Question about Dryers
Maytag de608 no heat
2 Suggested Answers
  • 10 Answers
SOURCE: I have a Maytag Model DE608 dryer and all of a
Fantastic dryer!!
Several things come to mind. Cycling thermostat, heating coil, electronic control unit. If you know your way around a multimeter, I could further help you out.
Posted on Oct 01, 2009
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
My Maytag Dryer DE608.. does not get any heat. It worked great 2 days ago.
heat element can be bad. you can fine heat element inside at the back of the tumbler
Oct 15, 2010 | Maytag Washing Machines
The dryer begins to heat runs a few minutes then cuts off
First, wet clothes are electrically conductive. With electronic sensing dryers as the wet clothes tumble, they touch the two metal bars in the drum.8e70df0.jpg There is a capacitor on the control that is trying to build up a charge, but when wet clothes create a short from one bar to the other, this charge is released to the frame of the dryer, therefore discharging the capacitor. As long as the capacitor charge is low, the control knows the clothes are wet. As the clothes become dryer, they short the bars fewer and fewer times. Once the capacitor charge builds to a certain level, the control knows the clothes are mostly dry, and it advances the program to the final timed portion, usually less than 20 minutes, some of which is a cool down portion to reduce wrinkling. If your dryer is shutting off after only 10 minutes, that means the control capacitor is never getting discharged. This can be due to a few different reasons: 1. Sensing bar wire is disconnected or broken; 2. Load is not large enough (remember the bars must be contacted repeatedly); 3. Bars are "coated" by fabric softener build up and need to be cleaned with Windex or 409. 4. Defective control board. 5. Airflow is restricted and moisture can't escape the drum. 6. Corrosion built-up on sensing board connection.(yank out the board and clean the contacts that sometimes is all it takes on some models) Address the airflow condition and load size. Clean the sensor bars and make sure the wires are all connected securely.
May 28, 2010 | Maytag Dryers
Maytag Gas dryer not heating, Model #MDG8600AWW
Called Maytage directly, information is free. Thanks anyway
Jan 13, 2010 | Maytag Dryers
I have a Maytag Model DE608 dryer and all of a sudden it is not heating. What could be causing this?
Fantastic dryer!!
Oct 01, 2009 | Maytag Dryers
Maytag dryer does not heat.
If the dryer comes on but doesn't heat, it is probably the heating element. If the dryer doesn't come on at all, it most likely is the dryer's motor.
Sep 18, 2009 | Maytag Dryers
I have an old maytag electric dryer model #DE608 that has a three wire cord. I moved into a new home with a four hole dryer outlet. Can I switch the dryer electrical line from the existing three wire to a...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Jul 06, 2009 | Dryers
Maytag gas dryer will not heat up.
The most common cause for "No Heat" on GAS dryers is bad gas valve coils. Go here for more: Dryer Repair Help
Go here for Maytag Dryer Part Info: http://www.repairclinic.com/Maytag-Dryer-Parts
www.RepairClinic.com
Feb 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
20 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
