Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi ws-65809 focus problem
My tv focus goes in and out. The different colors come up on right edge of image and then fades out again with the focus also going in and out. Is there anyone that can help me solve the problem. This is a 2002 hdtv.It is big but the chance of me replacing it is next to none. Please help..
  • 905 Answers
This is is some resistors on the conversion IC or IC's that control the color alignment
these big chips should also be replaced , they are on big heat sinks and the chips indentification will be on them they start with STK followed by numbers , you can get these from an electronic parts supplier store , but make sure you get all bad resistors replaced and change any electrolitic capacitors that don't look good
here is an example and also might be your chips
http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
electech
Posted on Oct 24, 2008
This is a model # RL8540 AKO6 TV made in 1991. Picture is severlyl fading, can anything be done?
since its so old you really only chance is to replace the bulb in the machine . also you may have to replace each color board here is a link to the bulbs and the three colored boards http://www.google.com/search?q=Mitsubishi+WS-65809+bulb&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#sclient=psy&hl=en&safe=off&client=firefox-a&hs=2uY&rls=org.mozilla:en-US%3Aofficial&biw=1280&bih=647&tbs=shop:1&q=Mitsubishi+WS-65809&aq=f&aqi=&aql=&oq=&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=d57722a22572de1d
Mar 16, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Image problem with WS-65809 65" Mitsubishi Projection TV
WS-65809?, if convergence is skewed and comes and goes, uses two of the STK-392-570 CONVERGENCE IC chips.
I have seen a lot of the Mitsubishi sets that use these two chips where the convergence jumps in and out. You need to replace both chips and adjust the set.
You can buy a pair of the chips on EBAY for less than 13 dollars plus shipping.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THE SETS THAT USE THESE TWO CHIPS.
If you or someone you know can do the repair you can save the set and a lot of money--most shops are going to get at least 300 for this kind of repair--I know as I have done hundreds of them here.
The instructions tell you everything you will need and how to do the repair. I have helped many people here do this based on my instructions.
If you want the instructions let me know and I will either post them here or send them to you.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 30, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Convergence is off far left and far right. Image
My TV did thistoo. When i would kick the side it would work for a couple days. I can't remember the name of the part that went bad, but it costed about $250 to have a repairman fix it
Jun 14, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi ws-65809
loose connection.
check for any over heated areas and resolder them specially the convergence IC.This resistor is located in the back edge of the chassis in the board in the right side and it might be hidden by a plastic casing that covers the high voltage transformer.If you are not too familiar with tv service you should seek the help of a servicer.Let Us know how it goes or if you need more information.
Nov 17, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65 in. Rear Projector
Bad solder connects on pins of STK convergence IC's.Replace IC's for reliability,then re-align if necessary.
Oct 04, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 Color Distortion
Bad connections on pins of STK IC's.Replace w/high quality new parts for reliability. Re-align as needed. .
Oct 03, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
