Nvidia boot agent ?
Computer Experts, i need your help. i have an Acer Aspire M1641. everytime i boot my PC, it will boot through these "NVIDIA Boot Agent." and then theres "PXE-E53:no boot filename receive." message. plus it took 5 minutes to finish the "client MAC ADDR: DCHP" loads.. is there any way that i can fix that?
  • Computers & ... Master
  • 5,660 Answers
I would state use the Restoration Disk, and perform a Repair. (Non-Destructive Installation)
This will repair the Nvidia settings for YOUR computer.
But more than likely Acer did not provide a Restoration Disk, and it is my understanding it may be hard to get a hold of. (Acer Support)
This makes me think you have installed a new Nvidia graphics card, since specifications indicate it comes with Integrated Graphics that is Nvidia GeForce 7050.
http://reviews.cnet.com/desktops/acer-aspire-m1641-u1521a/4507-3118_7-33234219.html
{Integrated Graphics is also referred as OnBoard Graphics.
ON the motherBOARD. The graphics chipset (GPU) is soldered to the motherboard, and Not to a removable graphics adapter card,
http://en.wikipedia.org/wiki/GPU
IF SO, the software (Installation disk) is installed FIRST, then the graphics card is physically installed.
IF not you get a driver conflict.
When a device is installed on a computer, (Such as a graphics card), Windows 'breaks it's neck' to find matching suitable drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This won't do.
Windows: "Which drivers do I use? These or THESE?"
[Drivers are small pieces of software, that allow the Operating System to 'communicate' with a device ]
Is this what you did? Install the graphics card, THEN use the graphics card's installation disk?
Post back in a Comment.
Regards,
joecoolvette
Posted on Feb 12, 2012
3 Suggested Answers
  • 11800 Answers
SOURCE: GM5664 will not boot up, What can I do?
There's something very wrong with the boot order from your pc: apparently now it's set to boot from network - something that is done only in network servers.  This happens when the BIOS battery (or the BIOS chip itself) start failing - it's time to start saving for a new pc, this motherboard has started to show signs of old age.
Enter the BIOS and set a new order: put the cd first, then the hard disk second and finally disable all the others. Save, exit and it should boot just fine
Posted on May 07, 2010
Testimonial: " Thank You Very Much although I am a Little disheartened by the fact that the comp seems to be near it's end especially since I've had it for just over a year. Is there anything that can be done to extend it's life?"
  • 26 Answers
SOURCE: AMD Data Change - Update
I need a little more info on this. I assume your using windows 7? I have a couple of thoughts on possible problems. It sounds as if your Bios is ether corrupted or might be set to boot in the wrong order or your hard drive has failed. I do not know what your system is but when you first boot up you should see a comment (usually at bottom of screen) that tells you which key to press to access your Bios. I do not know how much experience you have with computers but you need to be careful in there because if you change the wrong setting you could cause problems within your system. So after accessing your Bios screen you should be able to check the order of your boot process. (I'm thinking you might have multiple hard drives or partitions?) If everything checks out there is a good possibility that your hard drive has failed. Good luck
Posted on Jan 05, 2011
My acer aspire m1641 lost operation system,
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 24, 2012 | Acer Aspire M1641-U1521A PC Desktop
Hi When I start up my Acer Aspire L100 mini desktop, it makea clicking noise, which emits from with the computer and then the computer freezes with the screen below. Also, sometime I have to power off on,...
You can solve this problem by:
-- cleaning system junk
-- optimizing computer services
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Also remember to uninstall and reinstall updated drivers for your devices. Thanks
Nov 10, 2010 | Acer Aspire L100 PC Desktop
Computer freezes and shows a fault screen
Remove all the physical components of your computer and have it clean. You can use a brush or a blower and then reinstall your computer operating system. If it is windows xp then you will be needing the software for windows xp installation and then support cd for your motherboard and all support drivers.
Nov 15, 2009 | Acer Aspire L100 PC Desktop
My acer 7520 opens with an error reading NVIDIA boot agent 249.0542, then reads PXE-E61 media test failure, check cable, PXE-M0F exiting NVIDIA boot agent.
This error message could be a faulty hard disk or a faulty disk controller.
Reseat the hard disk to see if the problem is fixed.
If not go into the BIOS settings and check if the BIOS can detect the hard disk.
If the hard disk is not detected then remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If the this computer cannot detect it as an external hard drive then the hard drive is faulty. Then the Acer needs a replacement hard disk and Windows installed together with the laptop's device drivers and programs etc.
Oct 20, 2009 | Aspire Acer 7520-5324 Laptop
Windows Xp Sp3 installtion problem with Acer Aspire M1641 Desktop, there is a problem with installion of windows Xp in Acer Aspire M1641 Desktop. A blue screen is appearing. Saying that use CHKDSK /F...
http://komku.blogspot.com/2009/01/aspire-m1641-m3641-m5641-windows-xp-and.html
read down in comments for link on how to use Nlite and adding raid driver that will solve your problem
Mar 15, 2009 | Acer Aspire M1641-U1521A PC Desktop
Acer 4520 laptop media test failure
Your hardirve is damaged or your partition is corupted to fix this problem reinstall windows and make a new paetition or check inside your computer to see if a cable from the hardrive is desconnected.
Jan 17, 2009 | Acer Aspire 5610-4648 Notebook
When I want to use an Ubuntu 8.04 live cd the screen stays black
U need to configure your computer to boot from the ubuntu cd inorder to use the live cd. For doing this you need to set your boot device priority with preference to cd drive as first boot device. You can get into the bios settings by typing delete, F2, F12 (this depends upon your motherboard model). Go through the options in the BIOS until you find an option to change the boot priority. After setting it, save and restart the system with the cd in the drive. Select the option in the cd as "Try ubuntu without changes to my computer". ENJOY :-) Don't forget to rate my solution. Regards
Jan 07, 2009 | Acer Aspire M1641-U1521A PC Desktop
I have a acer aspire 5520 and it comes up with NVIDIA Boot agent 249.0542 copyright (c)2001-2005 NVIDIA corporation copyright (c)1997-2000 intel corporation PXE-E61: media test failure, check...
i think your harddrive got a problem.Maybe the hd are defect.Go to the bios(press `del `when start up)Than look if you can see the hard drive.
Dec 01, 2008 | Acer Computers & Internet
Acer aspire 5520
Sounds similar to this problem, one I was just looking up myself:
http://www.fixya.com/support/t342751-broadcom_undi_pxe_2_1_v10_0_9
The solutions shown may help you.
Nov 07, 2008 | Acer LXA3706003 Notebook
Computers & Internet Logo
288 people viewed this question
David Payne
David Payne
