed, the inside just never dries out. This is just a perfect environment for the growth of mold and other fungi. Once mold gets established in materials such as rubber gaskets, it can be very difficult if not impossible to eradicate because mold grows "roots" deep into the pores of the material, making it very difficult to remove. Eradicating the mold may result in damage to the gasket since my "cure" is to paint on full strength bleach on the moldy surfaces with a brush or sponge (wear gloves). Repeat if necessary. You may wind up having to replace the front door gasket to get all of it. It will probably take more than one application to fully eradicate the mold from the VISIBLE surfaces of the rubber gasket. If you remove the detergent dispenser and peer inside the opening, you may see a lot more mold inside the cavity. If you see mold inside the detergent dispenser cavity, imagine what the rest of the inside of your machine must look like. Do you run a periodic cleaning cycle as advised in the operating manual? Have you read the operating manual? Do you use the absolute minimum amount of HE (non foaming) detergent? Factory instructions for cleaning the door gasket call for mixing 3/4 cup of bleach into 1 gallon of warm water and applying this mixture to the affected gasket area, let stand 5 minutes and wipe the area down with a dry cloth. My experience has shown that this is a grossly inadequate concentration to deal with a deeply seated mold problem in the door gasket. To run the cleaning cycle, the factory calls for 2/3 cup of bleach to be added to the bleach dispenser. "Use of more than 2/3 cup of bleach will cause product damage OVER TIME". Initially, I would definitely consider using a whole lot more bleach than recommended and run two or more consecutive cleaning cycles. Then EVERY USE OF THE MACHINE: wipe the door gasket and all the creases and folds dry with a sponge, remove the detergent dispenser and wipe the cavity dry, leave the drawer out to dry on a clean towel, leave the door open, buy a cheapy plastic box fan and place it inside the machine and let it blow air around the inside of the machine for an hour or so to dry it off quickly, run a cleaning cycle at least once a month. If this sounds too involved or difficult, I would suggest switching to a top loading washer that is much less prone to develop mold growth as air can circulate in these types of machines to a much greater extent than the front loaders.
Sep 12, 2014 | Whirlpool duet Washing Machines
Mold on gaskets I like my Samsung refrigerator
Have you tried Clorox along with a fungicide? Mold usually forms on a moist surface. Is there any air leaks around the door seals? Sea Breeze
Aug 08, 2013 | Samsung Refrigerators
Black scum forming forming on rubber seal on inside of washing machine door
  • 1 Put on rubber gloves and safety glasses before commencing the cleaning process.
  • 2 Lay an old towel or drop cloth on the floor under the front of the washer to prevent floor damage as you clean.
  • 3 Fill a plastic cup with bleach and dip a tooth brush into the bleach.
  • 4 Remove the toothbrush and scrub the washing machine gasket with it to remove the black mold from it. Hold the gasket open with the fingers of your other hand so that you can clean the center grooves of the gasket where the most mold is likely to grow.
  • 5 Rinse the toothbrush in the cup of bleach and continue cleaning until you have removed the mold from the entire gasket.
  • 6 Wipe the gasket with a paper towel to remove excess bleach residue and any remaining mold.
  • Jul 02, 2011 | Zanussi Washing Machines
    Mold and mildew
    call a repairman to replace the gasket and see what he recommend.
    Apr 27, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
    The gasket on the washing machine has black mold on it and smells horrible. Do I have to replace this? Is it covered by warranty?
    Hello
    Simple green will get that mold off.Its up to you if you want to replace the gasket.I dont think the warranty covers mold or gaskets.
    Apr 12, 2010 | Kenmore 45087 Front Load Washer
    Mold on gasket
    The mold is common with the front loaders all you can do about the mold is wipe out the water that is in the gasket after a wash and leave the door open. DO NOT TRY TO CLEAN WITH BLEACH. The bleach will make the gasket weak and cause it to rip and then cause a leak.
    Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Mold issue on front gasket
    A solution of bleach and water will do. Just wet the rag and rub it down well. When this is done you may still have the marks but the mold is dead. If you want it to be completely clean you may need to replace.it.
    Jan 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Black mold
    YES GETTING RID IF THE MOLD WILL HELP YOUR PROBLEMS BUT YOU WILL HAVE TO GET RID OF ALL THE MOLD AND ALSO CONSULT YOUR DOCTOR FOR A CHECK UP SOME MOLD SPORES CAN CAUSE SERIOUS DAMAGE
    Jan 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
    SMELL IN WASHER MODEL #MAH5500BWW AND BLACK MOLD
    If you are using a high efficiency front loader than you suffer from the same symptoms that these front loaders typically have. The infamous bad smell and mold.. This is quite common because the front loaders actually seal the wash tub area with a water proof gasket around the door and left closed, the leftover water that gasket will get musty and if left untreated, may develop mold. Home Depot sells AFFRESH tablets that you cycle thru the qwasher about once a month and that usually does the trick.. The less desirable method is to wipe the gasket area with a towel or equivalent and leave the washer door open or partially open to air dry. That's been my experience.. Hope that helps !
    Jul 24, 2008 | Maytag Washing Machines
    Frigidaire ATF6000ES Front Load Washer Logo
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
