Question about Proscan PS36109 36" TV
I turn my tv off than shortly returned to turn it back on i first got static sound like it could not find a clear channel, then got three clicks everytime i try to turn it on and this happens everytime i try to turn it on sounds like its trying to come on but i get nothing but clicks
    New Friend:
  • 163 Answers
The power supply is shuting off it self becouse a short, you may have to take to a repair shop, becouse there are nothing that regular people can do, is a job for a tech..good luck
Posted on Aug 10, 2006
Proscan LCD hdtv stopped, no picture, no sound, but green power lights up indicating that the power source is turned on. However, power button does not turn off to red light, I have to unplug the TV.
Hello Arberzine Fisher,
Not finding DIRECT resonating numbers here in USA...
but similar MAINBOARDS here are as low as $55
guaranteed (no worries: principles remain the SAME).
I do not think switching your sources is that
CONVENIENT... I would suggest you FIRST
attempt to follow your manufacturer's manual
(at the bottom of this paragraph).
ProScan PLCD3956A Instruction Manual Troubleshooting
I will further complicate your concerns: HOT SWITCH
of your LIVE video CABLES is typically rewarded by
frying the mainboard associated with that particular
video input:
Shut ALL power down... Configure your cable
(d'jour) and restore the POWER
Even COLD CABLE connections OUGHT be
considerate of (ESD) Electro-Static Discharge
concerns...
The slightest STATIC spark (you might not even
feel) is capable of destroying a SEMICONDUCTOR.
Simple protection: $6 anti-static WRIST-BAND
owned by every (competent) technician in the
INDUSTRIAL Electrons field...
(not meaning your average SEARs home repair)
Amazon com Rosewill Anti Static Wrist Strap Band with Grounding Wire ESD...
Feel free to comment me back if you need REPAIR guidance....
I have written BUNCHES of directions... of assistance: DIY
(do-it-yourself) will save you hundreds against a competent repair person... Much more if YOUR repair person seems to emulate the SAMPSONITE GORILLA (apologies to our Gorillas).
Hope this inspires
Carnac the Magnificent
May 13, 2018 | Proscan Televison & Video
Proscan 42LA45H has picture and no sound
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | Proscan 42LA45H 42 in. LCD TV
High audio static on all but one channel of my RCA TV
had this problem for a while only just found the cause, its either your tuner flipped out which means you just neded to retune the tv and it should be fixed if not that there was this setting i found still not sure what it is or means but you could select these letters i think there was S, BG and some other ones but i changed it to the top one which was BG and it fixed the static sound with the clear picture problem just stuff around with the channel settings and see if you have that setting hope that helped
Aug 16, 2009 | RCA Televison & Video
When changing channels sporatic static,
Please feed again cable channels in TV by selecting Auto Search / channel preset in TV Menu.
This will update channel data stored in TV memory.
Mar 18, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
On my proscan tv, when i turn it on the sound works but nothing comes on the screen, the tv is 8 months old.
i think this is a known problem....some guy in phoenix is selling a bunch of these returned tv's from SEARS with the same problem for $150.00 try to return it.
Mar 02, 2009 | Proscan 32LA25Q 32 in. LCD TV
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
Very Strange Audio Problems on Cable Channels; No prob w/VCR
Mike, before you decide to pony up the money for the hdtv take the thirteen inch set in and connect it to the same coax cable that is currently connected to the set with the audio issue. If you have clear audio the issue is definitely with the set. If not try replacing the coax connectors behind the wall plate, the barrel in the wall plate, and the coax from the wallplate to the tv. I am curious if the audio is clear when playing a DVD, VCR or Xbox? Hopefully we can isolate the problem. Thanks for using Fix Ya.
Oct 15, 2008 | Proscan PS32500 32" TV
Proscan PS50700
Appreciate the direct "Ask Me".
Technically, when a TV signal is said to be snowy, it indicates that the incoming RF signal is weak; on the other hand, when a TV signal has static, this refers to electrical noise that goes with the TV signal.
Having said that, then to your concern:
  • for snowy signal, it is the cable providers problem. They have to change where your incoming cable is tapped from, check/replace the feedin cable itself or worst case scenario, replace the line amp/distribution amplifier feeding your cable input;
  • for static noise, what is required is to check possible sources which could include (but not be limited to) electronic ballasts of florescent lamps, electric fans, hair dryers, shavers, wireless phones, computers and others.
Additionally, you may want to check if you have any RF producing devices attached to the TV such as VCRs, DVDs, game consoles. You can try unplugging them when not in use.
Worst case scenario is the tuner block of the TV is getting weak (unlikely but possibly). You can try rewiring the cable to feed first into a VCR, connect the VCR to any of the free Video IN, and select channels through the VCR. If significant improvement, then you have just confirmed an internal fault with the TV tuner, if problem persists, then the static/noise/low RF is caused by something else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 31, 2008 | Samsung TXE2745 TV
White Noise Sound
Your problem is somewhere between the tuner and video detector circuit. The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess! After the audio passes through all this, it is detected and sent to the audio processor. If any frequency has drifted away from it's value then you loose the sound. SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem. Stargazer
Mar 11, 2007 | Proscan PS32600 32" TV
Every channel is static, no sound
Unplug the tv set for 30 seconds, plug back in and turn set on. if this does not return your audio you need and you're NOT still under warrantee you should at least open the TV and check the board where the components are mounted and resoled any that look bad. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint. All can be replaced at a local electronic or hardware store and they're easy to replace good luck
Jan 03, 2006 | RCA F27645 27" TV
Televison & Video Logo
238 people viewed this question
Top Proscan Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
