Question about Dopod 838 Smartphone
Synchronizing I can't synchronize my Dopod 900 with any PC. Any PC need a driver for it. How can I get the driver for doing synch. Thanks
  • amran percaya
    amran percaya Apr 13, 2009
    need cd driver for dopod 900,,,,,,,,,,plz help me. how can i get it.
Can some1 give me a User guide for Dopod 838, pls
Posted on Nov 12, 2008
How do I load and coordinate my MS Outlook address book and calendar with my Blackberry Curve 8330?
Here is how you do it:
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here
2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Nov 18, 2009 | Ricoh Aficio 1035 Copier
I want canect my cell htc p3452 with my pc
Well you can please follow the below link to download your pc suite -
http://www.software112.com/products/htc-pc-suite.html
or
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
Thanks for using FixYa
Oct 17, 2009 | HTC Touch P3452 Smartphone
Drivers for htc p4350
windows drivers? xp and vista? Basically this is all you need: active sync or vista mobile device center:
Think thats all you need,
Let me know how that goes.
Thanks,
Ekse
Jun 03, 2009 | HTC P4350 Smartphone
Where i get drivers of toshiba poket pc e800
Hey,
you basically need active sync.
noting else, active sync contains the driver.
Thanks and good luck.
Ekse
Apr 02, 2009 | Toshiba e800 Pocket PC
Htc pc suite
If ur using HTC, u can download it at Microsoft page.
Jan 21, 2009 | HTC Touch P3450 Smartphone
How do I fix my Outlook Calendar synchronization problem?
Palm tech fixed my problem. It turned out some items in Outlook Calendar were corrupted, thus preventing a synch with LifeDrive. The fix is to export the Calendar items and import them. This process fixes corruption. After doing that I successfully synchronized Calendar with LifeDrive. More specifically. I moved Calendar items to a different folder, thus emptying the main Calendar folder. I exported the Calendar items in the new folder to a CSV (Windows) file. Then, I imported that CSV (Windows) file into the main Calendar folder. Finally,I did a synch and all worked perfectly.
Sep 13, 2005 | Palm LifeDrive Handheld
Why does pocket mirror trawl through all items when synchronising a calendar
The HotSync software on the Mac was never designed to cope with the scenario where you synch with a PC elsewhere. It assumes that you are performing a recovery synchronization when it sees that the handheld synched elsewhere. The assumption with the Palm OS was always that you synched one computer to one PDA. With more propsperous times, the software has not yet evolved at Palm Source (not part of Palm Inc any longer.) With regards to PocketMirror, there is a setting to allow you to synch to more than one PC. The setting is buried deep in the PocketMirror settings for each of the four conduits. The setting allows PocketMirror to see more than one PC as your route to an Exchange server.
Sep 11, 2005 | Palm Zire 71 Handheld
How to synchronize outlook
Switcher.... Inorder to sync your handheld with Outlook you must have outlook conduits installed. Follow these steps to have an outlook conduits installed. 1. Place the Desktop Installation & Software Essentials CD on your cd-rom drive. Wait for it to finish its autorun 2. At this point you'll be presented wth a flash window which contains certain options you can choose. 3. Click on "Change your synchronization method" 4. Click on "Use Microsoft Outlook to ...... " 5. Click on "Yes" 6. Click on "Done" 7. Restart your computer inorder to refresh the new settings. You can now use Microsoft Outlook to synch your appointments, contacts etc..
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Microsoft Outlook data won't synch
In ActiveSybch there is an option of setting the priority of either the PC, the PDA or leaving the items unresolved. You can either change this of follow another route. With the device off the cradle delete the partnership WITHOUT deleting the partnership folder. Place the device on the cradle & let AS find the device & setup the partnership. Once setup remove the device & go to options & set all the required options. Replace the device & it should synchronise. If you still have problems please contact me directly through email.
Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
Dopod 838 Smartphone Logo
150 people viewed this question
Top Dopod Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
