Question about Acer AL1721 17" Flat Panel LCD Monitor
Dark screen hay sir:                       I am having problem with my LCD monitor LA - 1721, its screen goes blank during work, sometimes it goes dead. plz resolve my problem and one more thing what year this model was made.                                           Regards,                                                   Muhammad Ajmal Siddiqui,                                                        karachi.
SOURCE: monitor flashes display 2-3 times then goes blank on initial boot
Throw it out the window. Acer sucks.
Posted on Mar 19, 2008
JULIANFIX
  • 975 Answers
SOURCE: AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
Posted on May 06, 2008
bammbammfran
  • 159 Answers
SOURCE: Acer AL2017 20 inch LCD Monitor comes on for 2 sec during start up then goes
Hi
I repair monitors
Based on other models , it sounds like you are having a powerboard-inverter issue.
It just so happens that I hjust got one in that's doing that, I should know in a day or two (maybe sooner) what the whole story on this model is.
Good timing !!??
ebaysbammbammfran
Posted on Oct 15, 2008
  • 244 Answers
SOURCE: monitor acer lcd AL1717a
Looks like you have a burned lamp.
Most LCDs have a lamp that lights the screen's image.
If you see the image, but its too dark.....you need a lamp replacement.
Please rate this answer if its useful
Posted on Jun 18, 2009
SOURCE: My Acer LCD Monitor AL1707A goes blank after 2 seconds
Try this,
When laptop on booting immediately press del.
And the screen will run normally.
But if the screen is still white, force to press power button soon.
And it will shutting down.
After shutting down, repeat this action.
It will work.
Vincent-Jember
Posted on Mar 15, 2010
Samsung 22inch lcd monitor goes blank after 1min idle system.
disable all power management options in your system BIOS
May 13, 2010 | Acer X193W LCD Monitor
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Samsung lcd television the screen goes blank after 20 mins of watching there is still sound though
right click on your desktop.go to properties.then go to the screen saver tab.click on screen saver tab.then you will see call monitor power.click on the power icon.go to the settings forr home/office desk power scheme.there you will see a setting called (turn off monitor)change that.let me know if it did work hay.
Sep 07, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Screen flashes on then goes dark
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 04, 2009 | ViewSonic VX910 19" LCD Monitor
I have an Acer AL1916W the power switch lights up brightly but when computer is switched on switch goes dull and and screen stays blank...Found two Capacitors that were bulging they were 220mf 25volt....I...
Can you send me a picture of the boards in your monitor? We work on Acer units all the time.
Buddy
Corporate Computer
www.ccl-la.com
buddy@ccl-la.com
Over 21 years of PC and printer support/repair
Jun 28, 2009 | Acer AL1916W 19" WideScreen LCD Monitor
Monitor goes Black off and on .....
I had the same problem for about a week and solved it yesterday by downloading the latest driver by NVDIA who makes my video card (NVDIA GeForce 6200).
I had previously updated the latest Sony driver for the monitor. It did not solve the problem but could be part of the solution in conjunction with the new video card driver.
Oct 31, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
LCD Monitor Goes Black during Use
I had the problem sometimes, but then I connected a second computer to the analog input and found out, that the screen didnt turn black but switches between the inputs on an on.
I found out that the "input" button seems to be short or damaged, as the behaviour was invertable by pressing the button. I blew into the button some times (a very naive solution, yeah) but it worked, the switching stoppped.
Oct 17, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
Open Questions:
See all Acer AL1721 17" Flat Panel LCD Monitor Questions
Acer AL1721 17" Flat Panel LCD Monitor Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
