Question about Emerson LC320EMXF 32 in. LCD TV
Emerson model # lc320emxf is stuck on max volume, can not adjust with or without remote
THE VOLUME IS STUCK ON MAX, I CAN NOT ADJUST THE VOLUME MANUALLY OR WITH THE REMOTE. I UNPLUGGED IT FOR HOURS AT TIMES AND IF THE VOLUME DOES GO BACK TO NORMAL WITHIN A LITTLE WHILE THE VOLUME WILL GO BACK TO MAX BY ITSELF.
SOURCE: Emerson TV LC320EMXF Remote code for Direc TV
I got the same TV for my stepdaughter and had the same problem. None of the Emerson codes worked. We use Dish Network but I did the autoscan thing on the remote and found that it was 672 which is listed as a Sylvania. I don't know if it will help in your case but maybe try the Sylvania codes. Good luck.
Posted on Dec 25, 2009
SOURCE: anyone no a code fot emerson Lc320EMXF to program
I just call emerson about this problem and they told me that they dont make the tv codes they just provide the frecuency. The cable or Sat. company need to make a code for that frecuency. hope this help as it help me
Posted on Jan 09, 2010
SOURCE: i have at&t uverse bought emerson lc320emxf
1465 worked for me.
Posted on Jan 10, 2010
SOURCE: need remote codes(universal)for emerson lc320emxf
Use 1465. However, you will still have to use your other remote to turn your TV on. :-(
Posted on Feb 01, 2010
PhilwithDISH
  • 123 Answers
SOURCE: remote codes
We would be happy to help you with getting your DISH Networkremote to control your TV. Pressand hold the TV button located on the top of your remote until all mode buttons at the top of the remote light up, then release. Use the number buttons to enter thecodes for your Emerson TV; here some of the codes we currently have: 764, 632, 648, 672, 654, and 516.Press the pound (#) button. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the TV. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, please try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Feb 22, 2011
Volume goes max and will not lower.
Hello
Please remove the batteries from the remote and check whether it is possible to use the local keypad on the TV? If the volume increases, it may be a problem in the local keyboard.
Apr 02, 2014 | Samsung LN32B550 32 in. LCD HDTV
Volume moves up and down by itself and then stays max volume
sounds like the main system board is kaplooiee..
well..do you like to dig into this sort of thing?..it will take around 400 and 2 to 3 hours..
Oct 28, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Volume moving on it's own
Either the key/button the TV or Remote is stuck. Just remove the batteries of the remote and try. If same thing continues, do vacuum cleaning of the panel button/switch after switching of the TV, removing the plug from the power outlet. If the problem persists, this might require attention by a qualified service technician.
Jul 11, 2012 | Sanyo Televison & Video
Lg will not respond to remote.
Does it work without remote OK.
You have to go to service mode menu and adjust. Only service center can help you.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Mitsubishi ws65711-Volume bar always displays/remote not working
Just solved my problem. Found out that the down volume button must have been sticking. Tapped on it a number of times and finally the volume bar went off and then the up volume worked fine. Looks like the down volume button on front panel is intermittently getting stuck. This happened last year but went away before I could figure it out. Maybe going to try and blow some compressed air in button socket.
Jan 25, 2009 | Mitsubishi WS-65711 65" Rear Projection...
What is the 5 digit code for sylvania 26'' lcd tv
Go to comcast.com they have a remote link for codes
Dec 22, 2008 | Televison & Video
Magnavox 55
Sounds to me like you need a new control panel board which should run you about $150-$200 max! might be semi burnt out like mine was and that is what i had to pay not sure if this helps but hey ya never know :)
Sep 08, 2008 | Philips Magnavox 55P9271 55" Rear...
Sony 27" wont turn off!!!!
It looks like one of the buttons on the front panel is stuck, base on the info you have provided; the volumen down button is stuck. The remote or any other buttons will not be operative until the fault has been remove.
I would suggest to try to press the Vol. down a few times just to see of it unlocks, if that does not work, the front panel assembly will have to be remove and try again if it works with the remote or manually.
The last thing to do if none of the above works, it will be to put a new switch.
Good Luck.
Feb 20, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Emerson LC320EMXF 32 in. LCD TV Logo
279 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
