Mistral washing machine 7 kg washes but does not junp to the next cicle for spinning the water stay in
  • rupeshkg Nov 08, 2008
    The machine does not wringe well at all.
  • 209 Answers
SOURCE: Hoover Premier 10.1 kg washing machine
do you actually see the motor spinning? or think you hear it, check the belt hasn't come off, or gone slack, it needs to be fairly tight but not too tight, if the belt and pulley go round but the drum doesn't then you have serious damage and need a new inner drum hope i have helped and if i can help more get back to me, i am an appliance engineer of 20 years
Posted on Oct 07, 2007
  • 351 Answers
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Posted on Mar 04, 2008
  • 136 Answers
SOURCE: LG washing machine intellowasher 7 kg wd-8050f
Please unplug or shut off the power at the fuse box...
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valve The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.There are two wires connected to each solenoid (aka coil) on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Posted on Jan 19, 2010
TheMobilian
  • 8220 Answers
SOURCE: washer stop
My first thought Lid switch gone bad. This washer has a motor which reverses. The motor is a double shaft design. 1 end of that motor drives the transmission and the other end drives the pump. When moving in one direction the tranny agitates them clothes and the water cannot be repelled out of the washer. On spin cycle the motor goes opposite directione and tosses out that water while spinning the drum. Later models have a fancy spin pawl which allows them pump to empty that water and lessen the strain on the motor. If that safety lid switch don't act right then them washer will be dead in da water during dat rinsing cycle. Now here is a wondermous vido i found on dat new fangled world wide web from repair clinic the most wondermous site to buy them parts for this washer.
More good stuff HERE
Visit my forum and I might told you a story: Here
Posted on Jun 19, 2010
SOURCE: MISTRAL MTLW7..2 too many probs!
e4 error on my mistral MTLW7 washing machine want spin
Posted on Mar 18, 2011
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
MY WASHER IS NOT DOING THE SPIN CICLE, DRAINS ALL THE WATER OK, PUMP IS FINE, JUST DOES NOT SPIN
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | LG WFT1071TP Top Load Washer
Hello. My washer kemnore Mod. 110.29822800 NO WASH
Sounds like the timer is faulty and needs to be replaced.
Jul 16, 2010 | Kenmore Washing Machines
The machine do not complet the cicle.in the regular cicle, the machine finnish washing but do nt let out the water and the cicle stop at this point
have a look and see if outlet pipe is kinked not allowing water to drain, failing this you may have a blockage in the pump system
Dec 17, 2009 | Washing Machines
Machine does not drain and spin at end of cicle It is a LG top loader washing machine model R852
Your motor clutch is bad. That controls on the motor along with the timer on a washer from going to spin or agitate.
Dec 05, 2009 | LG Washing Machines
Admiral top load 10.1 Kg 4 speed Combo has become
water does not stay in drum goes straight out?
Jun 04, 2009 | Admiral AW22 Top Load Washer
Mar 27, 2008 | Washing Machines
I have a mistral MTLW7 washer and it is having trouble with the spin cycle, it comes up with an error code on the display screen, and will not spin again, as all of the clothes are over one side. The...
Im no expert but i have found the hight of the water outlet is kinda critical to correct function on mine.
The manual states outlet to be no less than 700mm and no more than 1200mm and i have mine now at 900 mm and its all working fine.
Originanly was hooked in under sink and exerienced similar problems
Hope this helps ya out
Dingo~
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
