Question about Haier Washing Machines
HWM 9308 slow draining
Small amount of water draining and auto stop due to over draining timing
localwonder
  • 6784 Answers
SOURCE: some water drains out onto the floor.
the drum seals will need to be replaced. there are seals that are used for the screws that connect the drum to the drive. they are leaking.
Posted on Mar 11, 2009
  • 240 Answers
SOURCE: Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Posted on Mar 14, 2009
  • 272 Answers
SOURCE: DOES NOT SPIN AND DRAIN. INDICATES F21 ERROR MESSAGE
This is from an old posting. Common problem:
I had the same F-21 error and thanks to others who have posted, I was able to solve the problem. F-21 is the code Whirlpool uses to signify that the machine has tried to empty the drum unsuccessfully for four minutes. This is telling you either the hose that drains to the wall is blocked or the filter for the pump is blocked. If your hose is kinked, you have solved the problem. If it is not, then you have to clean the filter. To do this, do just as the others have recommended...
1) Unplug the machine.
2) Remove the front panel(my duet had 3 1/4" sheet metal screws on the bottom of the panel.)
3) Unscrew the white cap you see next to the small little pump.(note, any water in the machine will flood out. Have about 20 towels or better yet...a wet/dry shop vac. Someone else suggested this and it worked great. Once you turn that white cap a revolution or two, water will come out slowly. You can use the shop vac to **** it up before it hits the floor)
4) Pull out the cap completely and look at your new treasure. Mine consisted of the following: Two collar stays, one small plastic jewel from a shirt, two pieces of orange plastic of unknown origin and the big prize...one slimey sock.
5) Carefully replace the white cap being sure not to cross thread the connection.
6) Replace the front cover(this was the hardest part, those small screws are a pain to work with)
7) Plug it back in and fire it up!!!
Posted on Jun 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: F11 code. Washer has a small amount of water
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%%W#E$
Posted on Sep 29, 2010
richroth
  • 9472 Answers
SOURCE: small amounts of water leaking and will not drain.
Here is a link to Miele's website. They will be able to get the part for you.
Posted on Jan 08, 2011
Odor coming from a new bonaire evaportive cooler----have run for 5 days but odor [musty] persists
New evaporatives will smell for a fair amount of time. Its the preservative and glues which are used in the manufacture of the filter pads. Using the machine on cooling for 5 or 6 hours should normally clear this. If not, you can mask the smell by pouring a small amount of disinfectant into the machine whilst on its cooling cycle. (You will have to get on the roof for this if its a roof mount) The machine should dump out the water and refill with fresh water in 2 ways. Manual bleed off will have the machine dribbling water out the drain pipe all the time the machine is working or an auto drain will let all the water out immediately you switch off or after a preset time depending on what type of auto drain has been fitted.
Mar 20, 2017 | Washing Machines
Tip
Whirlpool duet washer F02 or F21 error code.
This error code indicates that drain times are longer than expected.
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds will slow or stop the removal of water from the washer.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Temporary fixes:
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
on Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I stop a small slow leak into bowl of 1 pc Crane toilet?
The seat where the flap sits could have a nick in it. The flap might not be aligned properly. A temporary fix is to put a small amount of Vaseline on the seat and that should stop the water leak.
Aug 30, 2014 | Home
I have an F02 error on my fagor washing machine any ideas?
This error code indicates that drain times are longer than expected.Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Use only HE High Efficiency detergent. The excess suds will slow or stop the removal of water from the washer.
Mar 29, 2010 | Washing Machines
Code f 02 and it is normally in the drain cycle.
After the clothes have spun dry, a small amount of water accumlates in the tub; generally 1/4 inch or so. Why BTW, I'm not sure that I've selected the correct model. Our washer is about 3 years old.
If draining into laundry tub, chances are water is siphoned back into washer due to laundry tub slow drain.
Very long drain hoses( such as 10+ feet) will also cause this.
Nov 05, 2009 | Fisher and Paykel IWL12 Top Load Washer
I have an Admiral GS20B6D3EV fridge freezer and am getting a slow intermittent trickle of water from the freezer which is also forming a lot of ice in the bottom of the compartment. Assume it is due to the...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Sep 07, 2009 | Admiral 26 cu. ft. Side-By-Side...
There is a small amount of water collecting in the bottom of freezer and then freezing
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 09, 2009 | Freezers
Dishwasher does not drain in normal cycle. on
Thoroughly clean drain screen and drain. Add small amount of drain cleaner to drain, flush after five minutes. Do not add hot water with drain cleaner.
Jul 07, 2009 | Dishwashers
Small amount of water is leaking from the bottom front side of fridge (not from the dors)
you say the water is not leaking from the doors.This is usually where the water leaks out due to a stopped up drain line from the freezer section.But if not there,I have had to modify drain lines that have been too short or not properly aligned to empty into the condensate drain pan which sometimes is set on the compressor where the heat evaporates the water.If the water is not coming from under the door,pull the fridge out,remove the acess cover,and take a look see.See if there is water in drain pan,and where drain line is .Make sure drain line is clear and over the drain pan. Gregg
Jun 12, 2009 | Refrigerators
Washing Machines Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
