Question about AT&T Blackberry Curve 8300 Smartphone
Blackberry curve my roller ball wont move down, how do I lift the ring around it in order to clean it?
  • Anonymous Feb 24, 2009
    the ball wont move up
  • teresacmille Feb 26, 2009
    my roller ball will easily move in any direction other than down. When i want to scroll down, i have to press harder on the ball (sometimes i accidentally select items instead of scrolling) and the ball feels like it can freely move down. There's a grindy sound or feeling - reminiscent of a bad knee joint.
  • 2,794 Answers
I found this solutions:
http://blackberrytrackballs.com/
It looks like the made them easy to replace but not easy to clean.
Replacement may be your only solution.
Posted on Oct 27, 2008
My roller ball does not scroll down, it goes all other directions but down, it makes it so hard for me to navigate.
take the roller ball out by poping out the silver ring at the top and look on the bottom of the ball and make sure that all of the black rollers will roll and if not clean them.
Feb 22, 2010 | AT&T Blackberry Curve 8300 Smartphone
My blackberry roller wont move down... is there any way i can move up and down without the roller ball?
sorry there is no way to do that without replacing the trackball or have the old trackball cleaned.
Feb 04, 2010 | AT&T Blackberry Curve 8300 Smartphone
Roller ball sticks on my blackberry curve.
pry silver cover ring off gently. Then remove ball assembly and clean with compressed air. If this does not work you can buy ball assembly on line.
Jan 01, 2010 | RIM BlackBerry Curve 8310 Smartphone
When i push scroll button down nothing works only side to side up and down works
This is very common for the blackberry's. Sometimes the trackball gets full of lent and dirt which won't allow the wheels to move. The chrome ring around the ball just pops off and the track ball should come out. Try cleaning it with a small brush. If this doesn't fix the problem, then a new track ball can be purchased on ebay for less than $5
Dec 03, 2009 | RIM BlackBerry Curve 8310 Smartphone
Track ball on my blackberry is stuck wont go up and now it just goes down i can't navigate.
take off the silver ring over around te ball it should just pop off and clean the entire ball piece that comes out
Nov 05, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
My scroll ball won't allow me to scroll DOWN; I can scroll up, across right and left, but NOT down................
pop the silver ring off from around the ball and remove the ball assembly. Be careful cause the ring only has connections on three sides and you must start on the side without the "pins". just keep messing with it and it will come out. then clean the rollers up and make sure the flap connector on the bottom is clean and intact. That should do ya for now and should hold you for several weeks
pls rate this fix
Oct 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Curve 8330 has a trackball issue
Good evening!
Removing (or replacing) the trackball on the Blackberry phone is very easy.
Shut off your blackberry phone (I would take out the battery).
Quickly examine the trackball itself on your phone. Use something with a small tip, like a screwdriver (NOT A KNIFE! Could damage the mechanism), and slide it underneath the silver ring around the ball. Gently lift up, might also want to try lifting both sides to help lift it off.
Once off, set aside the silver ring. You should now see the trackball mechanism, to remove it, simply flip the phone over and it should just fall out (can also tap it a few times which helps). The mechanism is simply held in magnetically.
You should now be able to see where the trackball was. You can now take a cotton swab with a small amount of rubbing alcohol and clean around in that area. If you examine, you will see small rollers around the trackball, you can also clean these.
This is the best way to clean the trackball. If all else fails you can replace the trackball. You can order one off amazon, they are very cheap, ranging from $2-10.
To put in the trackball, simply reverse the steps. The trackball device only goes in 2 ways, if it simply doesnt fit, turn it. It requires minimal force to put it back in. To put the silver ring back in, just match up the 3 little clips and gently push it back in.
Put the battery back in and give it a test.
Hope this helps!
Feb 26, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
The ball won't scroll down
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Roller ball will not work down.
Cleaning the roller ball with a lint free cloth seems to work pretty well. Lock the hand held and then just go to town on the roller ball with the lint free cloth.
Sep 17, 2008 | RIM BlackBerry Curve 8310 Smartphone
Roller ball
Same problem, wouldn't scroll down. Lifted the ring pulled out the rollerball and cleaned it with alchohol. Used a cotton swab, soaked it pretty good and rolled it around a bit. Set it back in and it worked like new. Watch how you take it out so you can put it back in the same way.
Sep 15, 2008 | RIM BlackBerry Curve 8310 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
133 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
