Question about LaCie Computers & Internet
I have a 1TB LaCie Extreme d2 which has decided not to mount anymore, the drive spins up when the firewire 800 or 400 is connected, but that's it. It doesn't appear in the profiler either.
  • 5 more comments
  • kel3354 Oct 24, 2008
    The problem still exists, I'm using a mac running OS X 10.5.5
    There is no driver needed for OS X
    I've already tried it with my MacBook Pro with the same result
    I'm the only user on the system
    It's not mounting using USB 2 either
    The drive does not appear in the disc utilities
    I'm going to try the power supply answer to my question.
    Many thanks
  • 507 Answers
1. Make sure to copy any files on your hard disk to another location because reformatting will erase them.
2. Click on your computer hard disk’s icon. Select Applications ? Utilities ? Disk Utility.
3. In the left hand column, click on the drive icon for the LaCie Disk (or the name of your external drive). Make sure you click on the first icon, not the second level volume icon.
4. Select the Partition tab.
5. Select the format type from the Format drop-down menu.
* Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
6. Click on the Options button.
7. Select the type of partition you want to use:
* GUID Partition Table - for bootability on Intel-based Macs
* Apple Partition Map - for bootability on PowerPC-based Macs
8. Click OK.
9. Click the Partition button.
more using this
http://www.lacie.com/download/qig/bigdiskextremeplus_esata.pdf
Posted on Oct 24, 2008
    Sergeant:
  • 306 Answers
Try to plug the device in a Active USB hub..
    Master:
  • 505 Answers
First try in another Mac System if possible. If it works then its a problem its a problem with your FW800 port or the OS/drivers.
try uninstalling and reinstalling the drivers and also update the firmaware.
Link which will be of help ;
http://discussions.apple.com/thread.jspa?messageID=5780373
Thanks.
  • Indrajit Roy
    Indrajit Roy Oct 24, 2008
    I believe the issue is the plug into the drive from the power supply. Please check pin voltages on the old power supplies.Order additional d2 power supplies, one for production and one to have a spare on hand.
    Thanks
  • 849 Answers
You need to install its driver....
    Scholar:
  • 136 Answers
Do the same procedure in safe mode and then try.
  • 1 more comment
  • ready2helpu Oct 24, 2008
    also uninstall the old drivers and then reinstall it again and then try.
    this is what you have to do
    Go to Finder > Preferences > General and make sure that there is a check mark (not a dash) in Show these items on the Desktop. Do the same in Sidebar. The LaCie drive should reappear.
    The origin of the problem may be related to the known issue where Tiger unmounts FireWire drives if you are using fast user switching and one user logs out.
    thanks.
    sometimes changing the power cord also helps.try it.
    Master:
  • 538 Answers
Hmm..can you tell u s about the pc xp or vista..and all connections checked, yes?
  • 2 more comments
  • A Womans Computer Man
    A Womans Computer Man Oct 24, 2008
    i suspect a firewire driver corruption issue here..
    thanks for the mac information..ok..just did one of these the other day..can you shut down the laCie, power wise, and then try another appletalk usb port with that cable..
    pardon me..it is firewire..
    well..there is only one of those..methinks..so it is a driver issue..unless the drive it self tanked.
    well..then with no driver, and no signal..the evident conclusion is that the drive tanked..hope you have the data backed up..
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
Daisy chain my external hard-drives
I don't think these drives are designed to be daisy chained. This worked for SCSI drives, but not for USB drives.
Dec 20, 2007 | LaCie d2 Extreme 250GB External with...
Lacie d2 external drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
Lacie 250GB Drive
my only option to you is get file recover software for mac an recover data if no luck e-mail me on wareworlf2001@hotmail.com
May 30, 2007 | LaCie d2 Extreme (300790U) 250 GB Hard...
Computers & Internet Logo
194 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
